FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Tue Oct 11, 2016 1:13 pm Post subject: knocking on the solenoid is working for now |
So I got to my car after work and click nothing.
I ended up pushing starting it and getting home.
This morning again click but I use a rubber mallet and gently hammer the solenoid and it starts right up.
Any good options currently? I may have a spare solenoid but unknown working condition.
Can I remove just the solenoid or its best to remove the entire starter assembly? I know that will be a job in itself. If I did get it out could I repair the solenoid?
If worst comes to worse I'll take it to the shop but I'd love to see if I have options.
Thanks!
Chris |
74 Thing Samba Member
Posted: Tue Oct 11, 2016 4:39 pm Post subject: Re: knocking on the solenoid is working for now |
Typically Things have auto starters in them Bosh SR17x.
More than likely it is the solenoid.
Pulling the starter is not too bad. Disconnect the battery then go under the car and disconnect the battery/alt wires as well as the spaded ignition switch wire. Then there are two nuts-once inside the engine compartment near the firewall and one underneath.
You can unscrew and desolder the solenoid and remove and clean up the copper contacts. Also look at the braided wire between the solenoid and the starter motor.
Here is some info on how to do it:
http://www.thesamba.com/vw/forum/viewtopic.php?t=531782&highlight=solenoid+rebuild+solder |
Posted: Tue Oct 11, 2016 9:22 pm Post subject: Re: knocking on the solenoid is working for now |
Thank you for that! I forget there is a search function!
I now have the starter on the kitchen table ;) |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Oct 12, 2016 4:36 am Post subject: Re: knocking on the solenoid is working for now |
After years of age, its not uncommon for the wiring to get old and corroded and have trouble supplying power to the starter. If you are still having issues after installing a new starter, you may need to install a "hard start" relay. |
Posted: Wed Oct 12, 2016 2:59 pm Post subject: Re: knocking on the solenoid is working for now |
Old worn or corroded brushes will do the same thing. |
Semper_Dad Samba Member
ALANSD Samba Member
Joined: April 16, 2015 Posts: 341 Location: Woodstock, GA
Posted: Thu Oct 13, 2016 9:31 am Post subject: Re: knocking on the solenoid is working for now |
my wife uses that on me.. |
Posted: Tue Oct 25, 2016 12:10 pm Post subject: Re: knocking on the solenoid is working for now |
dang nabbit!
Starter quit on me again. After about a week of working fine.
I just get the click and thats it.
I'm thinking brushes need a looking into as suggested. |
Posted: Tue Nov 21, 2017 7:29 am Post subject: Re: knocking on the solenoid is working for now |
edit |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 212 Location: Norristown, PA
Posted: Tue Nov 21, 2017 7:59 am Post subject: Re: knocking on the solenoid is working for now |
Look on the bright side:
Having a starter that needs a tap to get going means you can leave the keys in the car and not worry that someone will steal it... |
