exoticdvm Samba Member
Posted: Mon Nov 20, 2017 2:43 pm Post subject: Dealing with Battery Tray Rust |
Have a fairly rust-free '78 Bus (campmobile). However, I suspected some rust issues affecting the battery trays. After removing both batteries, there was definitely rust present including a small eroded hole under the auxiliary battery. Was planning on a POR-15 treatment, but not sure if this type of rust damage warrants welding in of new metal. How would you treat this? Go forward with POR-15? More serious intervention? Any advice appreciated! Photo attached.
_________________ 1978 VW Westfalia
http://www.marcandeliana.com |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2068 Location: Ontario Canada
Posted: Mon Nov 20, 2017 2:50 pm Post subject: Re: Dealing with Battery Tray Rust |
That's a perfect place for POR15. Be sure to do the proper prep work. They also make a mesh I believe that will handle that rust hole. Put a bolt in the bracket hole so you don;t fill the threads with the POR. Do the underside as well. This message depends solely on how thick the remaining metal is-you know a battery is pretty heavy _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Poptopcamper Samba Member
Joined: June 23, 2012 Posts: 490 Location: Sheridan, Wyoming
Posted: Mon Nov 20, 2017 5:55 pm Post subject: Re: Dealing with Battery Tray Rust |
I have a 78 and one of my trays was totally rotted. The PO put a piece of carpet in that hole, to hold the battery. The other side was a little bit worse than yours, but solid. I POR-15ed both sides. I bought new trays from BD, but I'm not ready to weld yet. Yours looks like POR-15 will give you some more miles. As long as it's still solid enough to support the battery. _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2021 Dodge Ram 3/4 ton
2020 VW Tiguan
2001 Harley Electraglide Classic
1986 BMW R 800cc motorcycle
2002 Chevy Camaro Z28
1999 Harley Sportster 1200 Custom |
Posted: Mon Nov 20, 2017 8:02 pm Post subject: Re: Dealing with Battery Tray Rust |
Treat the rust with some form of phosphoric acid (like POR 15) and then put several layers of fiberglass on the bottom of the box and run the glass up the sides to the height of the battery or a bit more. |
popuppopdog Samba Member
Joined: April 19, 2017 Posts: 80 Location: Oakhurst, CA
Posted: Mon Nov 20, 2017 8:46 pm Post subject: Re: Dealing with Battery Tray Rust |
Wildthings wrote: |
Let me start by saying I "am not" an expert, I have noted some methods for getting rid of rust by spray metalizing with a flame, cool stuff , I also saw a product at my coating company that sprays zinc to build back rusted metal that is very fragile, it is very interesting and am heading to this area, watch my thread "
https://www.thesamba.com/vw/forum/viewtopic.php?t=680122 |
Posted: Mon Nov 20, 2017 8:55 pm Post subject: Re: Dealing with Battery Tray Rust |
popuppopdog wrote: |
Wildthings wrote: |
I have had spray welding done over the years and think that it can be a great restoration tool. In the now distant past, I have been to Camby, OR several times to get spray welding done by Rustbusters. Sadly the owners of this company have retired and/or passed on and who knows where their welding equipment may have ended up. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon Nov 20, 2017 9:37 pm Post subject: Re: Dealing with Battery Tray Rust |
If you go the POR15 route, follow the directions with attention to detail and make sure to clean and treat the underside also(wheel well area).
I prefer the cut and replace method with regards to battery trays. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Tue Nov 21, 2017 12:26 am Post subject: Re: Dealing with Battery Tray Rust |
Your tray will eventually look like my 1977's tray:
But the 1970 bus I had was Swiss Cheese, yet solid around the edges. I decided to cut out portions of the holes, weld in sheet metal patches, then douche it with POR-15:
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2535 Location: Ocean Beach in Beautiful BLUE California
Posted: Tue Nov 21, 2017 4:57 am Post subject: Re: Dealing with Battery Tray Rust |
I don't weld.
After treating the remaining metal with POR15 (or equivalent) I repaired my battery tray with a piece of 3/4" exterior plywood 11 years ago. Still there and it is fine.
That being said someone on this from (Gary/Aeromech?) got a new metal battery tray and used panel adhesive to "glue" it into place. Looked very clean. If I were to do another tray I'd go that route. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Nov 21, 2017 6:00 am Post subject: Re: Dealing with Battery Tray Rust |
OB Bus wrote: |
I don't weld.
That being said someone on this from (Gary/Aeromech?) got a new metal battery tray and used panel adhesive to "glue" it into place. Looked very clean. If I were to do another tray I'd go that route. |
If you don't own a welder, I'd say this is a great approach. Something like Panel Bond by 3M is essentially like welding in metal. I've got some more work on my bus and I think I'll be using panel bond for it. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
