MedievaL Samba Member
Joined: October 15, 2017 Posts: 9 Location: Warrior, AL
Posted: Wed Nov 15, 2017 7:30 pm Post subject: Pictures of 69 master cylinder resorvoir plumbing? |
I am replacing my fuel tank. When I pulled the old tank out I was looking at the plumbing between the master cylinder and the brake reservoir. Should there be 4 pieces of hard line and 6 soft lines in that plumbing? It doesn't look right to me.
Does anyone have a picture of theirs?
Has anyone replaced the stock reservoir with the one that goes directly on the master cylinder? I saw this while ordering parts and was considering going this route. |
xzener Samba Member
Posted: Wed Nov 15, 2017 9:55 pm Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
Found this picture.
I too am curious about a relocating the reservoir. Been wanting to bleed my recently rebuilt brakes to see how things work... But have to paint the car first. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
xzener Samba Member
xzener Samba Member
Posted: Fri Nov 17, 2017 2:54 pm Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
And.... They are out of stock. 80% of my wish list is. So frustrating with CIP1. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Fri Nov 17, 2017 3:15 pm Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
It does use the Volvo reservoir, I have one also. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Fri Nov 17, 2017 7:08 pm Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
Thanks!! Pictures of both options. Mine looks just like the top picture so I guess it is correct. It didn't look right to me. It looks a little cobbled together to me. I like the idea of the direct reservoir and I might try that. |
Bleyseng Samba Member
Posted: Sat Nov 18, 2017 7:36 am Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
But who wants to remove the tire to fill it? _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
PolarBearVW Samba Member
Posted: Sat Nov 18, 2017 8:10 am Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
I’m doing a full brake job on my 1974 over the thanksgiving break. EIS had everything in stock, even the MC with reservoir attached. Arrived a few days ago. _________________ 1974 Ghia Coupe |
Posted: Sat Nov 18, 2017 9:37 am Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
tjschmidty wrote: |
I’m doing a full brake job on my 1974 over the thanksgiving break. EIS had everything in stock, even the MC with reservoir attached. Arrived a few days ago. |
Are you using a proportioning valve, what type if you using a double master cylinder ? _________________ ----------------------
Posted: Sun Nov 19, 2017 1:00 pm Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
I don’t believe I need one with my stock setup of front disc rear drum on 1974.
My issue at present is a dragging backing plate on the driver front and I’m one more try away from just leaving it off. I also found out that is one of the places on the car that uses the rare M7 bolt. _________________ 1974 Ghia Coupe |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3413 Location: San Diego
Posted: Sun Nov 19, 2017 1:27 pm Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
I doubt the reservoir in that location will accessible at all, even with the tire off. You want be able to see if fluid is in it, nor be able to get something in there to fill it. Doesnt make sense to me |
stanthedog Samba Member
Joined: October 11, 2006 Posts: 357 Location: Portland,oregon.
Posted: Sun Nov 19, 2017 3:04 pm Post subject: Re: Pictures of 69 master cylinder resorvoir plumbing? |
What you do is run a tube from that reservoir up to a location behind the radio
where you have a second res mounted. |
