Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Sat Jun 04, 2005 7:16 pm Post subject: What size fuel line? |
I'm putting a 1904 with 44's in my split bus. Will the stock size fuel line be enough to feed it? Any suggestions on a better setup? Thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sat Jun 04, 2005 7:25 pm Post subject: |
I've got a 1904 with dual Dellorto DLRA and the stock hard line is plenty. I run the 7mm german hose and use clamps. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jun 04, 2005 7:31 pm Post subject: |
That's what I was hoping to hear. Thanks Glenn |
Alan_U Samba Member
Joined: July 10, 2004 Posts: 1762 Location: Vancouver, BC Canada
Posted: Sat Jun 04, 2005 9:50 pm Post subject: |
There are guys running 12:1 c/r 2276 motors using stock fuel lines and a CB rotory electic pump.
Stock fuel pump with your setup will work absolutely fine. Not certain if your bus has a filter screen on the bottom of the fuel tank but that may be a bottle neck.
I ran a 2110 with stock fuel pump, stock lines with dual 48 dellortos with absolutely no problems. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's....... |
Posted: Sun Jun 05, 2005 12:38 pm Post subject: |
Has anyone had problems running the screen on the fuel pickup? Seems like something you should have. I'm in the process of cleaning and sloshing the tank so I'm sure it will be clean inside, but I don't want to risk sucking something into the carbs. A fuel filter is obvious, but does the screen hurt any? |
MaidenFan Samba Member
Posted: Sun Jun 05, 2005 2:02 pm Post subject: |
What would you use for about 450hp max? EARLs line? -12 line or something? |
Glenn Mr. 010
Posted: Sun Jun 05, 2005 2:07 pm Post subject: |
MaidenFan wrote: |
AN6.
You have a 450hp engine? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Jun 05, 2005 4:31 pm Post subject: |
working on a drag car currently. Will have about 350hp normally, but at max boost about 450hp. |
turbobob Samba Member
Posted: Sun Jun 05, 2005 4:34 pm Post subject: |
It will take -6 to provide 500whp for fuel injected engine and -8 to do the same power with a carb, unless you are running methanol in which case you will need -10 for fuel inj and I don't know for carb methanol, never done that. _________________ Robert Young
ForcedPerformance.net |
Posted: Mon Jun 06, 2005 4:23 pm Post subject: |
meh, I wouldn't expect anything smaller to provide that much power anyway. However, wouldn't I be able to use smaller lines(not taht I would though, lol) since the car will be running a ton of boost to make those figures? |
