Reproduction OT Pulley's
Page: Previous  1, 2, 3, 4, 5, 6
frikendelicious
frikendelicious is offline
PostPosted: Wed Sep 27, 2017 3:39 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
I believe they reduced the diameter to prevent the pulley from cutting into the case. This happend a lot with the earlier ISP ones. The aluminium expands more than the original pulley. The reduced diameter is now causing the oil leaks. So Im wondering: is that only when the engine is cold, or is it also still leaking when warm? Either way, not really nice!
thanks,
jeroen
Mr.Ragtop
Mr.Ragtop is offline
PostPosted: Wed Sep 27, 2017 8:27 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
That shouldn't matter. Empi and many others have made aluminum pulleys with the correct diameter for years without issues. So what would make these ones expend any different?
The gap that is between the case and pulley snout is still pretty decent even with an original pulley. Steel doesn't expand at the same rate that aluminum does but the difference between steel and aluminum at full heat is very small.
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Wed Oct 04, 2017 10:15 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
Isn't it that, heated, steel expands more than an aluminum?
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20
Mr.Ragtop
PostPosted: Sun Nov 19, 2017 9:28 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
No. Aluminum expands at a fast rate and expands further than steel.
oldbusboy
oldbusboy is offline
PostPosted: Sat Dec 23, 2017 10:46 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
If the ISP OT copy pulleys are leaking, then they should take them back.
I have one on an Okrasa build that I haven't run yet.. I bought the pulley a couple years ago, so it would be interesting to see if it would be accepted as a return.
Trevor
1967 SO42
1958 Kombi
Mr.Ragtop
PostPosted: Sun Feb 25, 2018 12:56 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
Trevor
I agree they should take them back. From talking to a friend yesterday, I guess they are aware of the issue and are concerned about it. No idea what they will do. I got mine cheap enough and have the skills to correct it. Not worth going through the hoops to get a new one hoping it’s different.
johnny d
johnny d is offline
PostPosted: Tue Feb 27, 2018 12:41 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
Mr.Ragtop wrote:
[...]and have the skills to correct it.
so what you are going to do with it?
GermanRestoKommando
Der Barndoor Führers - Slamm Society
VWKernzentrale since 2007
mr. warehouse
mr. warehouse is offline
PostPosted: Sat Jul 21, 2018 2:25 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
I have a leaking ISP West OT pulley as well.
I've thought of turning it down and running sand seal.
Thoughts?
To keep up with Vintage Warehouse follow us on Instagram here - www.instagram.com/vintage_warehouse_vw_shop
Mr. Okrasa Premium Member
Original Old Speed
Mr. Okrasa is offline
PostPosted: Mon Jul 23, 2018 12:47 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
Thoughts?
You can turn the neck down of the ISP pulley but you have to add a steel collar otherwise the seal will cut into the aluminum.
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
See this link: https://vimeo.com/139432553
VW www.Okrasa.com
356 www.PreA356.com
mr. warehouse
PostPosted: Mon Jul 23, 2018 12:56 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
Thoughts?
Thanks. I was told to use a "Speedi Sleeve" or similar. In the meantime, I swapped it out for a Speedwell Denzel pulley and the leak has stopped.
Mr.Ragtop
PostPosted: Wed Aug 01, 2018 9:24 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
If you look at the other pages in this thread, i talk about fixing my pulley. I had it welded to make the OD much bigger. I will then lathe is down to the correct size of a stock pulley. Then lathe in the “slinger” groove again. It’s a lot of work, but if you have the tools and are able to do the work yourself, it’s not a big deal in the end. Here is the pic again after being welded.....
Mr.Ragtop
PostPosted: Mon Jul 08, 2019 9:19 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
Well I finally got around to finishing the pulley fix. It was machined to the exact dimensions of a stock pulley.
motofly196
motofly196 is offline
PostPosted: Sun Jul 14, 2019 7:27 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
That's some beautiful machine work! Be careful...you just might be getting request to fix a bunch of them!
johnny d
johnny d is offline
PostPosted: Wed Oct 30, 2019 9:02 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
its pretty nicly done.
ISP should do that to all our pulley. As there a lot of guys out there they can´t do this by there self. Crying or Very sad me included. Sad
GermanRestoKommando
johnny d
johnny d is offline
PostPosted: Wed Oct 30, 2019 9:05 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
ha, me too greg! Wink
GermanRestoKommando
Ted2
Ted2 is offline
PostPosted: Wed Oct 30, 2019 9:12 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
Mr. Ragtop,
After the repair what was the OD and the overall length?
Page 6 of 6
