'58/'59 Beetle Discussion
Page: Previous  1, 2, 3 ... 126, 127, 128 ... 146, 147, 148  Next
62ItalianRagtop
62ItalianRagtop is offline
PostPosted: Sat Jul 22, 2017 6:11 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Anyone can post a some pictures of rear fenders lights holes please ?
LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/
lil_azza
lil_azza is offline
PostPosted: Fri Aug 11, 2017 1:51 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Hi I have read most of the pages 😁 Would a uk 58 standard have windscreen washers?
And I also read somewhere that the 58 doesn't have high beam?
And interior light ?
Thanks
Erik G
Erik G is offline
PostPosted: Fri Aug 11, 2017 2:02 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
yes high beams, actuated by a foot switch. and yes to the interior light. It will not go on automatically with the doors opened on a standard, only deluxes has the pin switch
no on windshield washer
hope this helps
lil_azza
lil_azza is offline
PostPosted: Fri Aug 11, 2017 2:43 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Yes that helps thank you very much
raycer60
raycer60 is offline
PostPosted: Fri Aug 25, 2017 9:34 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
On 350 - They most likely included everything possible for 350, including options that only came on later Beetles.
They do this fairly often and it's confusing for earlier cars.
Yep. When my 59's BC came in saying it had the US350 as explained, I was surprised but realized it could not be.
I did ad the dual master cylinder just to make it a step closer to the BC and a little bit safer to drive. I really just wanted to know what the original color was so I can spray it original. Also found out that my 36hp is original to the car. Hope that is true!
59 De Luxe Sedan with grafted ragtop
EVfun
EVfun is offline
PostPosted: Sun Aug 27, 2017 11:19 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Perhaps this is not the best place to ask this but if this group of experts doesn't know I don't know who would.
Why is the rear track width of the '58 and '59 1250mm while the '60 to '65 is 1288mm? I thought these all used the same brakes and wheels with axles and tubes that where same length. That is a 38mm jump in track width, not as big of a change as the long axles in '67, but only 20mm less.
Wildthings wrote:
Matthew Tolbert
Matthew Tolbert is offline
PostPosted: Sun Aug 27, 2017 11:40 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
I'm not 100% sure but I think the rear brakes were widened somewhere in that time frame.
Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S
hsosa1
hsosa1 is offline
PostPosted: Sun Aug 27, 2017 11:42 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Anyone know what the correct fuse block for a 59 was 8 terminal with screw ?
Just Cruzin Sur Califas VW Car Club est♤1998
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
EVfun
EVfun is offline
PostPosted: Sun Aug 27, 2017 3:00 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
The rear brakes where 30mm wide until '68. Sourcing reacement parts show the wheel cylinders and brake shoes as the same from early '58 through '64, and the drums even longer through '65.
Wildthings wrote:
graybum
graybum is offline
PostPosted: Mon Oct 16, 2017 12:41 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Hi everyone!
Does anyone here know where I might be able to source a replacement sunroof cover for a '59 Garnet Red Ragtop?
I contacted Wolfsburg West who said they had nothing to match the original, and suggested I try Lenny Copp. So I sent Lenny an email a few weeks back, but as yet no reply.
Not a great picture, but the best I can find to show the colour:
Any help appreciated!
hsosa1
hsosa1 is offline
PostPosted: Mon Oct 16, 2017 6:27 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
graybum wrote:
Hi everyone!
Wow i got a garnet red too . There is no match
stale air
stale air is offline
PostPosted: Mon Oct 16, 2017 10:36 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
I dont know of anyone who repops the correct color, so here are a couple of suggestions.
You could take your existing rag, and have some sems paint/dye matched to it, and then spray the new cover.
Or you could try going to a bunch of upholstry shops and try to find some vinyl in the correct color, and then using your exsisting top as a pattern, and have one made.
graybum
graybum is offline
PostPosted: Mon Oct 16, 2017 10:43 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Thanks guys, shame that there doesn't appear to be a simple solution!
I need to make the car more weather proof in the short term, so think I'll just get another cover to put on for now, and then try to find a material or dye match that's closer to the original at some point in the future.
myvolks1
myvolks1 is offline
PostPosted: Tue Oct 17, 2017 1:39 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Wow! I also have a Garnet Red car. Would it be possible to see more pictures of your car. Is this a semaphore car?
Regards,
graybum wrote:
Hi everyone!
1959 L358 (Garnet Red)
Type-113 De Luxe Sedan
WANTED: DEET EICHEL (Modesto, CA), license plate frames and other Deet Eichel related items.
Wanted: Original VW
hsosa1
hsosa1 is offline
PostPosted: Tue Oct 17, 2017 1:48 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
I got a 59 garnet red rag too!
Regards,
graybum wrote:
Hi everyone!
myvolks1
myvolks1 is offline
PostPosted: Tue Oct 17, 2017 1:50 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
hsosa1,
Can you post some photos of your Garnet Red car?
Regards,
hsosa1 wrote:
graybum wrote:
Hi everyone!
Wanted: Original VW
57 Zwitter?
57 Zwitter? is offline
PostPosted: Thu Oct 26, 2017 6:26 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
I just started working on a 58 Vert I bought from a neighbor in 2001. It was parked in his garage since 1970 until a snow storm caused the garage roof to collapse. Luckily the bug only got a dent on the cowl by one of the wipers. It was originally a black car and the interior seems to be red and gray when you look at the door panels, however it has gray seats??? It this correct? This is a car that has been in this family since 1960 or so and it all original. But the red on the correct star pattern door panels puzzles me. Any thoughts?
my59
my59 is online now
PostPosted: Fri Nov 03, 2017 3:05 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Dealer may have mixed and matched. Look at the Wolfsburg west color charts for 58/59. Standards had grey seats in 58.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
iamdonquixote
iamdonquixote is offline
PostPosted: Thu Nov 09, 2017 7:37 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
question:
will a stewart warner gas heater for a 61-64' bug work on 58'-59' ? Anyone have pictures of various gas heater installs on their 58-59?
thanks
Darrin900
Darrin900 is offline
PostPosted: Wed Nov 15, 2017 9:01 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Looking for wheel colors for a 1958 Capri blue beetle. Ww says L82 silver white and L336 deep blue. Does that sound right? I’ve read L87 pearl white also. Also any help on formulas for those colors would be great thank you
Page 127 of 148
