Johnboy333 Samba Member
Posted: Fri Nov 17, 2017 7:27 pm Post subject: What kind of Electric Fuel Pump do you use? |
OK, so I am tired of replacing manual Fuel Pumps on my 70 VW Beetle, want to go to a Electric Fuel Pump, what is a good one or what does most people use, looking for one ready to use on my VW? I understand it needs to pump about 2.5 to 3.0 of pressure, is this right? Want one that is already set ready to use. Thanks in advance for your help, broke down again.javascript:emoticon('') _________________ 1968 Tan VW Beetle
1970 White Standard Beetle
1973 Blue Super Beetle |
wcfvw69 Samba Purist
Posted: Fri Nov 17, 2017 8:42 pm Post subject: Re: What kind of Electric Fuel Pump do you use? |
Johnboy333 wrote: |
OK, so I am tired of replacing manual Fuel Pumps on my 70 VW Beetle, want to go to a Electric Fuel Pump, what is a good one or what does most people use, looking for one ready to use on my VW? I understand it needs to pump about 2.5 to 3.0 of pressure, is this right? Want one that is already set ready to use. Thanks in advance for your help, broke down again.javascript:emoticon('') |
https://www.thesamba.com/vw/classifieds/detail.php?id=2117548
The original German Pierburg fuel pumps last for decades not a year or less like most of the cheap Chinese fuel pumps sold today. They also put out 3psi vs. the 5psi and up on the 'new' ones sold today. _________________ Contact me at [email protected]
The Samba member since 2004.
modok Samba Member
Posted: Fri Nov 17, 2017 9:06 pm Post subject: Re: What kind of Electric Fuel Pump do you use? |
Carter or Faucet have been VERy good in the past.
The future is always a mystery. |
windfish Samba Member
Posted: Fri Nov 17, 2017 10:28 pm Post subject: Re: What kind of Electric Fuel Pump do you use? |
I'm running a Carter, got somewhere around 20k miles on it and it's still happily humming along.
Puts out an even 3psi, no regulator required.
After bad luck with a sealed mechanical pump I picked up a Pierburg and got one of the awful rebuild kits WolfsburgWest used to sell. Worthless garbage, I was tired of dealing with mechanical pumps so I stuck in the electric and it's been trouble free.
Saw in a recent topic WolfsburgWest started making their own Pierburg kits with good results; if they'd done that a few years ago I'd be running the mechanical, but I like the electric and wont be switching back.
If you go electric there's a few different ways to wire it safely so it cuts off the pump when the engine dies.
Important in case of an accident, you don't want the electric pump continuing to pour gas onto a fire.
Easy way is to use a rabbit (iirc) fuel pump [edit: fuel pump relay], pic from the gallery -
Posted: Sat Nov 18, 2017 7:58 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
I have heard Carter is good, what model did you get, and did you use a relay inline with it? _________________ 1968 Tan VW Beetle
GjMan Samba Member
Joined: June 05, 2004 Posts: 822 Location: Grand Junction, CO
Posted: Sat Nov 18, 2017 8:53 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
Have had good experience w/the Facet. Be sure to get the lower pressure model. And mount it as close to the tank as possible.
As windfish suggested, wire it so that it cuts out when the engine stops. Holley makes an oil pressure sensor for this purpose, but there are several ways you can do this. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Sat Nov 18, 2017 9:02 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
Facet cube, Made in the USA, 2-1/2 psi, have one that is 20 plus years old and still going strong, about a third of the price of the Pierburg.
Either that Kaehler relay, a later model VW/Audi one with a built in fuse on top or a couple single pole Tyco (Bosch) relays one for crank the other for run to power the pump. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sat Nov 18, 2017 9:03 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
wcfvw69 wrote: |
Johnboy333 wrote: |
The original German Pierburg fuel pumps last for decades not a year or less like most of the cheap Chinese fuel pumps sold today. They also put out 3psi vs. the 5psi and up on the 'new' ones sold today. |
What Bill said.
