The EV Wheel Thread
Page: 1, 2, 3, 4  Next
Forum Index -> Eurovan Share: Facebook Twitter
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Nov 23, 2016 1:49 pm    Post subject: The EV Wheel Thread Reply with quote
I looked but didn't see anything, so I thought I'd start a wheel thread.
I'm curious about what kinds of alternative wheels can be fitted onto the EV. I've seen some MB rims, but I'm specifically curious about Audi. I have a set of 16 x 7 ET49 five spokes from my '94 C4 Avant. I'd like to use them as winter rims with Blizzaks.
Any tips or concerns?
Casey--
Volkswagens powered by Volkswagen
'89 Bluestar TDI
'01 Weekender VR6
Oly Bulli
DenverB
DenverB is offline
PostPosted: Wed Nov 23, 2016 4:56 pm    Post subject: Re: The EV Wheel Thread Reply with quote
you'll want to lift it and crank the torsion bars up if you put 16s on it.
cavevan.com has awesome lifters. about to get a grip of them for our vans.
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com
Zeitgeist 13
PostPosted: Wed Nov 23, 2016 5:32 pm    Post subject: Re: The EV Wheel Thread Reply with quote
It's a 2001, so it already has 16" rims from the factory. I'm not entirely clear on what the offset is for those, though. I've seen figures from 35mm to 49mm
Casey--
'89 Bluestar TDI
'01 Weekender VR6
Oly Bulli
BALDY & BLONDIE
BALDY & BLONDIE is offline
PostPosted: Thu Nov 24, 2016 6:33 am    Post subject: Re: The EV Wheel Thread Reply with quote
mine fitted with mercedes steels 7 x 16 et31 with 215/70 16 bfg at's, this is a '95 syncro multivan, with 2 x extra spring seats fitted to the rear, and front torsion bars wound up to suit, later vans may not suit this offset, cheers baldy
llilibel03
llilibel03 is offline
PostPosted: Thu Nov 24, 2016 1:15 pm    Post subject: Re: The EV Wheel Thread Reply with quote
Love the look of the BFG's but how do they work on the street (where I drive 95% of the time)? How many miles do yo expect to get out of them?
d-9
d-9 is offline
PostPosted: Fri Nov 25, 2016 2:52 am    Post subject: Re: The EV Wheel Thread Reply with quote
Lots of wheel options, almost anything with a 5x112 pcd from a VW/Audi will bolt up, and lots of aftermarket options. 2000s Passat, A4, A6, mk5 onwards golf, etc should be a straight fit. Don't go too wide or you will scrub the arches on compression.
You should consider the load rating of the wheel, in the UK it is illegal (but not strictly enforced) to use a wheel that is not rated beyond the max weight of the vehicle. People get very upset about this online, but just be sensible. Chinese eBay replica wheels do have a habit of cracking thou.
50Splitman
50Splitman is offline
PostPosted: Fri Nov 25, 2016 6:28 am    Post subject: Re: The EV Wheel Thread Reply with quote
How does one check the load rating of the rim from another VW or Audi? Is there a code on the back of the rim and a way to decode it? I've seen a picture of an EV with 2012 and later Beetle heritage rims (which I think looks great) but I'm worried that those rims would have nowhere near the load rating required for an EV. Thx
fkahlert
fkahlert is offline
PostPosted: Fri Nov 25, 2016 8:36 am    Post subject: Re: The EV Wheel Thread Reply with quote
on my Borbet wheels I had on the Passat, the actual max Kg rating was imprinted on the wheel. I believe (without looking now) the same was true on OEM steel wheels for the EV that I use on the snows.
In any case, any wheels that are also sold in Germany for example should with it or on the manufacturer site have a copy of the ABE (Allgemeine Betriebserlaubnis) which should state the max load of the wheel.
Same is true for the ET.
