VEE DUB BOYS Samba Member
Joined: August 30, 2011 Posts: 146 Location: Greenville, SC
Posted: Sun Aug 20, 2017 8:10 pm Post subject: Re: Starting to build my Heb. all steel replica |
peter schepens wrote: |
nice detail again . That bump is bolted on the rear cowl and afterwards leaded together on older Hebs. Later cars had it pressed in the rear cowl. The same for the rain gutter. First series was hand made, second was a pressed rain gutter and welded on the rear cowl, last serie was in one piece pressed.
Greetings. |
Peter, I always enjoy your analysis of each step of the process. It is a big undertaking and my many friends make it easier along the way |
Posted: Sat Aug 26, 2017 6:13 pm Post subject: Re: Starting to build my Heb. all steel replica |
Little more work in the cowl and vents today
This image shows the progression from layout to drilling holes to peening the holes. Then you slit the areas from front to back and fold them over. Just like the factory before they started stamping the cowls in one piece:
T2 Samba Member
Joined: February 15, 2003 Posts: 187 Location: Yachats, Oregon
Posted: Sun Aug 27, 2017 11:17 pm Post subject: Re: Starting to build my Heb. all steel replica |
Damn nice work. Wish I had a tenth of your ability |
Posted: Tue Aug 29, 2017 5:53 am Post subject: Re: Starting to build my Heb. all steel replica |
T2 wrote: |
Ambition, lack of finances (ready stamped cowls are so far out of my price range), and heart and soul are my motivation. You could do it too |
HMVWNAB Samba Member
Joined: September 23, 2006 Posts: 1067 Location: Sunshine State
Posted: Sat Sep 02, 2017 3:53 am Post subject: Re: Starting to build my Heb. all steel replica |
VEE DUB BOYS wrote: |
I just have to ask, since I know next to nothing about metal work, how do you manage to bend each vane so perfectly straight with no visible deformity? _________________ What are the last 2 words of the National Anthem?
PLAY BALL! |
Hacksaw-BoB Samba Member
Posted: Sat Sep 02, 2017 10:40 pm Post subject: Re: Starting to build my Heb. all steel replica |
Hi Matt . . . I want to know as well _________________ Hacksaw BoB
http://www.VintageVolkswagenModels.com
Collector of Vintage VW Toys
BoB's Restor-Version Shop |
Posted: Sun Sep 03, 2017 8:19 pm Post subject: Re: Starting to build my Heb. all steel replica |
HMVWNAB wrote: |
I just have to ask, since I know next to nothing about metal work, how do you manage to bend each vane so perfectly straight with no visible deformity? |
Hacksaw-BoB wrote: |
Hi Matt . . . I want to know as well |
To both guys that were wondering about the pressing of the louvers. This is my second attempt at pressing, and the process becomes easier the more I do it.
The process consists of a lower die and an upper die. The lower die is fixed in a vise. The upper die is placed over the area you want pressed, and is struck with a hammer.
The louvers are not consistently the same length, so I made the top die to the shortest length. The longer vanes required a little overlap of the top die when I pressed them.
Difficult to explain without a picture or video.
I guess the best way to describe the straight and uniform vanes is this: Tooling is very important. I spent several hours adjusting the top die so it would produce a clean,
crisp and straight vane |
Posted: Sat Sep 23, 2017 8:46 pm Post subject: Re: Starting to build my Heb. all steel replica |
Super day with many Hebby friends. Checking panels and wood parts on original Hebs. Thanks to Mark Schlachter for letting me put out our panels at the Open house at the new location for Metalkraft Coachwerks
Posted: Sat Sep 30, 2017 9:39 pm Post subject: Re: Starting to build my Heb. all steel replica |
Been a busy day transferring measurements to paper. Going to take these
patterns to a metal shop to transfer them into files so they can be laser cut.
The large pattern on top is for the rear seat crossmember.
The smaller pattern below is the rail that goes from the crossmember to the
package tray. The part that holds the two crossmember pieces together is
already on the piece but is hard to see because it is the same color.
Posted: Sat Oct 07, 2017 7:56 pm Post subject: Re: Starting to build my Heb. all steel replica |
From paper to steel in one day. Lightly tacked together to check the fit
T2 Samba Member
Posted: Mon Oct 09, 2017 8:25 pm Post subject: Re: Starting to build my Heb. all steel replica |
You should make a few of each part you do for us less talented people to buy. Sign me up. Plus it would help finance your project. |
wcfvw69 Samba Purist
Posted: Tue Oct 10, 2017 6:07 am Post subject: Re: Starting to build my Heb. all steel replica |
_________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Tue Oct 10, 2017 4:40 pm Post subject: Re: Starting to build my Heb. all steel replica |
wcfvw69 wrote: |
Going to try to keep up with progress on a weekly basis as I work a full time job during the week. Glad you're enjoying the show. |
Posted: Sat Oct 14, 2017 2:40 pm Post subject: Re: Starting to build my Heb. all steel replica |
Snip and check
Paper to plywood:
Finished fitting and ready for installation after a few more details.
T2 Samba Member
Posted: Sun Oct 15, 2017 7:00 am Post subject: Re: Starting to build my Heb. all steel replica |
Looks like you nailed it. |
Posted: Sun Oct 15, 2017 1:52 pm Post subject: Re: Starting to build my Heb. all steel replica |
T2 wrote: |
That's the benefit of having the old gal to test fit the prototype for the rear seat crossmember. My buddy owns the 50 standard and has been restoring it for a few years now. Measurements were taken from a mix of 3 Hebs that were in Cincinnati over the past several years. I was fortunate enough to be allowed to document them with paper templates, pictures and measurements |
Posted: Sun Oct 22, 2017 12:36 am Post subject: Re: Starting to build my Heb. all steel replica |
Original parts are gold in this hobby. Passenger side hinge cover.
Way out of sequence for the build, but you gotta strike when such a rare part
Is on loan from the owner |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1013 Location: belgium Caesars camp
Posted: Sun Oct 22, 2017 1:39 am Post subject: Re: Starting to build my Heb. all steel replica |
Nice work again Matt.
It is good to have an example. Did you tip the edge with the bead roller or with hand held dolly and hammer? That is how I made them.
The lower reinforcements for the 2 bolt fixing plate is nice. I whould made an extra set, you never know who needs them _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
Posted: Sun Oct 22, 2017 3:10 am Post subject: Re: Starting to build my Heb. all steel replica |
The lower reinforcements for the 2 bolt fixing plate is nice. I whould made an extra set, you never know who needs them |
Thanks again Peter. I was able to use a bead roller with a 5 mm (1/4") bottom die and a top die that was maybe 3 mm (1/8") to roll over the edges of the hinge covers. Several passes tipped the hem past 90 degrees and I finished it on a table with a body hammer. Multiple pieces are easy to make as long as the metal supply holds out I try to make the large pieces first, then smaller pieces from the cut offs. And yes, I always try to make extra pieces for those in want or need of them. |
Posted: Sun Oct 22, 2017 3:22 am Post subject: Re: Starting to build my Heb. all steel replica |
The heater channel to heater tube stiffener:
This is the same die I used to roll the edge of the hinge covers. A 50 ton punch was used to punch out the holes. Then, just roll the edge and cut out the triangle. I have to wait to show a finished pic of the stiffeners. I'm still working out a method to stamp the 2 hole depression. |
