Installing a wood headliner?
Page: Previous  1, 2, 3, 4
LAGrunthaner
LAGrunthaner is offline
PostPosted: Tue Oct 11, 2016 1:47 am    Post subject: Re: Installing a wood headliner? Reply with quote
Oh now I get it. I also located the material via Everett's reply on this post. I'll take a peek and check out the condition. Thanks for the new vocabulary work also Clara. "directional flaps" and yes bar soap 2x4 rubber mallet and push up to give the board the curved bend.
http://www.thesamba.com/vw/forum/viewtopic.php?t=266265&highlight=directional+flaps
Clara wrote:
LAGrunthaner wrote:
Clara what does this mean? Do I remove one of the screws? "do the fresh air directional flaps before, as the upper screw will be hidden after the panel is in place."
I'll try soap now.
It means if you are going to install new directional flaps in the fresh air box, do that before installing the cab roof panels.
After the cab roof panels are in, you won't be able to get to the upper screws, so that window of opportunity will be closed.
Don't remove the upper screw and leave it out.
If your fresh air flaps are fine, ignore the above and just put the cab roof panels in.
Like someone else said, install the cab roof panels before the wood ones behind.
Might be good to put soap on both long sides of the panel, the flat side and the curved side, come to think of it.
American Red Cross Safe And Well link:
https://safeandwell.communityos.org/cms/index.php?...OSmeUzh8l4
Maui Roadsters VW Logo
www.mauiroadsters.com
Lind wrote:
LAGrunthaner
PostPosted: Tue Oct 11, 2016 1:54 am    Post subject: Re: Installing a wood headliner? Reply with quote
and this complete thread with images of the vent.
http://www.thesamba.com/vw/forum/viewtopic.php?t=102071&postdays=0&postorder=asc&start=0
Lind wrote:
davebryant73
davebryant73 is offline
PostPosted: Tue Mar 07, 2017 1:42 pm    Post subject: Re: Wood headliner - birch wood but what color stain for 1971? Reply with quote
What color stain do you use on the birch wood headliner for a 1971 T2 camper?
mandraks
mandraks is offline
PostPosted: Tue Mar 07, 2017 1:48 pm    Post subject: Re: Installing a wood headliner? Reply with quote
westy orange, gives it some pizzazz! Wink
regards
Uli
StockNazi
StockNazi is offline
PostPosted: Tue Mar 07, 2017 5:06 pm    Post subject: Re: Wood headliner - birch wood but what color stain for 1971? Reply with quote
The original headliner was not stained; most likely Westfalia used a lacquer or shellac brushed on with the headliner in place.
WANTED:
Westfalia privy tent poles(silver painted / pre-59)
58 Westfalia roof rack and cabinet knobs
DYNOARNO
DYNOARNO is offline
PostPosted: Tue Oct 24, 2017 2:12 am    Post subject: Re: Installing a wood headliner? Reply with quote
Hi everybody, does someone can give us the size of the 2 panels in the cab?
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Oct 24, 2017 2:09 pm    Post subject: Re: Installing a wood headliner? Reply with quote
Not really. First have no idea of the year of your bus.
Plus those panels are not just a simple rectangle. What you should do is find someone that will trace out each onto paper. Use those templates so you can mark and cut out your own.
Do keep in mind that 1955 till sometime in 1961, and later 1961 thru 1967 are different panels.
In Stereo, Where Available!
easy e
easy e is offline
PostPosted: Tue Oct 24, 2017 2:10 pm    Post subject: Re: Installing a wood headliner? Reply with quote
Are you looking for length & width? I don't know what those dimensions will provide you, because the panel has a curved shape.
Are you asking for a template?
If so, there is an early template and late template for the forward cab panels (adjacent to the fresh air box).
You will need to tell the year of your bus.
aka: Evan
DYNOARNO
DYNOARNO is offline
PostPosted: Tue Oct 24, 2017 11:37 pm    Post subject: Re: Installing a wood headliner? Reply with quote
My bus is a 1966 westy...
Clara Premium Member
Clara is offline
PostPosted: Wed Oct 25, 2017 7:33 am    Post subject: Re: Installing a wood headliner? Reply with quote
There are 3 versions of this panel (and variations on them)
If you want to DIY, the basic thing is about 33 x 22, but has only one straight side, next to the airbox. You can spend some time and DIY.
I make interior panels for split buses.
https://www.thesamba.com/vw/classifieds/detail.php?id=942798
sixtyonecrew
sixtyonecrew is offline
PostPosted: Wed Oct 25, 2017 7:15 pm    Post subject: Re: Installing a wood headliner? Reply with quote
I installed this wood ceiling in my 58 Standard! It was a challenge, but it turned out pretty well!
LAGrunthaner
PostPosted: Thu Oct 26, 2017 2:11 am    Post subject: Re: Installing a wood headliner? Reply with quote
sixtyonecre very tidy, how is that wood slat held up? Love your 58 what was the original color?
Lind wrote:
DYNOARNO
DYNOARNO is offline
PostPosted: Thu Oct 26, 2017 5:30 am    Post subject: Re: Installing a wood headliner? Reply with quote
Thanks Clara,
I know you make panels for slpits buses, but I'm in France, and affraid of the shipping cost....
dgsaz
dgsaz is offline
PostPosted: Thu Oct 26, 2017 2:14 pm    Post subject: Re: Installing a wood headliner? Reply with quote
Here are a couple photos of the ceiling in my bus. I reproduced the ceiling from the original design. Very simple. This is a 1966 Sundial Camper.
Cut a 4 x 8 sheet of 1/8" plywood or ??? into 2 pieces 2' x 8'. These will fit from the outside edges to the almost center. A ripper of about 10" or so goes into other center gap between the two large panels.
From there you run batts over the exposed seams and you're done. I used the 1/4" x 1 1/2" oak "hobby boards" from the Home Depot to make the batts. I used stainless steel screws and finish washers for a nautical look.
The entire interior was pretty beat up and I used the old cabinets for templates and reproduced the camper interior. If you are simply looking to build a headliner this method works well. It is NOT a Westfalia ceiling. As you were.
dgsaz
EeVeeWee
EeVeeWee is offline
PostPosted: Fri Oct 27, 2017 1:52 pm    Post subject: Re: Installing a wood headliner? Reply with quote
DYNOARNO wrote:
Thanks Clara,
This guy sells them in the Netherlands:
https://www.facebook.com/rickysbuspanels/
Gallery of 1967 panel becomes 11 window camper with Dormobile roof
avocado_tom
avocado_tom is offline
PostPosted: Fri Aug 17, 2018 7:19 am    Post subject: Re: Installing a wood headliner? Reply with quote
That's really nicely done.
avocado_tom
PostPosted: Fri Aug 17, 2018 7:21 am    Post subject: Reply with quote
marklaken wrote:
here are couple more pics for DIYers:
this last picture shows the thin wood that runs in the side channels to help support the headliner
Are these the OG bows or did you make them?
(trying to figure out best way to make them myself - they're two pieces, right?)
Page 4 of 4
