Mathieu2k4 Samba Member
Posted: Thu Nov 16, 2017 12:01 pm Post subject: stub axle is going in. |
Hi I recently changed the stub axle on my 72 bus and today I realized that the stub axle is going in.
I really don't know what is going on. No noise
Visually there were no differences between stub axle and hub that I replaced.
Are there differences between vanagon and bus stub axle?
Thanks
I'm currently in Hancok, New-Y trying to figure it out.
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Nov 16, 2017 12:08 pm Post subject: Re: Emergency, stub axle is going in. |
What? you changed your stub axle, and now its going in?
so you changed your axle, and now there is no noise... and you're concerned? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
SGKent Samba Member
Posted: Thu Nov 16, 2017 12:09 pm Post subject: Re: Emergency, stub axle is going in. |
define going in? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Nov 16, 2017 12:59 pm Post subject: Re: Emergency, stub axle is going in. |
Going in, I mean in the bearing hub, so I look at the wheel, I see the Axle nut, and it was against the wheel hub when I torqued it to 250 ft lbs
now there is a inch of splines visible.
Like if the stub axle were too long now.
Posted: Thu Nov 16, 2017 1:36 pm Post subject: Re: Emergency, stub axle is going in. |
Is it possible the guy sold me a longer axle from 68-70 bus and I fitted it on a 72 bus? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Thu Nov 16, 2017 1:57 pm Post subject: Re: Emergency, stub axle is going in. |
Mathieu2k4 wrote: |
Yes; this is exactly what would happen if you installed an early stub axle in a 1971 or later bus.
One tell if you don't have them side by side (the early axle is an inch longer and unusable on a 1971+ bus,) is to look for a collar where the CV rests. Here are some NOS early style axles; see the collars?
Here is a late style, missing the collared CV support.
[img]
I do not know if there were crossover years that were the late axle with the early color.
Good luck finding the correct part; I have two spares for sale, so send me a PM if you have a hard time finding one.
Robbie[/img] _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Nov 16, 2017 2:40 pm Post subject: Re: Emergency, stub axle is going in. |
Mathieu2k4 wrote: |
It's not "possible"- it's what happened. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Nov 16, 2017 2:43 pm Post subject: Re: Emergency, stub axle is going in. |
asiab3 wrote: |
Mathieu2k4 wrote: |
[img]
Robbie[/img] |
You beat me to it.
Actually, IIRC from our debacle with the Columbo bus this summer late ones are available new and are shared with Vanagons; that said, I'd trust a good used over new for anything these days unless the new one is German. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Nov 16, 2017 2:59 pm Post subject: Re: Emergency, stub axle is going in. |
If you are stuck out on the road, find a local machine shop and have them make you a collar that fits over the stub axle so the nut has something to tighten against. Others can probably tell you whether the spacer between the bearings and stuff will work correctly if you do this. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Fri Nov 17, 2017 10:01 am Post subject: Re: Emergency, stub axle is going in. |
DO NOT continue to drive it!!! _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Nov 19, 2017 5:58 pm Post subject: Re: Emergency, stub axle is going in. |
Sorry for the late reply, I found some spacers and installed them between the hub and nut, and torqued it to 250 ft lbs.
Will look to exchange my stub axle now for an late one.
Thanks for your help. |
