IoWesty Samba Member
Posted: Fri Nov 17, 2017 10:37 am Post subject: Re: Throttle body replacement recommendation. |
RoryGirl wrote: |
Almost every post on this page is about that unit... |
I don't think so. GoWesty used to sell their "rebuilt" throttle body (Part GW-TB-205). This is a new product (part GW-TB-DF-N).. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Fri Nov 17, 2017 10:47 am Post subject: Re: Throttle body replacement recommendation. |
IO- SlimVest first posted about the new body 9/3 on page 1, I think all the posts since then are about it. The first production run sold out, back in stock, I plan on (Finally) ordering mine this weekend. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
binger59 Samba Member
Joined: December 09, 2007 Posts: 236 Location: Oswego, NY
Posted: Fri Nov 24, 2017 7:14 am Post subject: Re: Throttle body replacement recommendation. |
So I'm planning to purchase the GW throttle this winter and I wanted to run a question by the group. I have the early Vacuum setup. Can i just put the "T" in in the system to the regulator in place of the line to the throttle body? I'm a bit timid to clip wires for the TPS but that seems pretty straight forward. See diagram i've included. Thanks for any input.
_________________ Binger
1984 Westy
1986 7 Pass R.I.P. Donor van
2019 Jetta
2014 Passat
2019 Atlas
2006 Passat R.I.P.
1998 Jetta R.I.P.
1984 Vanagon R.I.P. |
tencentlife Samba Member
Posted: Fri Nov 24, 2017 8:29 am Post subject: Re: Throttle body replacement recommendation. |
Yes, you can plumb the retard signal line according to the 2nd diagram. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
