Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sat Oct 14, 2017 7:29 am Post subject: Re: Ride-On goes Subaru power |
that won't change anything. the selector shaft is where it is and there isn't much I can do about it. I sure as hell am not going to trim the selector shaft either. all in all it *should* be ok, but I will have to see once I get the engine plugged in, level etc. only then can I make a decision.
it's kind of sad that Subarugears doesn't make more bits and pieces for the install end of things. they seem to cater more to the beetle/buggy crowd. I have to wonder how much shifter rattle there will be by having a solid connection between everything. this would still be the case if you use the super beetle steering joint. I am going to suspect there will be some noise transmitted into the shifter. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sat Oct 14, 2017 8:26 am Post subject: Re: Ride-On goes Subaru power |
While not ideal for CV angles, what about tilting the engine/trans assembly 2*-3* to raise the selector shaft?
Or, instead of cutting away at the torsion housing, how about slightly denting (or crushing) it where the shifter rides above it? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Oct 14, 2017 9:00 am Post subject: Re: Ride-On goes Subaru power |
TDCTDI wrote: |
Or, instead of cutting away at the torsion housing, how about slightly denting (or crushing) it where the shifter rides above it? |
I have plenty of clearance above it, just not below it. as it is, the transmission sits back, so to your point the CV angle is already compromised. I really don't want to add to that. I may just kiss the torsion housing with a deburring bit to add a hair more space. this is a lot more problem solving than the re-geared 4 speed for sure. I am just hoping the result is acceptable. I am also hoping that I won't have any shifter chatter due to the solid arrangement of the coupler. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Oct 14, 2017 9:09 am Post subject: Re: Ride-On goes Subaru power |
I meant the tube itself, not the metal above it. Kinda like when the impact jockeys over tighten the U-bolts holding the spring pack on a RWD axle.
Perhaps you could find a way of incorporating one of the early beetle shift couplers into the linkage.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D711%2D175%2DB _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
pkrboo Samba Member
Joined: October 09, 2009 Posts: 512 Location: Lincolnshire, UK
Posted: Sat Oct 14, 2017 12:06 pm Post subject: Re: Ride-On goes Subaru power |
captincanuck wrote: |
skills@eurocarsplus wrote: |
I am not that close to the tube and have no interference issues. Did you max out the adjustment on the front mount? If you want any photos just ask. |
mine isn't that close either _________________ 1979 Sage Green Westfalia P22 |
Posted: Sat Oct 14, 2017 2:56 pm Post subject: Re: Ride-On goes Subaru power |
yes, the front mount is installed as far as I can make it go to gain the clearance needed. I may have to dip the bell housing down a red one to get the ass of the trans up somewhat. either way...it's close _________________
Jake Raby wrote: |
Brian wrote: |
RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Sun Oct 15, 2017 8:14 am Post subject: Re: Ride-On goes Subaru power |
Out of the two I have worked on, one was fine out of the box and the other did hit the torsion bar. We corrected this by adding a washer inbetween the trans “ears” and the subarugears mount. This rotated the mount a bit raising the shift selector a few millimeters. _________________ 69 Westy |
Posted: Sun Oct 15, 2017 6:41 pm Post subject: Re: Ride-On goes Subaru power |
RocketSurgeon wrote: |
Out of the two I have worked on, one was fine out of the box and the other did hit the torsion bar. We corrected this by adding a washer inbetween the trans “ears” and the subarugears mount. This rotated the mount a bit raising the shift selector a few millimeters. |
interesting....I will have to see if that is a work around. I will know better once I get the engine mated/level if I will have to do that.
dear Wolfsburg west, that you for providing us with the finest chinesium filler neck, made from the finest chi-titanium ingredients you could harvest.
and folks, this is why I want to cut an access panel to the filler neck. as luck would have it, a friend of mine that I sold a parts bus to still had it, so I harvested a bunch of stuff I needed
now I have that odd shaped kick out in the luggage area to make a removable plate to access the filler. I mean, lets face it this is a huge problem, and now that this stupid thing is part of a seasonal pre-flight check, it's foolish to NOT make it easily accessible. sad how far down the shitter the quality parts have become....
took to getting the shift rod all dialed in. this was a first for me. the snap ring on the front bushing almost wore thru the rod
taking the calipers to it, I estimate it was 2/3 of the way into making a hole. that would have sucked, so it got welded up and ground down
all greased up, new bushings and ready to roll
another thing was removing the belly heater. THAT was a PITA. they were very proud of that, and I swear that workers at VW were paid by the weld...
