Westy rack differences
Page: Previous  1, 2, 3 ... 11, 12, 13, 14, 15  Next
[email protected]
jmp@ncounty.net is offline
PostPosted: Mon Jul 24, 2017 7:01 pm    Post subject: Re: Westy rack differences Reply with quote
what year is this rack and is it made by Westfalia?
1)The rack has boxed bows like early racks
2) large feet with ribs
3) clamp with ribs and high screw location
4) one screw from wood to bow.
I looked at all the racks on the samba and can't find one like this.
HappyTheMan
HappyTheMan is offline
PostPosted: Tue Sep 12, 2017 12:43 pm    Post subject: Re: Westy rack differences Reply with quote
When restoring an original rack, should the legs and clamps be hot dip galvanized or electroplate galvanized?
otahuhu
otahuhu is offline
PostPosted: Tue Sep 12, 2017 2:46 pm    Post subject: Re: Westy rack differences Reply with quote
Originally, 100% definitely electro galv not hot dip.
HappyTheMan
PostPosted: Wed Sep 13, 2017 11:50 am    Post subject: Re: Westy rack differences Reply with quote
Okay, thanks. I've looked into it a little bit and information out there says the electroplating is much thinner than dipping. So, looking at the legs what you say makes sense. I've also read that it doesn't weather well, as in more prone to rust. Still, the legs don't show much sign of that. The clamps do though. Do you think car wax or something would help with that?
I have some remnants of the rubber stuff attached to the clamps (#24 in the drawing shown earlier). Anybody find material close to the original? It seems to be like a closed cell foam type of rubber. Mine are black (it's a 59 rack).
broozebrothers
broozebrothers is offline
PostPosted: Wed Sep 13, 2017 10:12 pm    Post subject: Re: Westy rack differences Reply with quote
crofty wrote:
easy e wrote:
Yes, slope has taller legs in the front... and shorter in the rear.
A non-slope follows the line of the drip rail.
That's actually a '62 only rack that has all three legs made from the rear leg of a sloper rack.
I have one of these 62 only racks ,, has all 3 small bows from a sloper rack without reinforcements on the corners , 61 sloper style clamps and 1 tag .. only seen one other , the one on that very bus ..
Skim
Rants Master
Skim is offline
PostPosted: Sun Nov 19, 2017 9:58 pm    Post subject: Re: Westy rack differences Reply with quote
My westy rack came with four of these aluminum plates between the slats. Does anyone know what they were for?
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Nov 20, 2017 3:01 am    Post subject: Re: Westy rack differences Reply with quote
Looks like small L-track pieces for cargo control/tie downs. Google L-track and you can see what I man.
1957 Beetle
1966 Bus
hitest
hitest is offline
PostPosted: Mon Nov 20, 2017 9:38 am    Post subject: Re: Westy rack differences Reply with quote
^^^ As you know- you hit it on the head. Perhaps the rack's owner did not want to add pulling stress to the side rails. By concentrating the pull on four corners (I'm assuming) it probably helped that rack last a lot longer than many. Pretty smart, and kinda stealth.
FU#5
folks55
folks55 is offline
PostPosted: Sun Dec 03, 2017 11:04 am    Post subject: Re: Westy rack differences Reply with quote
Followed a lead about some VWs stored away for years. Looks like a couple of cool racks there too
oakman
oakman is offline
PostPosted: Sun Dec 03, 2017 11:58 am    Post subject: Re: Westy rack differences Reply with quote
Damn dude!
Brandon
folks55
folks55 is offline
PostPosted: Fri Dec 29, 2017 1:48 am    Post subject: Re: Westy rack differences Reply with quote
oakman wrote:
Damn dude!
Lucky I suppose right. I needed the rack with the 2 screws at the end of the wood for my bus is Feb 60. Hopefully I'll be bringing it home really soon.
vworwhat
vworwhat is offline
PostPosted: Mon Jan 15, 2018 8:03 pm    Post subject: Re: Westy rack differences Reply with quote
After a 3 years hunt I finally found a set of original westy clamps (cheers Tony) for my baywindow rack. All I need now is the right hardwear. Does anybody have pics and specs of the original bolts and nuts? Are they the same as for split - DIN 85, 50s style cheese head machine bolts and DIN 557 square brass nuts or is the baywindow hardware different?
Westfalia Helsinki 6/77
Winter bus 5/74
Earlybay 7 seater deluxe 11/69
Type3 9/63 1500N M264 panel
easy e
easy e is offline
PostPosted: Mon Jan 15, 2018 8:45 pm    Post subject: Re: Westy rack differences Reply with quote
If you don't find your Bay Window answer in this Split Bus forum... maybe try this thread in the Bay Window forum:
Westy Roof Rack Clamps
aka: Evan
vworwhat
vworwhat is offline
PostPosted: Mon Jan 15, 2018 9:04 pm    Post subject: Re: Westy rack differences Reply with quote
Well, I figured this is a westy rack thread, not so much an exclusive split westy rack one. I don’t know whether you have read it, but I have - and it contains quite a bit of information on baywindow westy racks, too. Some guys in this thread really know their way around this topic and have been of great help on my quest so far. Taken all that in consideration, I might have a decent chance to get the missing information on my baywindow rack in this thread.
But thanks, I will try the thread the in baywindow forum aswell!
Winter bus 5/74
easy e
easy e is offline
PostPosted: Mon Jan 15, 2018 9:47 pm    Post subject: Re: Westy rack differences Reply with quote
I agree... so started my last post with "if."
Just hoping you get the info you seek.
I imagine there is a fair amount of Bay + Split owners.
aka: Evan
BarryL Premium Member
BarryL is offline
PostPosted: Tue Jan 16, 2018 10:36 am    Post subject: Re: Westy rack differences Reply with quote
What exactly makes it Bay?
vworwhat
vworwhat is offline
PostPosted: Tue Jan 16, 2018 10:44 am    Post subject: Re: Westy rack differences Reply with quote
The size, slates are longer. The shape, its lower than split. The size of the clamps, they are larger than late split clamps.
Winter bus 5/74
vworwhat
vworwhat is offline
PostPosted: Tue Jan 16, 2018 11:15 am    Post subject: Re: Westy rack differences Reply with quote
Any suggestions with regard to the proper hardwear for a bay rack? A mate has galvanized M6x30 machine bolts and wing nuts on his, they don’t quite look original though Rolling Eyes, but who knows.
Winter bus 5/74
easy e
easy e is offline
PostPosted: Tue Jan 16, 2018 3:19 pm    Post subject: Re: Westy rack differences Reply with quote
Bay Clamp is the one on the right (click)
Bay rack sits lower (closer in the pic).... split bus sits higher (back of pic)
aka: Evan
folks55
folks55 is offline
PostPosted: Wed Feb 21, 2018 11:57 pm    Post subject: Re: Westy rack differences Reply with quote
Page 12 of 15
