cliveawn Samba Member
Joined: December 07, 2010 Posts: 481 Location: Southern Sweden
Posted: Fri Nov 17, 2017 1:39 pm Post subject: treatment for new wooden veneer panels? |
Hi,
I bought this and was wondering if i should treat the inside wood backing? its bare wood but with a veneer on the outside,thinking maybe I should varnish it?
https://www.vwheritage.com/231898233-8-piece-wood-interior-panel-kit-for-westfalia-helsinki _________________ ---------------------------------------------------------
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Python CSP 42mm exhaust.
115 HP
Daily driver 2017 Volvo V60 D5 hybrid
Rica stage 2 tune 345hp.
''Funny thing about common sense is that its not very common''
Seismic gun mechanic |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Fri Nov 17, 2017 1:58 pm Post subject: Re: treatment for new wooden veneer panels? |
if you are sure the factory didn't seal them I would for sure-only cost a couple $$ but good insurance _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
ewdb92 Samba Member
Joined: September 24, 2010 Posts: 502 Location: Plymouth, NH
Posted: Fri Nov 17, 2017 2:12 pm Post subject: Re: treatment for new wooden veneer panels? |
I threw some wood sealer on the backs of my panels, but mostly for protection against window leaks (vent windows being left open/failed seals) or door panels getting rained on. Unless you live in a really humid climate, I don't think sealer is necessary. _________________ Erik
71 Camper
http://zerotosixtyeventually.wordpress.com/ |
Posted: Fri Nov 17, 2017 2:18 pm Post subject: Re: treatment for new wooden veneer panels? |
Im busy doing my 78 Westy down to bare metal respray,i need it to last and look like new.
I think some thinly coated varnish might do it. _________________ ---------------------------------------------------------
Fully balanced
8,5:1CR
JPM Custom made cam
115 HP
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sun Nov 19, 2017 8:21 am Post subject: Re: treatment for new wooden veneer panels? |
Sealing the backside of a laminated countertop is a good idea to prevent warpage . The laminate is impervious to moisture but the other side isn't and can absorb ambient humidity and can expand causing warpage. That's why those crappy home depot countertops are always cupped. Be careful in your case because the substrate is so thin too heavy of a coat of finish may soften the glue holding the laminate on. Thin fast drying coats is best. |
Posted: Sun Nov 19, 2017 11:37 am Post subject: Re: treatment for new wooden veneer panels? |
I think I will apply a thin coat of varnish just to be safe,thanks all for the tips and advice. _________________ ---------------------------------------------------------
Fully balanced
8,5:1CR
JPM Custom made cam
115 HP
nodrenim Samba Member
Joined: October 06, 2006 Posts: 843 Location: Dobson, North Carolina
Posted: Sun Nov 19, 2017 5:17 pm Post subject: Re: treatment for new wooden veneer panels? |
I most definitely would seal those new panels with a marine grade spar varnish, on the backside. Cheapest insurance you can get. Good luck with the resto, and post us some pics! |
Posted: Sun Nov 19, 2017 10:23 pm Post subject: Re: treatment for new wooden veneer panels? |
Excellent!
Got 6 weeks at sea then it starts!
Motor is coming out too,pics will be posted.... _________________ ---------------------------------------------------------
Fully balanced
8,5:1CR
JPM Custom made cam
115 HP
Posted: Sun Nov 19, 2017 11:24 pm Post subject: Re: treatment for new wooden veneer panels? |
I will also be using Dynamat extreme as sound proofing,can I also use Rockwool? If so,where do I fit the vapour barrier if needed? _________________ ---------------------------------------------------------
Fully balanced
8,5:1CR
JPM Custom made cam
115 HP
Hoody Samba Member
Posted: Mon Nov 20, 2017 12:14 am Post subject: Re: treatment for new wooden veneer panels? |
Be cardful what you use to seal those panels. I personally would use an oil based sealer. You want something with low VOC's. I chose a water based outdoor spray bomb urethane. It's called Rustoleum "varathane". Good luck! |