if you notice in my above harvested sheet metal photo, I grabbed this area as well. that hole is way to big to put the ECU loom thru, so I will make a plate to cover that giant oval and re-drill as needed.
that belly heater was something else to remove...I mean ho-lee-cow the welds they used on the pipes....I think they could have been used as tie downs for transport thankfully, I have a few more bits to remove, as the bulk of it has been done. I will be happy to end the shower of sparks going down the crack of my ass.
this one has required a LOT of extra prep work, mainly due to the 5 speed, but that belly heater REALLY threw a wrench in things. trying to think into the future and make cuts that make sense is kind of a hard thing to do, but I just don't want to go in there all junkyard style either.
one of these days I can start the actual swap _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Oct 20, 2017 8:01 pm Post subject: Re: Ride-On goes Subaru power |
well, time for an update
got the BA6 belly heater out of there. (it's up for grabs if anyone is interested) and started mapping out a plan for the install. seeing this is my first 5 speed conversion, all of my "off the shelf" templates were useless. but, there was a lot of other things that needed to be changed anyways.
got to making the carrier
and welded my heart out
tacked up and ready to make the end plates. the Subaru 5 pushes everything back, so this wasn't in my box-o-templates.
almost done. need to make some gussets and weld those in as well
I had to surgically remove about 1/4" thick undercoating to actually mount the bar
but, it's in (temporarily)
I have to say, having a lift and a transmission jack makes the work less back breaking. in the end, I leveled the bus and made adjustments until I was happy.
getting the engine/trans level and centered was a bit of a chore. this is simply one of those things you just can't 'eyeball' and hope for the best. the goofy shape of the late bay engine bays isn't symmetrical so you just can't do it that way. I ended up measuring from the axle flanges to center all of it.
my exhaust system was tight to say the least. now with the engine shoved back, it is just going to get even tighter....
you may see in one of the photos the harness connector. I laid out the harness, because again the whole business is shoved back more than that of a 4 speed.
I am kind of glad the carrier is almost done. it is quite a lot of work to make them, test fit and weld, especially when you have a bunch of loose pieces. I wanted to make dam sure the engine/trans was centered before I welded on the end caps. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Oct 22, 2017 6:18 pm Post subject: Re: Ride-On goes Subaru power |
last test fit
look ma, no straps the reason for all of the in/out,in/out,in/out was to make sure everything was going to work. here's to hoping I didn't miss anything.
also got the fuel filler access panel all done
not sure why the supports look funny in the photo. it is on a odd angle, but trust me, they're straight
the gaps look big, but are only a fine saw blade thick. I 100% hated to do this, but the aftermarket forced me to. I just can't see the replacement ones lasting more than a year or so. they are so friggen cheesy. this will make replacement on the road a 2 second job....because he will keep on in the bus at all times...
also set the manifold on there so I can get an idea of where lines will need to run.
it is pretty much all laid out now. I have to clean up some cuts, but beyond that it's time to clean and paint the engine bay. we aren't going to paint the whole bay, just treat and touch up here and there.
overall, it is in good shape. there is this nasty poopy goopy hateful stuff in there that I will clean up and touch up as needed. the initial power wash took care of quite a lot of it, but man, I would need a pressure washer full of lacquer thinner to get this crud off.
after I get the engine bay all set, it's final assembly, wiring, build the exhaust etc... _________________
Jake Raby wrote: |
Brian wrote: |
plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Sun Oct 22, 2017 7:24 pm Post subject: Re: Ride-On goes Subaru power |
Look'in good Skills. Lots of mock up on this one aye?
I just picked up a water boxer Subi swap job this weekend. Guy is going to purchase everything from a company in Phoenix that buys up the low mileage engines out of Japan. Good reputable business for the last 25 years or so, deal mainly with the sand and buggy crowds. I get to install it all and make it run. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Posted: Sun Oct 22, 2017 7:53 pm Post subject: Re: Ride-On goes Subaru power |
thanks!
yes, the 5 speed was way more than I expected in terms of what had to be done.
the time spent was staggering, BUT those who know me and how I work, I don't go for the "git-r-done" approach. I have learned quite a lot from this. I have been doing my best to kind of split some time with ride-on in terms of the fabrication. I just don't think I have it in me to bill him for every hour.
then there were surprises around every corner....the crushed tank being one of them. original rubber brake hoses were another. as I have said in the past, no one has brought me a perfect bus, and that isn't a dig on the bus owner at all....it's just the truth. Daveark's bus was the same deal...bad ball joints, old brake hoses etc etc etc....we are putting a LOT of power into these, so EVERYTHING need to be fresh...by no way is it a money grab, it's a safety thing.
