Brake line connections
Buzzfagan
Buzzfagan is offline
PostPosted: Thu Oct 12, 2017 9:21 am    Post subject: Brake line connections Reply with quote
Should you use teflon tape, threadlock or anything else on the brake line fittings into each other, into the brakes or into the master cylinder?
Dale M.
Dale M. is offline
PostPosted: Thu Oct 12, 2017 11:53 am    Post subject: Re: Brake line connections Reply with quote
NO.... The actual seal is in the double flair (SAE) or bubble flair (for VW) any sealers or tape are going to be a problem not a help or solution...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Lo Cash John
Lo Cash John is offline
PostPosted: Thu Oct 12, 2017 1:53 pm    Post subject: Re: Brake line connections Reply with quote
What those guys said.
Also, make note that "double flares" and "bubble flares" are different and NOT interchangeable.
www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
Bluggy
Bluggy is offline
PostPosted: Thu Oct 12, 2017 7:07 pm    Post subject: Re: Brake line connections Reply with quote
Was looking for the thread pitch and size, seems to be 10mm 1.0
This thread has some useful info and illustrations, awesome posts from Dale...as usual.
https://www.thesamba.com/vw/forum/viewtopic.php?t=638088
