Merian Samba Member
Posted: Mon Nov 06, 2017 2:30 pm Post subject: Aux Battery Mounting under Driver's Seat |
I have one of the small house batteries that Van-Cafe sells.
I am wondering whether to mount it with the terminals facing forwards or rearwards.
Any thoughts?
it can go either way but I'm not clear on which might be safer and less likely to short out. _________________ .... |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Mon Nov 06, 2017 3:15 pm Post subject: Re: Aux Battery Mounting under Driver's Seat |
If you have swivel seats then forward. Use the welded nut on the seat base to attach a battery hold down that keeps the battery in place and the terminals away from any potential contact with the vehicle. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Merian Samba Member
Posted: Mon Nov 06, 2017 5:51 pm Post subject: Re: Aux Battery Mounting under Driver's Seat |
Yes, my Westy has swivel seats - but why forward?
if forward, the seat might back over them
ir rearward, they are closer to the hinged (low) end of the top plate.... _________________ .... |
Abscate Samba Member
Posted: Mon Nov 06, 2017 5:57 pm Post subject: Re: Aux Battery Mounting under Driver's Seat |
I fabbed a plastic cover for my Volvo battery that mounts under the rear deck. That might make you more comfortable with the underseat mount? _________________ .ssS! |
Posted: Mon Nov 06, 2017 7:08 pm Post subject: Re: Aux Battery Mounting under Driver's Seat |
Merian wrote: |
ir rearward, they are closer to the hinged (low) end of the top plate.... |
Here is a picture:
The bolted mount holds the battery securely and keeps the posts from touching the vehicle. You can put a non-conductive cover over the top of the battery to prevent the hinged lid from touching the positive post. _________________ 1988 Westfalia automatic Subaru OBD1
Merian Samba Member
Posted: Mon Nov 06, 2017 8:13 pm Post subject: Re: Aux Battery Mounting under Driver's Seat |
mine has recesses for the mounting tabs on both sides
I see yours only has one side with them _________________ .... |
Posted: Mon Nov 06, 2017 11:11 pm Post subject: Re: Aux Battery Mounting under Driver's Seat |
Merian wrote: |
I see yours only has one side with them |
My battery is laying on its side. _________________ 1988 Westfalia automatic Subaru OBD1
