dustymojave Samba Member
Posted: Thu Nov 02, 2017 5:02 pm Post subject: Re: Carb staying on high RPM after accelerating. |
Most every modern factory fuel injection throttle body comes equipped with 2 return springs on the throttle shaft. No matter what country they come from.
Stock dual springs are acceptable for Off Road race Tech.
The setup in the photo above would pass in terms of having dual springs. But if I found that on a race car, I would tell the racer to fix the interference before I would accept it for race.
If the old roll pin is made of brass, it can be drilled out. If the old roll pin is steel. it might be difficult to drill out without making a mess of that part of the carb body. I had a carb years ago that the roll pin wobbled a while before it fell out. It left a big hole. So I drilled it a little larger even, then used a larger roll pin with a little rat tile file work in the slot in the fast idle cam so the cam would come back to the proper point. _________________ Richard
SoCalBajas Member
Bub II Samba Member
Joined: October 13, 2010 Posts: 10 Location: Hoosier State
Posted: Fri Nov 03, 2017 9:53 am Post subject: Re: Carb staying on high RPM after accelerating. |
Ok, I figured out my choke element is ok. It was either assembled incorrectly, was adjusted incorrectly or it shifted after it was initially set?
I’ve set it temporarily and will further fine tune it as I get time.
I think the old Roll pin is broken off, so I will hope it is brass so I can drill it out.
Seems like a brass Roll pin is a lose/win situation, lose because it breaks, win because it might be possible to drill it out. Is there a reason a steel Roll pin wouldn’t be a better option?
Thanks for the info! _________________ Enjoying life one day at a time. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Fri Nov 03, 2017 10:07 am Post subject: Re: Carb staying on high RPM after accelerating. |
Bub II wrote: |
Thanks for the info! |
There is no pressure on the roll pin. It just acts as a stop, so brass would be fine. I have never seen one of those broken off before, so just make life easier on yourself and dont over engineer it. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Bub II Samba Member
Posted: Fri Nov 03, 2017 10:25 am Post subject: Re: Carb staying on high RPM after accelerating. |
I thought it was odd that mine was broke or missing.
When I did a general search for replacing carb choke Roll pin - the first YouTube video that popped up was about replacing a missing carb choke Roll pin. 😂
Where is the best place to buy a brass Roll pin if I’m able to drill mine out?
Thanks. _________________ Enjoying life one day at a time. |
Dale M. Samba Member
Posted: Fri Nov 03, 2017 10:47 am Post subject: Re: Carb staying on high RPM after accelerating. |
Not sure if brass roll pins exist, all I have ever seen are steel...
Might use a piece of brazing rod (dowel pin?) or even a "screw" in place of roll pin... After all it just keeps lever indexed..
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Fri Nov 03, 2017 10:50 am Post subject: Re: Carb staying on high RPM after accelerating. |
I do believe the roll pin is steel. I seem to remember seeing them with rust on them, but I can't remember ever removing or replacing one. Can't see any advantage to brass and it would seem to be too soft. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Mon Nov 06, 2017 2:05 pm Post subject: Re: Carb staying on high RPM after accelerating. |
I've encountered Solex carbs with steel pins and others with brass pins. The brass pins were solid rod, like 1/16" diameter. Brass pins are probably hard brass (not all brass is all that soft). _________________ Richard
SoCalBajas Member
Bub II Samba Member
Posted: Wed Jul 11, 2018 3:07 pm Post subject: Re: Carb staying on high RPM after accelerating. |
I finally got a minute to drill out the old Roll pin and replace it with a steel roll pin.
It totally fixed my original issue.
Now it starts, idles, returns to idle properly after rapid acceleration and then backing off the throttle pedal.
Thanks to all for your replies and especially the pictures.
As they say, a picture is worth a thousand words and the pics definitely helped me zero in on the problem location.
Now I need to unsnarl the wiring for the lights 😜 _________________ Enjoying life one day at a time. |
Bub II Samba Member
Posted: Wed Jul 11, 2018 3:08 pm Post subject: Re: Carb staying on high RPM after accelerating. |
