Mulcheese Samba Member
Joined: September 19, 2004 Posts: 548 Location: Maple Grove, Mn
Posted: Sun Jun 05, 2005 8:30 am Post subject: steel wheels |
When I had a blow-out the other week the bead of the rim bent. I am going to see if it is able to be bent back but if not and I need one from a junk yard what do I need to look for?
I know the rim is 5.5 x 14 but are the vanagon rims any different that any other 14 in. vw rims? Do I need to ask for a specific offset? Am I able to just ask for 14in. vw rim and be done? _________________ 82 Westy: Air is cool! |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Sun Jun 05, 2005 8:40 am Post subject: |
Tap it back with a hammer, just the lip is bent right, the steel wheels will take more abuse than alloys. If it looks bent but stilll holds air, use it for your spare, another advantage to having a full size spare. _________________ My Art:
http://www.instagram.com/flynn8552/ |
DanJReed Samba Member
Joined: July 30, 2004 Posts: 548 Location: Riverton NJ
Posted: Sun Jun 05, 2005 11:38 am Post subject: |
Funny. Once I bent the crap out of my Mom's steel wheel on her 88 Golf while useing an older style tire changer (that was a peice of $h!+). Anyhow when I was breaking the bead, I folded, I mean, folded one side of the rim over. I was just a lad then..
In a panic, I flipped the rim over, and bent it back the other way.
Ask me how to pound out dents in a Golf alloy rim with a dead-blow hammer. I was the king of doing that. _________________ -Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport) |
mjamgb Samba Member
Joined: September 13, 2004 Posts: 231 Location: Carson City, Nevada
Posted: Mon Jun 06, 2005 4:22 pm Post subject: |
The VW type II rim is nearly unique. The only other rig to use the 5 on 112mm pattern was Mercedes and they had a 12mm stud rather than our 14mm stud. Oh, a couple models of Audi and one year of Corrado and a few other odd-ball cars but we are pretty unique.
The Mercedes rim will fit if you need to, just use a 9/16" bit in the bolt holes. Better to get a van rim, however, as they are hub-centric (and it matters... I need to get adaptors!).
Mike! |
mr_vanagon Samba Member
Joined: March 31, 2005 Posts: 589 Location: Southern Illinois (GO SALUKIS)
Posted: Mon Jun 06, 2005 5:35 pm Post subject: steel wheels |
I know that the wheels from my old '76 Bay window bus are the same as the wheels on my '89 Vanagon. The only difference is the color. Might be a bit easier to find a wheel on a Bay than on a Vanagon. |
Posted: Tue Jun 07, 2005 7:44 am Post subject: |
Thanks for the reply. I did just bend it back and it is still holding air. _________________ 82 Westy: Air is cool! |
mjamgb Samba Member
Posted: Tue Jun 07, 2005 3:23 pm Post subject: |
Yes, basically the same wheel late '71 to '90. Dunno about the Eurovans.
Some 16" and 15" units are out there but they are pretty scarce (fastforward.ca has them, whoof, I'll just go to Pick-yer-part!).
Mike! |
