i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Sat Nov 18, 2017 9:36 pm Post subject: Re: Dead #1 cylinder |
wcfvw69 wrote: |
i_luv_my_bus76 wrote: |
SHE'S ALIVE!!!!!!
So my issue was that I had the choke all wrong...she starts and idles nicely except for a miss...
When I pull the plug wires for cylinders 1 and 2 the motor is uneffected...i changed the spark plugs and it ran and idled smoothly but shortly after 1 and 2 went dead again...
Any suggestions |
Check the carb manifold where it bolts to the head on 1/2. Sounds like a vacuum leak. |
Definitely will thanks for the suggestion |
Posted: Sat Nov 18, 2017 9:42 pm Post subject: Re: Dead #1 cylinder |
Starbucket wrote: |
You say "Went dead again" were the plugs fouled? oily? melted? carbon stuck between plug gap?, How did they go dead? White as snow = big vacuum leak. |
Plugs weren't oily or melted, they were new plugs with zero miles on them. I installed them when I put the rebuilt heads on... When I changed the plugs this last time it idled nicely for about 90 seconds then I could hear the miss again...
I didn't see any smoke but I agree with wcfvw69 I think it could be a vacuum leak or I'm hoping it's one |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Nov 18, 2017 10:27 pm Post subject: Re: Dead #1 cylinder |
Did you get the old crush.washers out of the head before installing new ones? Once they.get crushed, they look like part of the head. I've pulled apart multiple single port engines with multiple crush.washers stacked on top of each other. Usually ppl just torque down the nuts so tight to get them to seal, they bend the flanges.
Check for vacuum leaks at the head where the intake bolts up. |
Posted: Sun Nov 19, 2017 8:46 am Post subject: Re: Dead #1 cylinder |
Pruneman99 wrote: |
Yeah I made sure I got the old ones out...i had a hard time getting the nuts real tight the first time I installed them I went too tight and stripped out the manifold stud so I was real careful maybe to careful this time...im going to go back around and tighten them |
Starbucket Samba Member
Posted: Sun Nov 19, 2017 9:02 am Post subject: Re: Dead #1 cylinder |
Pruneman99 wrote: |
Borrow a torque wrench from your FAPS and tighten slowly a little at a time i.e. nut near #1 then #4, #2, and #3 and repeat until you get to 10 ft/lbs (I think, check your book or maybe someone will chime in if I'm wrong). |
Posted: Sun Nov 19, 2017 9:19 am Post subject: Re: Dead #1 cylinder |
Starbucket wrote: |
Pruneman99 wrote: |
I have a torque wrench...a freshly calibrated snap on torque wrench...i was using it and John Muirs idiot guide when i stripped out the stud...i will try it again
Thanks for all the help I sincerely appreciate it |
Posted: Sun Nov 19, 2017 12:09 pm Post subject: Re: Dead #1 cylinder |
[quote="i_luv_my_bus76"]
Starbucket wrote: |
Pruneman99 wrote: |
/quote] If you have a short piece of hose, with the motor running, you can hold one end to your ear and the other end my the manifold joint and you can hear a hiss if it's leaking. |
