mark d Samba Member
Joined: February 06, 2013 Posts: 219 Location: Costa Rica
Posted: Sat Oct 21, 2017 8:29 am Post subject: hella battery isolator relay help |
note: checked search first and did not see any answers to these specific questions. probably there somewhere.
question 1. what the hell is that little blue thing in the foreground of the first photo ?
question 2. in photo 2 the black wire #86 on the diagram is the trigger wire to the alternator circuit. can i just run it to the output terminal on the alternator and call it good ?
thks,
_________________ 1972ish westfalia
"what good are tractors without violins ?" jose figueres |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Oct 21, 2017 8:37 am Post subject: Re: hella battery isolator relay help |
#1 is a Scotchlock connector, it's for tapping into a wire, not the best way to do it long term, but quick and convenient.
#2 taps into the blue wire on the regulator (charge light circuit), likely what that blue gizmo is for. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mark d Samba Member
Posted: Sat Oct 21, 2017 3:13 pm Post subject: Re: hella battery isolator relay help |
busdaddy, thks for the help _________________ 1972ish westfalia
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sat Oct 21, 2017 4:10 pm Post subject: Re: hella battery isolator relay help |
Busdaddy was too nice.
That first thing is a piece of crap that should be beaten to death with a hammer and fed to the guy who invented it.
They have no current handling capacity, and generally damage any wire to which they are attached. I've seen more damaged wiring harnesses from using these things than I ever want to remember.
Use them at your own peril.... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
mark d Samba Member
Posted: Sat Oct 21, 2017 6:35 pm Post subject: Re: hella battery isolator relay help |
oh jeez, now you tell me...i remember your name from one of my searches on this subject, but could not remember the exact thread. went back and tried to find but, the adult beverage ship has sailed
unrelated question or partially related, how best/necessary to ground the new auxillary battery ? _________________ 1972ish westfalia
Posted: Sat Oct 21, 2017 6:45 pm Post subject: Re: hella battery isolator relay help |
The ground has to be big enough to handle all the systems connected to it combined, a premade cable from the FLAPS is the best choice, you may not be cranking with it but better to go on the heavy side just because you can. Any bit of permanent body sheet metal will do to attach it, sand the paint off both sides of the hole you drill and grease up all the washers and hardware you use to attach it.
As Telford says those Scotchloks are rather savage, cutting the wire and reconnecting it with a butt connector with 2 wires in one end is the better choice, some grease in the butt connector and shrink wrap over the whole deal afterwards is even better. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mark d Samba Member
Posted: Sun Oct 22, 2017 2:43 am Post subject: Re: hella battery isolator relay help |
will do on all of the above, thks _________________ 1972ish westfalia
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Sun Oct 22, 2017 5:04 am Post subject: Re: hella battery isolator relay help |
telford dorr wrote: |
Use them at your own peril.... |
I disagree that they should be given orally, alternative orfices should be utilized _________________ .ssS! |
mark d Samba Member
Posted: Sun Oct 22, 2017 7:29 am Post subject: Re: hella battery isolator relay help |
i believe my alternator has an internal regulator. when i remove the small red wire on my alternator the dash alternator light goes off. so i'm thinking that's the wire i need to tap #86 (trigger wire from alt circuit) into, but want to check with the experts before i create a smoking crater....thks
Posted: Sun Oct 22, 2017 7:52 am Post subject: Re: hella battery isolator relay help |
Yes, that's the one, but why is it red/black?, does that splice into the blue near the firewall? If it does find the joint and make sure it's well done (hint: that crappy blue jacketed crimp on the alternator end is not well done). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mark d Samba Member
Posted: Sun Oct 22, 2017 8:07 am Post subject: Re: hella battery isolator relay help |
yep it looks even crappier in person. will redo connection and find the connection to the blue wire and redo as well.
many thks for the help _________________ 1972ish westfalia
mark d Samba Member
Posted: Tue Oct 24, 2017 4:43 pm Post subject: Re: hella battery isolator relay help |
all done. works perfect. many thks to those that replied. _________________ 1972ish westfalia
