AA Performance Thing shroud with type 4 oil cooler
kubelmann
kubelmann is offline
PostPosted: Tue Nov 21, 2017 6:57 pm    Post subject: AA Performance Thing shroud with type 4 oil cooler Reply with quote
AA Performance products has some nice looking Thing cooling shrouds for some Thing in need.... I have no connections with AA other than using their good priced pistons and jugs with happy success.
https://aapistons.com/collections/sale-items/produ...oil-cooler
74 Thing
74 Thing is offline
PostPosted: Tue Nov 21, 2017 9:35 pm    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
http://usstore.concept1.ca/Fan-Shroud-W-OHeat-W-Holes-COOLED.1.2-62217/
I believe this is the product they are selling.
They do look nice, although I never need a type IV cooler.
kubelmann
PostPosted: Tue Nov 21, 2017 10:21 pm    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
I only ran into the AA site with the shrouds today. The shroud you listed is a lower price. The type 4 addition is an old offroad trick for larger motors with higher compression. In the path of building high compression 1915 motors, I have built/modified a number of Thing shrouds to hold a type 4 cooler. It is cool to see a modification that was previously hand built from two shoruds now available without clean air holes. A used stock 73 shroud has been $250 for a long time now. So, a new one made to the same speces is a nice deal especially for an owner without fabrication skills. It is cool that you listed a lower priced source...
EDragnDean
EDragnDean is offline
PostPosted: Wed Nov 22, 2017 12:51 am    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
They should include a custom hoover bit
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
kubelmann
PostPosted: Wed Nov 22, 2017 5:12 am    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
Here is the guy who makes the custom Hoover bits. This one is for a type 4 cooler
www.thesamba.com/vw/classifieds/detail.php?id=1193280[url][/url]
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Nov 22, 2017 6:58 am    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
No coil mount nutserts.
As for the T4 oil cooler.. i had one on my 1904 and didn't notice any improvement. My current 2180 has a Type 1 oil cooler (Genuine 73 Type 181 shroud) and it runs as cool as stock.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2019
74 Thing
74 Thing is offline
PostPosted: Wed Nov 22, 2017 7:49 am    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
I believe that the type IV cooler was due to the info in the Berg blue book.
If my memory serves me right Jake Raby did a test back in the day and indicated that it did not help since no more air is being diverted over the larger cooler when compared to a type 1 cooler.
kubelmann
PostPosted: Wed Nov 22, 2017 8:02 am    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
The point of my original post was to let folks who had not seen it aware that there are some rare shrouds in ALL styles at a reasonable price and nice looking quality. They have all flavors from straight stock to modified. It was not a pitch for the t 4 oil cooler conversion... I did not notice the missing coil nuts ~~good eye Glenn...
Wildthings
Wildthings is offline
PostPosted: Wed Nov 22, 2017 9:48 am    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
It would be interesting to see if this setup had any positive effects on cooling with no down side. I have bought a late model Bug fan shroud with the factory velocity ring and will install it the next time my engine is out. Might do the T-4 cooler swap as well as I have multiple T-4 coolers available.
Have also thought about building a bulge in the body (the back shelf area on a Thing) to give a larger crossectional area for air flow in front of the fan inlet. The inlet area has just always seemed restrictive to me. Others thoughts on doing this?
Jake Raby
Jake Raby is offline
PostPosted: Wed Nov 22, 2017 9:16 pm    Post subject: Re: AA Performance Thing shroud with type 4 oil cooler Reply with quote
Never saw a benefit from this... Back to back the oil temps ran the same, or hotter, and the CHTs suffered on cylinder #1.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
