pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Sun Oct 08, 2017 10:26 pm Post subject: Lost a wheel today. related to powder coat? |
This afternoon, my wife lost a rim on highway 17 with my son in the back seat. She got it over to the side, but it was squirrely and both of them were pretty shook up. The lug bolts backed out. When I got there, I checked the other 3 and the two fronts were tight, but the other back was also loose.
Right before I drove the car up from So Cal to Nor Cal, I had the rims stripped and powder coated. New tires, then installed them myself and torqued them to 80 ft lbs. Not sure what the spec is but that should have been tight, since I've been doing it for decades.
I am not sure if the powder is a factor? Also, the fronts are disk, back are drum. Brakes were not dragging, and the car had no other issues. I mounted the spare and drove it home.
Any thoughts? I thought I remember a debate here about reaming the powder away from the bolt seats? _________________
sjbartnik wrote: |
Engines get hot. They have fire inside. |
Tobias Bylund Samba Member
Joined: December 10, 2007 Posts: 202 Location: Varberg - Sweden
Posted: Mon Oct 09, 2017 12:39 am Post subject: Re: Lost a wheel today. related to powder coat? |
That was what i was about to suggest, i would for sure remove any powdercoating on the ball seat for the lugs/nuts on the rims, if that stuff breaks loose from the metal on the rim, you would have a loose nut |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Mon Oct 09, 2017 3:45 am Post subject: Re: Lost a wheel today. related to powder coat? |
Did a quick search on the net and this topic comes up quite a bit, so I am guessing there is some concern. _________________ D-Dubya Manx clone - 63 Short pan,1914.
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1291 Location: Modesto, CA
Posted: Mon Oct 09, 2017 5:46 am Post subject: Re: Lost a wheel today. related to powder coat? |
Oooo , highway 17. I'd be shook up too!
I've been thinking about having my wheels powder coated. Maybe I'll insist they don't paint the lug holes.
H2OSB |
wcfvw69 Samba Purist
Posted: Mon Oct 09, 2017 5:51 am Post subject: Re: Lost a wheel today. related to powder coat? |
Very common for this to happen if you don't remove the powder coat from where the lugs sit on the rims. I had some lugs loosen on freshly painted rims as well. When I checked the lug torque, they had loosened. I unscrewed one of the looser lugs and found a thick layer of paint on the lug face.
I removed all 4 rims and removed the paint from the seat on the rims where the lugs tighten up. They never loosened again. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Mon Oct 09, 2017 6:19 am Post subject: Re: Lost a wheel today. related to powder coat? |
OK, thanks guys. Guess I know what I'm doing this weekend!
This didn't happen for the first 50 years of the car's life, then within a thousand miles of powder coating. That's definitive enough for me I think. _________________
sjbartnik wrote: |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Wed Nov 22, 2017 6:14 pm Post subject: Re: Lost a wheel today. related to powder coat? |
Yes. For sure caused by the powdercoat. Sounds like you guys got lucky. Powdercoating is very thick and chips away easily with torque applied, leaving a gap. I nearly lost a wheel on my '57 after 200 miles of desert driving with powdercoated wheels. I got lucky. My buddy rolled his 23 window after a few thousand miles as well. Not so lucky. I'm sure a google search would yield all kinds of horror stories.
Cdennisg shared this genius idea
modified lug bolt for paint/powder coat removal
I used a cold chisel to plow a few grooves in a lug bolt. a quick spin with a drill and socket and the freshly coated lug bolt holes are shiny and free of paint, awaiting fresh contact with a lug bolt seating surface. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Nov 30, 2017 12:54 pm Post subject: Re: Lost a wheel today. related to powder coat? |
Lug bolt ^^ is a genius reactive method.
A good proactive method is to have the powdercoater wipe the lug holes prior to baking.
The powder wipes off like dust on a waxed coffee table.
It's how they do powdered Harley cylinders (with exposed fin edges).
Polish... powder... wipe... bake...
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Wed Dec 06, 2017 1:00 pm Post subject: Re: Lost a wheel today. related to powder coat? |
I'd never had a problem with powder coated wheels before, so I was a bit skeptical in the past.
Then more recently, when I had my Bay wheels powdered in a 2-part coat (clear coat over chrome silver), I torqued them on, but didn't drive. Then I broke torque and removed the rims to do some other stuff...low-and-behold, the powder coating on the lug seats was falling off in little ring-shaped layers, having yielded and delaminated under the pressure of the lugs being torqued on it.
