busboyjake Samba Member
Joined: September 22, 2002 Posts: 393 Location: Colorado
Posted: Mon Nov 13, 2017 8:13 pm Post subject: Replacing late rear drums on an early bay. |
I have a '69 that someone has stuck a late front beam under (2-bolts on each side..... bad). It also has narrow 5 drums on the rear.
My plan is to replace this nonsense with a proper '69 wide 5 beam and replace the rear stuff as well so that I can run wide 5 15" wheels all around.
My question is: is it possible that I just have to swap the hub/drum out for an early 1-piece drum, or do I need to replace axles and housings and brakes and the whole 9 yards? _________________ 1965 Pearl White Caravelle Camper
1978 Dakota Beige Westy
1969 Montana Red Westy (for sale soon) |
klcarrie Samba Member
Posted: Mon Nov 13, 2017 8:26 pm Post subject: Re: Replacing late rear drums on an early bay. |
9 yards.
Rear stub axle length differs between 68, 69-70, 71...
Cannot mix and match hubs, axles and drums.
Front: 10 yards.
Seek out complete beam, drum to drum.
Would need more info as to which specific beam you have in the bus now.
if its a 71-72 beam, maybe the spindles would cross over.
If its a later beam, no dice. _________________ Pritchin'
Currently looking for:
- Bay Bus Pinion Nut Socket
- 64-67 big nut (rear) drums and brake parts, 46mm axle nuts (Big Nuts)
'55 Wolfburg Pannel Project
'55 Wolfsburg SC Project
'71 Westy |
Posted: Mon Nov 13, 2017 8:44 pm Post subject: Re: Replacing late rear drums on an early bay. |
klcarrie wrote: |
9 yards.
Front: 10 yards.
If its a later beam, no dice. |
So I'll need to find for the rear: stubs, nuts, and drums? Can I keep the brakes and backing plates? _________________ 1965 Pearl White Caravelle Camper
Posted: Mon Nov 13, 2017 8:49 pm Post subject: Re: Replacing late rear drums on an early bay. |
busboyjake wrote: |
klcarrie wrote: |
9 yards.
Front: 10 yards.
So I'll need to find for the rear: stubs, nuts, and drums? Can I keep the brakes and backing plates? |
NOPE _________________ Pritchin'
'71 Westy |
bastardbus Samba Member
Joined: July 13, 2000 Posts: 1768 Location: Toledo, Ohio
Posted: Sat Jan 20, 2018 11:28 am Post subject: Re: Replacing late rear drums on an early bay. |
I am converting a `71 to wide five drum set up. Replacing the front spindles and parts but in rear can one just replace the stub axle, and all drum components or do I need to replace the entire bearing carrier as well. _________________ Samba Member #95 |
Posted: Sat Jan 20, 2018 11:48 am Post subject: Re: Replacing late rear drums on an early bay. |
Carriers too.
AFAIK stub axle bearing seats (and corresponding bearing seats on the carriers) differ as follow:
Model Year
68 only
69-70.
71-79
Plus for 71-79 I know of the following difference:
The early early-71 carriers are threaded to receive a bolt that holds the brake slave
the late 71-79 carriers are not threaded to receive. The cylinder itself is threaded..
best would be get an assembly complete from carrier to brake drum. _________________ Pritchin'
'71 Westy |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sat Jan 20, 2018 12:25 pm Post subject: Re: Replacing late rear drums on an early bay. |
A few corrections for teh OP....
Personal decisions aside, there is no suspension difference in a disc front beam and a drum front beam. The differences are in the beam mounting holes (68-69, or 70+) and the mounting plate for the brake servo (70+.)
...So you can easily put 68-70 drums on a late beams, and even keep the torsion arms. (Shock bushing sizes changed in 70 too; another reason to keep your torsion arms.) Just like how you can put disc spindles and rotors/calipers on an early beam as long as you weld the booster/MC mounting plate on.
There will be a few other minor differences, like the steering full-lock bolts from when VW introduced radial tires to the bus around '70, but there is no reason to replace a good beam.
www.airschooled.com |
Posted: Sat Jan 20, 2018 2:04 pm Post subject: Re: Replacing late rear drums on an early bay. |
Thanks Robbie...yup I found you can just swap drum spindles onto the `71 beam. Look at the lowered spindles available they are a once size fits all for 68-79 buses so that verifies that.
