msaltz Samba Member
Joined: October 24, 2015 Posts: 42 Location: Fallbrook
Posted: Tue Nov 21, 2017 4:01 pm Post subject: Engine advice |
I am new to VW's and I just recently acquired a 65 Karmann Ghia. The engine has a lot of brass? shavings in the oil and relatively low compression on the no. 3 cylinder. I was planning on going through the engine and putting it back in but after doing a little research I have decided that putting my money towards a bigger engine may be the way to go. Which leads to my questions, since I have no experience with VW engines I am not sure how much engine I should go with. I want something that would be fairly reliable, idles well and I would like to use the Ghia as a daily driver. Within that I would like it to be fun to drive with the most HP that makes sense. That being said I was thinking about the below engine parts list as a starting point and would like to know if I am heading in the right direction or if there is anything I should change, any input would be greatly appreciated.
1) New Magnesium engine case bored for 94's, stroke relieved and full flowed.
2) AA 92B Thick Wall P&C's
3) Crank-4340 forged chromoly, counterwwighted 78mm Stroke, vw journals
4) Rods- 5.5” H-beam w/ARP Bolts
5) Cam- web 163
6) Rocker Arms- Scat pro street 707 1.25:1
7) Heads- Big Valve 40 x 35.5 dual valve spring
Push rods- Manton Chrome Molly
9) Bearings, Main, Cam & rod- Silverline?
10) Lifters-Scat Lube a lobe?
CR- 8.5-9:1? Have not thought about Carbs or exhaust at this point.
Also, I may not be asking the right questions so any insight to that would also be greatly appreciated. |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Tue Nov 21, 2017 4:13 pm Post subject: Re: ENGINE ADVICE |
Get SLR treated lifters.....stay away from the lube a lobes. Go with 82 crank and 5.4 rods...goes together real nice....juat like what you have only 82 crank will more bottom end torque in that heavy Ghia. Wolverine bearings are fine. Buy new rings for the AA's..Grant .....the ones they come with have issues. Not sure about cr....not familiar with that cam. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
msaltz Samba Member
Posted: Tue Nov 21, 2017 4:42 pm Post subject: Re: ENGINE ADVICE |
Thanks for the reply as far as the lifters, are the SLR treated lifters still SCAT? if possible could you post a link to those lifters?
As far as using this size engine 2180, is this something that is suitable for a daily driver? |
mark tucker Samba Member
Posted: Tue Nov 21, 2017 5:04 pm Post subject: Re: Engine advice |
and CB's lost pan of cheetos heads. ditto on the crank&rods..or more stroke&5.5 rods. and aluminum bubble top case instead of the mag case. I havent a clue what that cam is but what ever you want it to do get the cam for that app and.... 1.35 cb rockers&scat lash caps...and.... jcee or scat big mouth pushrod tubes....and...cb or empi "C" chanel valve covers....and...total seal rings....on what ever pistons you decide on and.....coated beariings...and..... |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue Nov 21, 2017 5:12 pm Post subject: Re: Engine advice |
msaltz wrote: |
I would build
2) AA 92B Thick Wall P&C's Yes change the rings to Grant or Devee's
3) Crank-4340 forged chromoly, counterwwighted 82mm Stroke, vw journals
4) Rods- 5.4” H-beam w/ARP Bolts
5) Cam- Engle FK-8 ground on a SC1 blank
6) Rocker Arms- Scat 1.4:1
7) Heads- Big Valve 40 x 35.5 dual valve spring get the CB Panchito
9) Bearings, Silverline Main, Mahle Cam & rod-
10) Lifters-Scat Lightweight. Stay away from the SLR and Lobe-A Lobe Both are unnecessary way to get extra money out of you.
CR- 8.5-9:1?
Have not thought about Carbs or exhaust at this point. Dual Weber 44 IDF's and 1 5/8" exhaust |
_________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Nov 21, 2017 5:56 pm Post subject: Re: Engine advice |
vwracerdave wrote: |
msaltz wrote: |
I would build
CR- 8.5-9:1?