Florian 03 MVWK
fkahlert
fkahlert is offline
PostPosted: Fri Nov 25, 2016 8:43 am    Post subject: Re: The EV Wheel Thread Reply with quote
Also, speaking of offset. Unless I am mistaken, the OEM wheel has an offset of 49mm. That's quite a bit more than most aftermarket wheels have (many I've seen have 32-35mm). Unless I get this totally wrong, the lower the ET, the further the tires will stick OUT, reducing clearance to the fender.
Florian 03 MVWK
Stripped66
Stripped66 is offline
PostPosted: Fri Nov 25, 2016 9:03 am    Post subject: Re: The EV Wheel Thread Reply with quote
16x6.5" et42 steel wheels that TireRack sells for the Audi A4, 225/65r16 tires.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Nov 25, 2016 10:23 am    Post subject: Re: The EV Wheel Thread Reply with quote
No issues, I'm running a set of 15x7 forged Fuchs alloys from a UR Quattro.
Zeitgeist 13
PostPosted: Thu Dec 22, 2016 11:29 am    Post subject: Re: The EV Wheel Thread Reply with quote
They fit like a glove, and the center caps pop right in...but are a little loose, since the detents in the rims are in a different place.
Casey--
'89 Bluestar TDI
'01 Weekender VR6
Oly Bulli
wildenbeast
wildenbeast is offline
PostPosted: Thu Dec 22, 2016 1:07 pm    Post subject: Re: The EV Wheel Thread Reply with quote
Mine are 16-inch alloy MK5 2006 VW Jetta wheels, 7.5" wide, 5x112 with a 57.1mm center bore, ET50.
- Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU)
WagenWerks KS
WagenWerks KS is offline
PostPosted: Sun Sep 24, 2017 4:21 pm    Post subject: Re: The EV Wheel Thread Reply with quote
18x8.5 et35 Alzor style 081.. yokohama 245/40/18 tires
fit like a glove with no rubbing at all.. a little stiff due to the sidewall though
they are now flat green though Smile
17x7 et43 OEM Beetle Heritage wheels.. Hankook 215/55/17 tires
THESE ARE AN ABSOLUTELY PERFECT FIT AND RIDE
PostPosted: Sun Sep 24, 2017 5:25 pm    Post subject: Re: The EV Wheel Thread Reply with quote
This is a cool look. Interested in seeing the flat green look too
gavin.
gavin. is offline
PostPosted: Tue Sep 26, 2017 6:46 pm    Post subject: Re: The EV Wheel Thread Reply with quote
Holy shit-on-a-stick, they look nice.
VAEV1993
VAEV1993 is offline
PostPosted: Tue Oct 03, 2017 5:25 am    Post subject: Re: The EV Wheel Thread Reply with quote
16x6.5" et42 steel wheels - same vw steel wheels that others have gotten from Tire Rack, though I got these used.
225/60/16 - Nokian entyre 2.0
1993 Weekender - Hula
2002 Golf TDI
2017 Golf Alltrack
gest24
gest24 is offline
PostPosted: Tue Oct 03, 2017 4:29 pm    Post subject: Re: The EV Wheel Thread Reply with quote
Here is our 99 EVC on some B5 Passat "Sport Alloy" wheels (VW used to really lack creativity when naming wheels) wrapped in 235/60/16 Kuhmo Crugen HT51s. The suspension is still stock height (for now). Seat center caps added for the super OEM+ look.
[/img]
Chi-town
Chi-town is offline
PostPosted: Fri Oct 13, 2017 8:47 pm    Post subject: Re: The EV Wheel Thread Reply with quote
16" Tiguan wheels with BFG A/T KO2's
greenlaker
greenlaker is offline
PostPosted: Sat Oct 14, 2017 3:03 pm    Post subject: Re: The EV Wheel Thread Reply with quote
How's the ride quality and noise with the KO2s?
'15 Mercedes-Benz Sprinter Crew 144 hi roof
'10 Toyota Prius iii
'01 Honda S2000
'92 Mercedes-Benz 400E
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 1 of 4