As for the rear still curious as definitive answer if one can use the existing `71 bearings-hub and swap in the `70 and earlier stub, spacer then drum. The two hubs use the exact same inner bearings and seals and outer seal. That means the axles shafts are same OD. true the `71 up used a different outer bearing but from what I have seen the dimensions are the same. So seems there is a good chance that just swaping in the 68-70 axle with it's oil seal spacer and then drum would work. The only chance I see for an issue is dimensional width of the bearing housing and bearing placement inside it. Something that would need to be compared with both sets side by side. If anyone has done this let us know.
P.S. I have seen a couple various threads over the years where someone has installed later axle stub and brake set up on an EARLY bus but those are old threads and looked like hacks to me, so not holding that as sound proof. _________________ Samba Member #95 |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Jan 20, 2018 5:31 pm Post subject: Re: Replacing late rear drums on an early bay. |
bastardbus wrote: |
You need to get a life then...
Like Donald Trump said to Congress..."Flat Hubcaps Are GAY AS SH!T!"
I drive early split buses and `50 split daily in warm months . The beetle has a fully non syncro trans and cable brakes...you think I give a rats ass about power discs?! LOL!
OHHHH NO ...MY BUS STOPS LIKE A `70 instead of a `71...OMG!!! CALL THE PO-PO! |
I have been looking at differences between 1971 and 1970 rear axles. I see that the early buses have circlips holding the inner and outer bearings in the housing. I cannot tell if the stub axle bearing riding locations are at different places on the shaft due to '71 having the composite drum on a hub versus the straight early drums. Do you think the moon hubcaps on the earlier bus are to cover a longer axle than the flat hubcaps on the '71s?
Colin4WheelDrumsNoPowerAssistGoodNuff _________________ www.itinerant-air-cooled.com |
Posted: Sat Jan 20, 2018 6:47 pm Post subject: Re: Replacing late rear drums on an early bay. |
I would be curious to hear busboyjake (author of this thread) chime in on this. Apparently his `69 had later rear drum set up installed. Would be interesting to find out some details.
-did his 69 still have the original rear hubs
-was there any mods to the original bearings spacers etc in those hubs IF so.
-did the later axle and associated parts fit and work properly with early hubs. _________________ Samba Member #95 |
Posted: Wed Jan 24, 2018 5:17 pm Post subject: Re: Replacing late rear drums on an early bay. |
So I got an email from Jeff G today and he actually had a n early and late assembly on the bench in front of him and here is what he wrote (hope you don't mind me quoting you Jeff!).
Quote: |
I have both axle housings in front of me neither have bearings in yet
What you have found is the actual outside of the housing is 100% identical with the exception of the backing plate locating pin
But that’s nothing to worry about.
1. The bearing area is identical depth
2. The measurement from the inside (transmission side) snap ring to outside of the bearing housing is identical
3. The inner bearings are identical
4. The spacers b/n the bearings is identical
5. The only difference is the outer bearings
6. Spacing for backing plate is identical
From what I gather you can swap a long axle in it and just need to modify the backing plate and it will work.
Hope this helps.
Jeff |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Jan 24, 2018 5:49 pm Post subject: Re: Replacing late rear drums on an early bay. |
Good to know. I always understood that one needed to replace the entire rear brake assembly, but I never knew exactly why.
Thanks for updating us. _________________ nothing |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Thu Jan 25, 2018 7:51 am Post subject: Re: Replacing late rear drums on an early bay. |
Will you also need to replace the master cylinder?I"m thinking of different delivery rates and pressures,and are the residual pressure valves the same,[residual pressure valve thanks again Robbie]
Also will this brake change affect the proportioning valve operation? _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Thu Jan 25, 2018 3:15 pm Post subject: Re: Replacing late rear drums on an early bay. |
liljinx if you look at my earlier posts there is a thread I linked on using the power servo set up with drum brakes. Bunch-a guys did it and rave reviews.
From what I have read, yes the 68-70 MCs are basically interchangeable and yes indeed the `71 power set up has the same ID and internals of the earlier MC, only difference is the servo set up. The did state since you no longer have front discs the regulator or proportioning valve is no longer needed with the all drum set up. There are several good threads about this on the forums here. _________________ Samba Member #95 |
