jacoby1007 Samba Member
Joined: July 28, 2016 Posts: 105 Location: North Hollywood, CA
Posted: Sat Oct 14, 2017 5:43 pm Post subject: Grounded Heater Control |
I searched for this but didn't seem to find it. Where does the control arm for the grounded heater contact get ground from? With out my heater control flaps installed the control dash arm is not grounded. Does it really get grounded at the control flaps in the back? Not grounded at in the front anywhere? _________________ 1974 Westy 1967 Beetle |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sat Oct 14, 2017 6:34 pm Post subject: Re: Grounded Heater Control |
I love hidden things like that, I added the late bay switch contacts to my 71 bus heater levers. I hope it will make a good stealth install on my under cab floor blower motor I'm still working on
It's really easy to get the switch contacts apart, but getting the lever assy out is a pain. You probably just need to scotchbrite the contacts and rub a little vaseline on them. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Sun Oct 15, 2017 1:01 pm Post subject: Re: Grounded Heater Control |
I got it working after taking the assembly apart. To confirm it does ground on the assembly. I also added a smaller washer on the side to help it make more contact. _________________ 1974 Westy 1967 Beetle |
