vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Fri Oct 06, 2017 5:13 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
All the spot weld areas have to be grinded. |
Posted: Sun Oct 08, 2017 3:00 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
rmh60bug Samba Member
Joined: October 02, 2015 Posts: 124 Location: Northwest PA
Posted: Sun Oct 08, 2017 4:08 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
This is awesome to see. The work you put into this build is phenomenal. Always look forward to new pics ! _________________ 1960 Volksrod in progress
Engine… depends on the day !
6"chop, 5" drop, 10" ext
Slow & Steady is the key |
finefettle Samba Member
Joined: October 13, 2006 Posts: 699 Location: Shelburne,Vermont
Posted: Mon Oct 09, 2017 7:08 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Best thread on Samba.
Thanks for the updates.
When I grow up, I want to be half as good as you. _________________ 1979 Bug project |
Posted: Tue Oct 10, 2017 7:29 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Thanks y'all. If CB would donate an engine kit, we'd be set.
Now just few hundred more spot welds and couple a dozen more warp control clamps and weights. |
Posted: Sat Oct 14, 2017 9:17 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Posted: Sun Oct 15, 2017 3:34 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Posted: Mon Oct 30, 2017 12:30 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Final welding done on frame top. Will flip over and do all final front end welds on bottom. Then Rotissori for pans.
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Wed Nov 01, 2017 7:56 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
How does your pedal assembly/foot space work out with the front frame brace?
or have you got something else in the works for that?
very cool build _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Thu Nov 02, 2017 7:04 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Thanks. The foot and leg room seems to be okay. |
Posted: Tue Nov 07, 2017 10:28 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Posted: Tue Nov 07, 2017 12:04 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Posted: Tue Nov 07, 2017 3:32 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
This Bug is going to be AWSOME ! Makes me get out and work on mine _________________ 1960 Volksrod in progress
Posted: Tue Nov 07, 2017 4:37 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Thanks man. It's getting to the point where you can slide your hands all along the chassis and not get cut. |
Posted: Fri Nov 10, 2017 11:06 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Finishing the front panhard mounts.
Posted: Mon Nov 20, 2017 6:36 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Purdy😃 _________________ 1979 Bug project |
Posted: Tue Nov 21, 2017 5:47 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Thanks ∆∆
Some heater Chanel and running board area work.
Posted: Wed Nov 22, 2017 10:34 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Before and After
Posted: Sat Nov 25, 2017 7:03 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Providing good pan gasket seal all around the body, even here.
Posted: Sat Nov 25, 2017 8:01 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
