apihor Samba Member
Joined: February 22, 2015 Posts: 61 Location: Buena Park, CA
Posted: Wed Nov 22, 2017 10:59 am Post subject: 1962 shift issue |
Hey Samba,
I've been having a bit of an issue with my shifter alignment. No matter how far up, down, or in the middle I go, it just not want to stick in 3rd gear(also grinds).
it is weird because before I remove the shifter every gear was working fine.
hopefully someone can help!
I am try to avoid buying a new transmission.
the things I have done:
-replace the shifter
-replace the hanger and wielded
-replace shiftrod bushing
-rear couplet |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Nov 22, 2017 12:37 pm Post subject: Re: 1962 shift issue |
Check the shift linkage coupler under the rear seat.
Make sure the bolts for that are still tight and properly safety wired.
Do you have the early or later style of coupler?? _________________ In Stereo, Where Available! |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Wed Nov 22, 2017 1:18 pm Post subject: Re: 1962 shift issue |
Make sure you have this plate positioned properly under the shifter. It goes the way it's show in this pic from the gallery. The little ramp is on the right and faces up.
_________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
apihor Samba Member
Posted: Wed Nov 22, 2017 2:27 pm Post subject: Re: 1962 shift issue |
Eric&Barb wrote: |
Do you have the early or later style of coupler?? |
yes they are bolted tight. also it is an early style. |
apihor Samba Member
Posted: Wed Nov 22, 2017 2:30 pm Post subject: Re: 1962 shift issue |
rcooled wrote: |
Yes it is up and on the on the passenger side. |
Posted: Wed Nov 22, 2017 2:34 pm Post subject: Re: 1962 shift issue |
What shape is the forward link shift bushing? _________________ In Stereo, Where Available! |
apihor Samba Member
Posted: Wed Nov 22, 2017 2:57 pm Post subject: Re: 1962 shift issue |
Eric&Barb wrote: |
What shape is the forward link shift bushing? |
it is new |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Nov 22, 2017 4:10 pm Post subject: Re: 1962 shift issue |
apihor wrote: |
-replace the hanger and welded
-rear couplet |
Positive that the new hanger was in the absolute correct place when it was welded?
Is the shift bushing still locked in place in that hanger? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
apihor Samba Member
Posted: Wed Nov 22, 2017 4:30 pm Post subject: Re: 1962 shift issue |
Cusser wrote: |
apihor wrote: |
-rear couplet |
Is the shift bushing still locked in place in that hanger? |
Yes, I believe so. |
Posted: Wed Nov 22, 2017 5:10 pm Post subject: Re: 1962 shift issue |
apihor wrote: |
...it just not want to stick in 3rd gear(also grinds). |
The exact same problem came up suddenly in a newly-rebuilt transaxle in my '63. Was done less than 1K miles ago by a recommended shop too. Linkage has a new bushing, is well-greased and properly adjusted. I can't engage 3rd gear, even with the engine off, despite the gear lever having a good solid connection to the input shaft on the trans.
I figure that something let go inside and the trans needs to come out to see what's going on. Adjusting the shift plate up & back can only do so much... _________________ '63 Ragtop (current)
apihor Samba Member
Posted: Mon Nov 27, 2017 8:22 am Post subject: Re: 1962 shift issue |
rcooled wrote: |
apihor wrote: |
I figure that something let go inside and the trans needs to come out to see what's going on. Adjusting the shift plate up & back can only do so much... |
thanks i will try that. |
