bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Wed Nov 01, 2017 9:06 am Post subject: What's up with speedo cables? |
I ordered some parts today from WW and KGPR. The KGPR order included a speedo cable for my 65 KG. When I called them I was told that those speedometer cables (perhaps for my MY) are no longer avail with KGPR and haven't been for a while. So, had to take it off the order. I have to say that I'm surprised that something as basic and essential as a speedo cable (or an alternative) is not available at a place that specializes in KG parts.
Next I called WW. Took a chance and asked about the Ghia cable. His first response (I didn't catch his name) was to ask KGPR. When I told him about my call there, he said "I'm sure we can find something for you" -- then looked up the length of the cable in the Ghia parts book (roughly 46") and found a close match from a RHD beetle (47"). That was great service!!
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Wed Nov 01, 2017 10:24 am Post subject: Re: What's up with speedo cables? |
The speedometer cables for ghias are shared with beetles, as evidenced by their beetle part number prefix, 111. They aren't ghia specific. _________________ 1966 Karmann-Ghia convertible |
bnam Samba Member
Posted: Wed Nov 01, 2017 3:41 pm Post subject: Re: What's up with speedo cables? |
141-957-801C -- thru '66. Then a 111 part 67-72 and then again a 141 part from then on. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
HerbieDave Samba Member
Posted: Thu Nov 02, 2017 10:53 am Post subject: Re: What's up with speedo cables? |
The problem is whoever is currently making them is not making the ends that go into the speedometer correct. It's a little big. It may fit in 1/2 way if you force it in, but you'll never get it back out!
The only difference between the earlier speedo cable and the 72-74 cable is that up to 71 ghias the cable has a screw on connector to the back of the speedo, the 72-74 ghia's have a twist on connector. |
bellhp Samba Member
Joined: October 30, 2017 Posts: 14 Location: Ponchatoula , La
Posted: Thu Nov 02, 2017 11:10 am Post subject: Re: What's up with speedo cables? |
Good to know , I'm assuming the connector on the 72-74 was plastic ? I thought it strange that my car (74) was missing the connector ...I couldn't figure out how it would have come off. But today I noticed that KGPR sells just the spring and connector so I bought one ... even though it was 25 bucks ( twice the cost of a cable from some other sellers) . If quality is off on replacement cables maybe that was the right call. |
Posted: Thu Nov 02, 2017 11:15 am Post subject: Re: What's up with speedo cables? |
You can "try" to file down the part that goes into the gauge, but it is a pain since it's basically in a cup. |
