Goach2 Samba Member
Joined: November 20, 2017 Posts: 522 Location: Niagara Region, Ontario
Posted: Mon Nov 20, 2017 9:24 pm Post subject: /New-to-Me Engine, what's missing |
Hello all,
Long time lurker on this site, now a proud owner of a '77 Westfalia. For my first (of many) post, I was wondering if I could get some help identifying what's missing from my engine. I know the dist. cap, rotor and wires are missing, as well as the fan and tubing for the exhaust heat recovery and some type of intake attachment on the throttle-body. Is there anything else obviously not there? Also, I was hoping someone could identify which distributor is in it and any advice for getting it running is greatly appreciated.
Thanks!
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon Nov 20, 2017 9:29 pm Post subject: Re: /New-to-Me Engine, what's missing |
Missing:
Charcoal canister
S boot
Air Filter
Air Flow Meter
Almost all of the vacuum hoses
Is your ECU present? The photos don't show that area (front of passenger's side battery tray) _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Goach2 Samba Member
Posted: Mon Nov 20, 2017 9:38 pm Post subject: Re: /New-to-Me Engine, what's missing |
Thanks BusBoss, I'm making a list Yes, the ECM is there. |
Tcash Samba Member
Tcash Samba Member
Posted: Mon Nov 20, 2017 10:27 pm Post subject: Re: /New-to-Me Engine, what's missing |
Welcome to TheSamba, Bay Window Bus Forum!
73-79 NEWBIE
Tcash wrote: |
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Tue Nov 21, 2017 12:28 am Post subject: Re: /New-to-Me Engine, what's missing |
Goach2 Samba Member
Posted: Tue Nov 21, 2017 9:42 am Post subject: Re: /New-to-Me Engine, what's missing |
Thank you everyone for the welcome, pics and tips. I will ready through it all. Is it possible to identify the distributor from the pics? Or will I need to pull it out and look for some identifier? Thanks! |
Posted: Tue Nov 21, 2017 9:57 am Post subject: Re: /New-to-Me Engine, what's missing |
Your distributor should be stamped. From the Samba Photo Gallery, here is what you need to find... this model is the Bosch 205 T... and you might be able to determine what yours is with a penlight and a mirror... kind of like what this guy did to get this photo. But you may need to pull it to read the number.
Also... check this out:
http://www.oldvolkshome.com/ignition.htm |
Goach2 Samba Member
Posted: Tue Nov 21, 2017 9:24 pm Post subject: Re: /New-to-Me Engine, what's missing |
Had to pull mine out to get a good look at it. Needs a cleaning anyway It appears to be a 205 P? Anything I should be looking for specifically as far as parts for it?
Posted: Tue Nov 21, 2017 9:38 pm Post subject: Re: /New-to-Me Engine, what's missing |
There is a shitload of information and opinions about parts for these on the Samba. Dig in!
Sometimes, a package deal is a good way to get started in the beginning:
http://www.busdepot.com/87139
As time and experience build, you will likely arrive at your own conclusions about appropriate brands of parts for your bus. For now, clean up the distributor as best you can, and put it back in. The distributor is probably of small concern at this point. Do make a note of its model, take a few more pictures of it and put those pictures in a file folder on your desktop.
What is your goal over the next 30 days? Parts inventory, compression check/engine assessment, or what? |
Goach2 Samba Member
Posted: Wed Nov 22, 2017 6:51 am Post subject: Re: /New-to-Me Engine, what's missing |
Hmmm, tune-up kit does look like the way to go, thanks for that. now to try and find one north of the border
My plan is to first identify the parts that are missing and collect what I can. Then assemble and see what I have a far as compression and a running engine. If all goes well, move to brakes and inch closer to road worthy.
For the distributor itself, I wasn't sure what to search for in the forum, but 205P seems to be the way to go.
Thanks! |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Wed Nov 22, 2017 7:16 am Post subject: Re: /New-to-Me Engine, what's missing |
Hook up the oil pressure sensor wire. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Wed Nov 22, 2017 7:42 am Post subject: Re: /New-to-Me Engine, what's missing |
Use Bus Depot for part numbers, if nothing else. They (for the most part) use VW part numbers on their stuff, so it is often helpful in doing research.
Your engine seems to be equipped with an EGR system. I would expect you also have a catalytic converter.
Also, if you need an air filter box with Air Flow Meter, let me know. I have a few. They are specific to application, so you will need to know which one you need. I may or may not have the one you need. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Goach2 Samba Member
Posted: Wed Nov 22, 2017 8:13 am Post subject: Re: /New-to-Me Engine, what's missing |
lil-jinx - Thanks for those, I will read them in detail.
WY - Thank you for your offer, that would really help me get things rolling. How do I identify which filter/meter I'll need? I found the engine serial:
Posted: Wed Nov 22, 2017 9:01 am Post subject: Re: /New-to-Me Engine, what's missing |
Great question! Best answer is from Bentley:
See Chapter 5 - Engine and Clutch, page 5-87, Table VIII - General Engine Date where it lists Engine Code Letters. From there, we derive the first two letters of your stamping: GD
A word of caution: The Type 4 engines were stamped in two places; on the air housing (your picture) and on the case. Hopefully, they match... air housings can be swapped out, leaving you with two different numbers. Always try to find the case number (see photo earlier in this thread indicting where that number is found) Also, equally important is the understanding that the build of your engine may have been modified by previous owners... different stroke, bore, lifters, etc.
For now, assume you have a stock GD fuel injected engine. (We hope!) Now, with this information, turn to Chapter 10 - Fuel Injection, page 10-17, Figure 4-17 and Table A - Intake Air Sensor Part Numbers. It shows yours to be 022 906 301 D
Bus Depot has them rebuilt:
http://www.busdepot.com/catalogsearch/result/?q=02...sort_order |
Posted: Wed Nov 22, 2017 9:09 am Post subject: Re: /New-to-Me Engine, what's missing |
Excellent threads! |
Goach2 Samba Member
Posted: Wed Nov 22, 2017 10:54 am Post subject: Re: /New-to-Me Engine, what's missing |
Ok, I will look at the case again, I haven't found it as of yet.
If it is the same as the air housing, would 022 906 301 D be one of the ones you may have on hand? |
Posted: Wed Nov 22, 2017 1:26 pm Post subject: Re: /New-to-Me Engine, what's missing |
Goach2 wrote: |
... would 022 906 301 D be one of the ones you may have on hand? |
I do not know. I will try to look today. They are all junk yard finds and are aged. |
Posted: Wed Nov 22, 2017 8:06 pm Post subject: Re: /New-to-Me Engine, what's missing |
Edited...
I was not able to wade very far into the parts today, sorry! I found three of them. All seven pin, with air boxes attached to two of them. Problem is, the covers are missing off two of them and they are full of silt. Complete (except missing cover), but obviously just cores. I would not put any of these in operation. They all need total refurbishment.
I found one loose cover with part number 022 906 301 D but cannot determine which one it is from. Might not be from any of them!
The one that has its cover glued in place is without any numbers at all. |