Now I'm convinced that it ALL needs to come off the seats (or never be applied like the pre-wiping suggestion above). |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Fri Dec 08, 2017 1:26 pm Post subject: Re: Lost a wheel today. related to powder coat? |
I do all my own powder coating and I've never had anything come loose after years of driving
Most of mine are mutiple coats.
the white wheel is, white base, clear with ice pearl, and then clear on top
the phone dials are almost chrome with a clear topcoat
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Wed May 15, 2019 9:10 pm Post subject: Re: Lost a wheel today. related to powder coat? |
Well, I joined the club today. I just brought my 1969 Beetle out of hibernation last week after doing a lot of work on it. During the winter, I had all 5 of my stock wheels sandblasted, straightened, and powder coated, new rubber on each wheel. I torqued each lug nut to 95 ft/lbs. I was just enjoying driving it around, and tweaking the timing and carb tuning. A few days ago, I took it up a winding mountain road near my place and had a lot of fun coming down(maybe speeding a little) testing out the little bug in the corners. The next morning I was taking the dog for a swim, and there was an awful grinding noise coming from the rear. I managed to get the bug to the garage that I rent about 2 blocks away. I was bummed - thinking I had a brake job or worse to look forward to, and getting parts here takes at least a week.
Today, I decided that I better find out what the problem is, so I can get parts ordered. As soon as I jacked up the car, the problem was obvious - all four lug nuts on that wheel were loose, but it looked like I caught it soon enough to avoid any damage. I checked all of the other wheels, and they were fine. Looks like I will be reaming all of the lug holes this weekend. Campingbox's chisled lug nut reamer looks like a great idea, but I don't have a spare lug. I'll hit the hardware store in the morning and see what I can come up with. |
john7 Samba Member
Joined: August 06, 2003 Posts: 1542 Location: Garden grove ca
Posted: Thu May 16, 2019 9:50 am Post subject: Re: Lost a wheel today. related to powder coat? |
ive never had a problem with 4 lug wheels powder coated coming loose.
BUT powder coated 5 lug wheels come loose. i lost a couple before. always the left rear wheel. ive even changed the drum and lugs and gone as far as having the drum modified with press in studs. i always torque my wheels with a torque wrench.
i would scrape the powder off of the lug holes, torque the wheels, drive 20 miles, torque again, and then retorque again after another 20 miles. you will find that they retorque the 2nd time and a few of them will still retorque again the 3rd time. _________________ Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders. |
Posted: Thu May 16, 2019 12:15 pm Post subject: Re: Lost a wheel today. related to powder coat? |
john7, it was the left rear wheel that worked itself loose. |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed Aug 14, 2019 9:13 pm Post subject: Re: Lost a wheel today. related to powder coat? |
better get some left hand threaded studs installed, lol _________________ foam cowboy hats aren't good helmets. |
Danwvw Samba Member
Posted: Fri Nov 13, 2020 2:46 pm Post subject: Re: Lost a wheel today. related to powder coat? |
W1K1 wrote: |
Hi "W1K1" I saw your recent post on the
2054 Build for the Fastback and was looking at your photos of the Dellortos with the 30/34 Venturis "Sexy" , when I noticed the PhoneDials above. I have a set I can run on my bug but they need refurbishing, How are they prepared for the Powder Coat? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
W1K1 Samba Member
Posted: Fri Nov 13, 2020 4:11 pm Post subject: Re: Lost a wheel today. related to powder coat? |
Quote: |
I have a set I can run on my bug but they need refurbishing, How are they prepared for the Powder Coat? |
I normally blast them clean so they have a good tooth for the powder to stick to.
They should be pre heated to leach out any oil out of the pores, I had one wheel that solvent popped the powder after the clear was added 3 times even after pre heating. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Kento-Moto Samba Member
Posted: Mon Feb 07, 2022 10:14 pm Post subject: Re: Lost a wheel today. related to powder coat? |
W1K1 wrote: |
Looks very nice W1K1, I have a question though ... how do you mount the tires without damaging the painted finish? My local Americas tire says they cant guaranty they wont chip or scuff the paint when installing. Powder coat finish they say shouldnt be a problem but painted is. ...? |
W1K1 Samba Member
Posted: Tue Feb 08, 2022 2:47 pm Post subject: Re: Lost a wheel today. related to powder coat? |
I've had my tires mounted at Costco for all my cars, I've never had a problem or damage. They are usually happy to get something "different" to work on _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Adam47374 Samba Member
Joined: September 14, 2014 Posts: 36 Location: Richmond, in
Posted: Thu Apr 07, 2022 6:46 pm Post subject: Re: Lost a wheel today. related to powder coat? |
Kento-Moto wrote: |
I found a shop that uses a newer style machine, then got them to put shop rags over the parts that hold the wheel, you don't need much grab to get the tire on, It's getting an old tire off that you need the extra grab. If you toss the installer a $20 before starting the work, that might also help. _________________ 1968 Bug 2nd owner
1974 Brazilian Split Window Ambulance
2017 GTI |
