eth727 Samba Member
Joined: February 21, 2007 Posts: 542 Location: san diego
Posted: Mon Oct 16, 2017 10:43 am Post subject: '55 vert deck lid installation |
On my '55 vert there are 2 slots on the body for the big spring. I was having rubbing issues with the fan housing. Does the spring attach to the lower slot on the body or upper one. I have a later 1600 fan housing with later deck lid hinges. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Mon Oct 16, 2017 6:47 pm Post subject: Re: '55 vert deck lid installation |
If your spring is installed upside down, you have the issue you describe. Make sure it is the correct way. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
eth727 Samba Member
Posted: Mon Oct 16, 2017 8:18 pm Post subject: Re: '55 vert deck lid installation |
If It's upside down would it still prop up the deck lid? Mine is propped up. |
Keith Samba Member
Posted: Mon Oct 16, 2017 8:40 pm Post subject: Re: '55 vert deck lid installation |
Yup, been there done that. Had the same exact issue you are having. Kept rubbing the fan shroud. _________________ Formerly known in the forums as "OVALTEEN"
