lil_azza Samba Member
Joined: December 18, 2012 Posts: 249 Location: somerset
Posted: Mon Oct 23, 2017 12:56 pm Post subject: 1958 steering column outer shaft |
I need the outer shaft part for my 58
This seems to be a incredibly hard part to find, what years would work.?
Thanks |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Mon Oct 23, 2017 1:15 pm Post subject: Re: 1958 steering column outer shaft |
Yes that's correct but I'm in the uk |
Posted: Mon Oct 23, 2017 2:02 pm Post subject: Re: 1958 steering column outer shaft |
Yea inthink i will im guessing anything between 52-59 would work? |
pbenn Samba Member
Joined: November 21, 2007 Posts: 375 Location: Toronto
Posted: Tue Nov 14, 2017 3:47 pm Post subject: Re: 1958 steering column outer shaft |
There's one in classifieds,
https://www.thesamba.com/vw/classifieds/detail.php?id=2059421
Also they were Canadian Custom and Euro Standard columns up until '66, so maybe check German, Belgian, Dutch, Brit e-bays.
And try Facebook scene for folks who go to those Euro car shows and see parts.
Does your '58 wheel have 24 or 48 splines?
GLWSearch! |
Posted: Wed Nov 15, 2017 12:14 am Post subject: Re: 1958 steering column outer shaft |
Cheers a friend actually found one for me in texas and is sending it over then last week a mate found 2 beetles in hedges and the only things left were the columns so he grabbed them seem to be the correct length |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Thu Jan 24, 2019 1:42 pm Post subject: Re: 1958 steering column outer shaft |
Ok so it turns out after all that I have ended up with 2 different length outer columns
I have the 3 wire indicator switch like the oval ? And different to a mates in his 64
Not having either car local to check what would fit which one is correct? One measures 720mm and has a flared end
The other is 620mm with no flare
I'm guessing it's the larger one I need for my 58? |
Posted: Thu Jan 24, 2019 1:48 pm Post subject: Re: 1958 steering column outer shaft |
Posted: Thu Jan 24, 2019 2:15 pm Post subject: Re: 1958 steering column outer shaft |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jan 24, 2019 2:49 pm Post subject: Re: 1958 steering column outer shaft |
Do both have the carbon brush socket? _________________ In Stereo, Where Available! |
Posted: Thu Jan 24, 2019 3:06 pm Post subject: Re: 1958 steering column outer shaft |
Hi yes the longer ones does yes |
EVfun Samba Member
Posted: Thu Jan 24, 2019 3:58 pm Post subject: Re: 1958 steering column outer shaft |
You want the longer one with the brush holder. The other one looks to be a '60-'67 style. _________________
Wildthings wrote: |