Mo betta! _________________ modok wrote:
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Tue Nov 21, 2017 6:08 pm Post subject: Re: Engine advice |
msaltz wrote: |
I would build
CR- 8.5-9:1?
X2, The web 86b would be good too but that is a preference thing, both are good. Dan |
TerryFM75 Samba Member
Joined: February 15, 2015 Posts: 47 Location: Indiana
Posted: Tue Nov 21, 2017 7:01 pm Post subject: Re: Engine advice |
msaltz wrote: |
I would build
CR- 8.5-9:1?
I agree with this engine combo. Would be an awesome daily driver and super reliable. With the FK-8/1.4 rockers, this thing will blow the doors off of any Honda/Ricer out there. |
Howard 111 Samba Member
74 Thing Samba Member
Posted: Tue Nov 21, 2017 7:11 pm Post subject: Re: Engine advice |
With the 86b run it at 9:1 and get your manifold ported too as well as make sure you do not skimp on your heads and get a good set of ported heads. |
msaltz Samba Member
Posted: Tue Nov 21, 2017 7:29 pm Post subject: Re: Engine advice |
Thanks for all the advice and the CB Panchito heads are a good call. Excellent performance for not a lot of $. I was looking for the most performance I can get in a fairly reliable daily driver package. I wanted to make sure I was headed in a good direction before spending my money.
Looks like the general consensus approves vwracerdave's reccomendations.
Thanks vwracerdave. Also I was looking at Benco for the tranny, some super duper freeway flyer for about $1,300 . I wanted to wait on the tranny until I had a good idea on the engine.
Thanks again to everybody and if there is any more advice I would greatly appreciate it. |
Posted: Tue Nov 21, 2017 7:36 pm Post subject: Re: Engine advice |
Daily driver? You might want to consider my beehive valve spring kit. Click on my ads. Dan |
esde Samba Member
Posted: Tue Nov 21, 2017 7:57 pm Post subject: Re: Engine advice |
msaltz Samba Member
Posted: Tue Nov 21, 2017 9:22 pm Post subject: Re: Engine advice |
Fallbrook, California in Northern San Diego County. |
Posted: Tue Nov 21, 2017 9:53 pm Post subject: Re: Engine advice |
msaltz wrote: |
$1,300 is cheap! I paid a little more than double that for my Rancho with chromoly axles....it had a couple extras in it. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Tue Nov 21, 2017 11:49 pm Post subject: Re: Engine advice |
When we are in the FK8 cam area, might I also suggest the CB 2288 which is in the same range. A tad nippier than the FK8, a tad noisier than the 86b but about the same power as the 86b.
T |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Nov 22, 2017 8:23 am Post subject: Re: Engine advice |
msaltz wrote: |
You should check out my 050 Rasser cylinder heads. They will produce excellent HP and run cooler than any other casting out there.... _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 256 Location: Peoria, Illinois
Posted: Wed Nov 22, 2017 8:19 pm Post subject: Re: Engine advice |
For the money that you'll have invested in engine suggested above, I think I would rather have a stock short block, 94 PCs, no name 40 by 37 heads with a DIY port job and dual springs, any small cam, DDVA distributor with Pertronix module, and a small turbocharger. Add water injection. An engine like this will make very high torque at 3500 rpm because the turbo is feeding the engine a lot of air even though it is still making an inch or two vacuum and not yet on boost. Just the thing to go well with a freeway flyer transaxle in a daily driver. Bonuses are smooth idle, very broad torque curve, and good mileage without all the "big cam" drama. Sorry to be the "wise guy" in the thread, but I love my turbochargers. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Wed Nov 22, 2017 11:55 pm Post subject: Re: Engine advice |
Bugsy61 wrote: |
A turbo and water injection for a guy new to VWs? Really? _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Thu Nov 23, 2017 9:18 am Post subject: Re: Engine advice |
My ignorance showing?
But with the TW 92s, does case need to be opened up for 94? Or is there a version of TW cylinder that accommodates 94 at both head and case? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
