Rear license plate mounting
sgellis
sgellis is offline
PostPosted: Fri Nov 24, 2017 6:55 pm    Post subject: Rear license plate mounting Reply with quote
My 64 Kombi had the plate mounted directly to the engine lid. Lid was 65 or newer anyway. The holes were not centered and one was 1/4" higher than the other so I welded them in.
I would like to put an offset bracket but see many sizes. Is there a preferred bracket for a 64 from VW or were they just random?
Found this pic for an older lid. Was there a standard hole placement for the offset bracket?
My 64 Kombi restoration
My camper interior build
PostPosted: Fri Nov 24, 2017 9:55 pm    Post subject: Re: Rear license plate mounting Reply with quote
It was definitely a dealer thing and that's why you saw "random" holes in your lid.
The picture above looks like many I have seen where the license plate is raised off of the lid.
2 narrow holes in the center.
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Nov 25, 2017 12:16 pm    Post subject: Re: Rear license plate mounting Reply with quote
Probably the most standard one used for rear Bus and Ghia is the lower one in this image.
In Stereo, Where Available!
Eric&Barb
PostPosted: Sat Nov 25, 2017 12:19 pm    Post subject: Re: Rear license plate mounting Reply with quote
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=ZVW17A
sgellis
sgellis is offline
PostPosted: Sat Nov 25, 2017 2:17 pm    Post subject: Re: Rear license plate mounting Reply with quote
Thanks. I will pick one of those up and drill my lid.
Eric&Barb
PostPosted: Sat Nov 25, 2017 2:27 pm    Post subject: Re: Rear license plate mounting Reply with quote
Glad to help!
Our 1962 SO-34 Tourist Delivery had the plate bolted directly to the lid also.
Changing to the same bracket so we can more easily add/wire in accessory yellow turn/brake signals to each side of the plate.