Nothing wrong with a "good" mechanical pump. Less complicated, less chance of fire and they can handle 150hp. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Nov 18, 2017 9:07 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
I'm running a Carter P60504
A note that this pump pushes well, but I don't believe it'll pull fuel to it -- so it needs to be mounted below the gas tank. |
Posted: Sat Nov 18, 2017 11:08 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
Glenn wrote: |
Nothing wrong with a "good" mechanical pump. Less complicated, less chance of fire and they can handle 150hp. |
I always think why reinvent the wheel and add more complexity when it's not needed when OE quality parts are installed? It's like folks who buy an electronic module and then carry a backup distributor with points and condenser installed "in case" the module fails? I've never had a Pierburg pump or points/condenser fail on me in 35 years of driving VW's.
In the past 20 years, I've had two breakdowns with a VW that put me on the side of the road. One was a economy fuel pump that I used to test run a rebuilt engine on.
The second was this pump above in the picture. It was on a new to me bus that I hadn't changed in the first week of ownership. The rocker pin is only "peened" in place on most cheap fuel pumps. Well, the rocker/actuating arm pin walked out of the pump body and I was on the side of the freeway. Sadly, I knew this cheap pump was on the engine but hadn't replaced it with a restored Pierburg yet. Procrastination doesn't pay! _________________ Contact me at [email protected]
slalombuggy Samba Member
Posted: Sat Nov 18, 2017 11:35 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
I've run Faucet pumps with very good success, a bit noisy but if you put them on rubber isolators they are quieter. I've also installed Carter pumps in friends cars and they work very well also, but I don't like barbed fittings in my cars I use all AN fittings. Either will support anything from stock to big carbs on big engines no problem.
brad |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sat Nov 18, 2017 1:22 pm Post subject: Re: What kind of Electric Fuel Pump do you use? |
windfish wrote: |
Same Carter pump in my 68 Beetle, also mounted below the tank. Very quiet and no issues in five years of use. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Zundfolge1432 Samba Member
Posted: Sat Nov 18, 2017 5:25 pm Post subject: Re: What kind of Electric Fuel Pump do you use? |
X3 what Glenn said that Bill said . I’ve got a couple of 36hp engines running original German pumps over 60 years old, can’t swear they’ve not been rebuilt but thinking back I didn’t notice any problems with the newer replacement mechanical pumps till about 15 years. Same condition that center rod began to migrate and we had excessive pressure concerns as well.
I can understand why folks would want to install electric because just
like other inferior aftermarket parts they are left with few options. As you know the German pumps and the Brazil pumps are rebuildable but if money is tight and you aren’t worried about appearances that electric pump looks better and better. talking to a friend of mine today who rebuilds OEM steering boxes it’s same situation but it breaks down different in that the majority of his market comes from Ghia owners. Seems they are willing to spend the extra money to keep their cars original whereas type 1 folks are buying chinese parts in the mistaken belief they are saving money. I’ll just say buying those aftermarket chinese parts is going to cost more in the long run. Good luck |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Sat Nov 18, 2017 10:30 pm Post subject: Re: What kind of Electric Fuel Pump do you use? |
Mechanical pumps work great. Buy new, NOS, or rebuilt. _________________ www.vwnos.com [email protected]
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Sun Nov 19, 2017 12:17 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
I'm running a Carter in my '69, mounted below the tank with a relay. _________________ Der Kleiner Kampfwagens |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Sun Nov 19, 2017 5:30 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
Like a lot of replies why would you want to run an electric fuel pump.
The original VW pump work fine for just about ever. Original VW fuel pump overhaul kits are readiliy available so there is no excuse to use some cheap and nasty non original unit or an electrical pump.
With an electrical pump you need extra wiring and possibly a fuel pressure regulator. All this would cost more than overhauling the original pump and causing a lot of grief trying to install it. As they say its a no brainer. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sun Nov 19, 2017 7:29 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
the only time i would use an electric pump would be on injection conversions where the block had no provision for a manual pump...the little facet cube worked fine for that (think there may be low and high pressure versions, if so get the low pressure one)....those pumps push, they dont pull, so they have to be mounted under the tank...rubber mounts and a relay...but i'd still stick to manual....my 8000rpm race car used a stock pump....are you fighting a rust issue in the tank or line thats screwing up the pumps? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Nov 19, 2017 7:32 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
Loud as @#$k Holley Red mounted under the fuel tank
_________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Sun Nov 19, 2017 8:21 am Post subject: Re: What kind of Electric Fuel Pump do you use? |
volksworld wrote: |
No rust issues, new tank and good flow, just lousy reman fuel pumps. _________________ 1968 Tan VW Beetle
