Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here!
Page: Previous  1, 2, 3 ... 12, 13, 14, 15  Next
JoelH
JoelH is offline
PostPosted: Wed Jul 26, 2017 4:42 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
I want to get my Thing rims powder coated close or even spot on to the stock silver. Does anyone know the correct color code, etc that I will need to tell the painter?
RED RIVER VW CLUB---www.redrivervwclub.com
'60 DD SWR Panel
http://www.thesamba.com/vw/forum/viewtopic.php?p=2522353#2522353
'62 Gulf Blue Ragtop Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=420720&highlight=
'60 Black RHD Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?p=6478591#6478591
1965 Sea Sand L568 Notchback
http://www.thesamba.com/vw/forum/viewtopic.php?p=8307805#8307805
hylomatt
hylomatt is offline
PostPosted: Wed Jul 26, 2017 4:52 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
I just went through all of that mess with Eastwood about two to three months ago. There's really no guarantee of a match. You can choose their rally silver or they're Silver Base. I'm referring to Eastwood colors of course. Eastwood said that their rally silver powder was different from the rally silver paint. I even ordered a spray can of the rally silver paint to do a comparison. I could be wrong but I'm fairly certain the original paint did not have a metallic flake in it. And all three of those items that I mentioned have metallic flake. It was irritating and time-consuming and I finally submitted to something called Silver Sparkle that looks really nice but isn't stock.
hylomatt
hylomatt is offline
PostPosted: Wed Jul 26, 2017 4:59 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
http://www.eastwood.com/hotcoat-powder-rally-wheel-silver.html
http://www.eastwood.com/hotcoat-powder-silver-base.html
http://www.eastwood.com/hotcoat-powder-oem-wheel-sparkle-silver.html
http://www.eastwood.com/ew-rally-wheel-argent-silver-paint-areos-12-oz.html
If you search around on the samba you will find a lot of mention of rally silver and Argent silver.
Pete VW
Pete VW is offline
PostPosted: Sat Sep 02, 2017 12:05 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
New to Samba. New to vw thing. Need sanity check on wheel and tire choice.1973 thing bug beam with adjusters not narrowed . Porsche disc brakes front and rear. Porsche steel disc brake wheels 4 1/2 front 5 1/2 back. All of this on hand. Time to order tires. Expect front to drop 2 1/2 with new beam back to drop at least the same with 1 or 2 clicks. Would like to have option to go lower front and back depending on stance. Current tire choice are 195/60R 15 front and 215/60R15 back. Tires will be 1 inch white walls. Going for beach buggy look. Should I go smaller tires?? Or will these sizes give me a little room to go lower? Or are they too big already.
Thanks for any advice,
Pete
Robio55
Robio55 is offline
PostPosted: Sun Sep 03, 2017 10:26 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
So, if i have 2 rims that are stamped 5jk 14, both with a date stamp of 10 67, does that mean these were some of the earliest 68 thing rims? Or did something else use 5jk14 wheels? Thanks, rob
jsweetd
jsweetd is offline
PostPosted: Thu Sep 21, 2017 1:32 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Great thread! Has anyone put tires on stock 14's lately? Trying to find an all terrain tire to go on stock rims.
JoelH
JoelH is offline
PostPosted: Thu Sep 28, 2017 8:08 pm    Post subject: Reply with quote
klokard wrote:
I am running stock 181 wheels, powder coated stock silver with original style hubcaps. I have the McCreary G78X14 all terraine tires on them.
What was the powder coat color code you used?
'60 DD SWR Panel
CritDicks
CritDicks is offline
PostPosted: Sun Nov 05, 2017 11:43 am    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Does anyone know if this tire/wheel combination for a 1973 Thing with stock suspension and fenders etc will positively work?
I know the largest size that will fit stock, figuring this means the front mostly, is 205/75/15. I would like to run those on the front, with new 7"X15" wheels and original back spacing and 235/75/15 on the back with the same wheels. Does this provide any rubbing issues on the stock vehicle?
Also, does anyone know the original back spacing for the original 14" wheels?
Andy
Kerrek
Kerrek is offline
PostPosted: Sat Apr 21, 2018 7:27 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
I am putting together a ‘73 thing and I am trying to decide wether to keep the rims that are on it or go with something new. Will this tire and rim combination work?
https://www.hdwheelsusa.com/products/falcon_gloss_black_machined
https://www.amazon.com/gp/product/B004QL6ATE/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
CarlSpackler
CarlSpackler is offline
PostPosted: Fri May 25, 2018 6:14 am    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
General Grabbers on stock rims. On sale right now at Walmart for $97 each.
'67 Micro Bus
'73 Thing
'91 Westy
Ray Syverson
Ray Syverson is offline
PostPosted: Fri Jun 15, 2018 11:45 am    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
After much procrastination I finally decided to order some General Grabber AT-2 27 x 8.5 R14 tires for my Thing. I found out they are being discontinued, but was lucky enough to still be able to get them. They are being replaced with ATX 27 x 8.5 R14. So ATX instead of AT-2. The ATX look a little different. Basically the same tire but they have extra detail on the sidewall that may or may not look just as good on a Thing. Glad I found out in time.
Ray Syverson
PostPosted: Fri Jun 15, 2018 11:46 am    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
booted
booted is offline
PostPosted: Thu Nov 15, 2018 8:02 am    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
mine are 1966 beetle wheels with 155/55x15 front and185/65x15 rears
herewego
herewego is offline
PostPosted: Sun Mar 17, 2019 5:50 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Just had my wheels powder coated. Took off the skinny old white stripes and had a set of General Grabber ATx’s fitted (27x8.5 R14). No rubbing even at the stops, drives straight and true at 60+ mph.
Before:
After:
obus Premium Member
obus is offline
PostPosted: Mon Mar 18, 2019 6:28 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Thats a beauty!!! Newer roof and side curtains?
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273
herewego
herewego is offline
PostPosted: Mon Mar 18, 2019 6:44 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Thanks! Replaced the original, warped top frame and worn out top with Thing Shop top and frame, same with curtains. Pretty painful price to pay, but I’m very happy with the quality. I try to do a little improvement each year. Definitely a marathon with a 46-year old car.
obus Premium Member
obus is offline
PostPosted: Tue Mar 19, 2019 4:08 am    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Good to know! Thats the direction i am going to go with the frame, top and curtains also. The shipping is going to be the killer. ugh
RWK
RWK is offline
PostPosted: Wed Apr 17, 2019 5:00 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Ok, thinking about new tires for my 73, I pulled out some NOS T3 rims (5 lug 15") I bought years ago thinking they were T2 15 in. anyways considering putting on 7.00-15 traction lug tires, found a good deal on some new one's that are bias 8 ply, any body try this combo yet? If they dont fit I can always put on my SC.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
PostPosted: Wed Apr 17, 2019 6:57 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Neat that they are NOS but I think they might have the wrong offset and/or be the wrong width for a Thing or Bus?
RWK
RWK is offline
PostPosted: Thu Apr 18, 2019 2:04 pm    Post subject: Re: Wheel/Tire FAQs-Wheel/Tire questions/answers? Start here! Reply with quote
Offset is real close, I measured back spacing at about 4.4" my thing rims about 4.34, (well maybe the same, thing rims are crusty!) so should be ok for thing, concern is the 7.00-15 tire, yes if it doesn't fit in thing confines I would dismount and put on bus 15s, I know about bus/thing incompatibility, these T3 rims have safety bead, unlike 15" bus thought that was unique though!
73 Type 181
63 Type 113
Page 13 of 15