I have had to work a bit backwards in some areas, like the mock up. typically I have the engine in and out 1-3 times with a swap. this one has been in and out around 7....transmission roughly 10 times. I don't mind though....I am working with a great guy.
one word of advice I would give you...if you are doing a swap for anyone...screen them, and screen them hard. if you have 1 doubt the guy is an asshole, pass on the job...you don't need the money that bad, or the aggravation that comes with it. I have been screening people who want the swap. I'm not being arrogant but trust me when I tell you that having the right person makes these swaps fun. it's like a marriage....shit WILL go sideways on all of these conversions....I have done enough to know this. it's how both parties handle it that matters.
the absolute worse part is you don't know what you're getting into until you dive in. there is stuff that is impossible to see until you dive in. _________________
Jake Raby wrote: |
Brian wrote: |
wcfvw69 Samba Purist
Posted: Sun Oct 22, 2017 7:55 pm Post subject: Re: Ride-On goes Subaru power |
Looks great so far. I can't remember and I'm too lazy to go back and look. It's getting a 5 speed suby trans too?
If so, that will be a fun bus to drive. Question Don- are these Subaru conversions quieter inside the cab vs. the original stock VW engines with stock mufflers? _________________ Contact me at [email protected]
The Samba member since 2004.
Xevin Samba Member
Posted: Sun Oct 22, 2017 8:09 pm Post subject: Re: Ride-On goes Subaru power |
Nice job skills. Can you find my previous owner, rip the can opener from him, and punch him in the throat. Thanks. You the best
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
SGKent wrote: |
Ride_On Samba Member
Joined: August 27, 2015 Posts: 385 Location: Ottawa, Canada
Posted: Sun Oct 22, 2017 9:39 pm Post subject: Re: Ride-On goes Subaru power |
Xevin, you sure about the can opener? Looks a bit like the outline of an anvil dropped from 20ft? 😀
Awesome work Skills! The fun parts are underway...
I had a ride in Skills Deluxe and, yes, definitely quieter than our 77 Westy. His has the same muffler and similar sound deadening, but ours has the Westy interior, so should be even a little quieter still? Wait a minute... Skills... you said the kids wouldn't be able to hear us talk! That could be a downside... (we have to yell back now, so very much looking forward to a somewhat more peaceful ride.
And yes, Subarugears 5sp. Figured if we are going to go, we better do the full deal.
And supporting what Skills said about interviewing your swapee, from the owner perspective, we had the same thought - very much a must to know who will be doing the work, how they work and communicate, and ultimately see if you could work with them if and when the fan gets stinky. It's an old vehicle, shits gonna fly at some point 💩💥☔️ _________________ 1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG) |
Posted: Mon Oct 23, 2017 4:46 am Post subject: Re: Ride-On goes Subaru power |
Hey Bill! As ride-on pointed out, yes...scary quiet. Don't forget, we are turning about 3k at 70...not 3800/4k like the air cooled mill spins. That right there is an iimprovement alone.
Add the sound dampning and its real nice. I am sure the camper mattress will only help kill more noise. Honestly, they are a treat to drive when you don't have a fan spooled up to make air flow over the engine. Ride-on has been fantastic to work with when the shit did hit the fan. Pretty sure there is no more fan hitting shit in store for us at this point _________________
Jake Raby wrote: |
Brian wrote: |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon Oct 23, 2017 6:39 am Post subject: Re: Ride-On goes Subaru power |
Xevin wrote: |
babysnakes wrote: |
Xevin, is that plain or buttered? |
Hot Butter
(I think Skills will be whistling this as he works)
how do you find this gold!
youtube showed this one next..
_________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Mon Oct 23, 2017 8:44 am Post subject: Re: Ride-On goes Subaru power |
can a seal for the trap door be added? Even like a thin vacuum hose cut down the middle and pushed onto the panel edge, sort of like the trick for bumper guard seals? Theoretically there shouldn't be a problem but I would worry about fumes in the cabin if a hose cracked or something... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Mon Oct 23, 2017 1:34 pm Post subject: Re: Ride-On goes Subaru power |
Quote: |
I have to say, having a lift and a transmission jack makes the work less back breaking. |
You suck skills. Real men can wrestle in an M56 single handed in the driveway
(Now that you saved my a$$ I can insult you again..)
all in love..
_________________ .ssS! |
