kenney158 Samba Member
Joined: September 05, 2014 Posts: 121 Location: Easton, Pa.
Posted: Sat Nov 18, 2017 10:48 pm Post subject: Horn Question |
I've read the posts I can find about horns, but not seeing what I need.
My '03 Weekender's horns have stopped working. Were weak but now nothing. I have removed horns, cleaned all connections, put new connectors on horns, and tested both horns with alligator clips to battery. Got good sound from both. Cleaned all grounds near the horn, on the mounts, etc., but nothing.
I know on older cars there was a contact that had to be made under the horn pad on the steering wheel, but when I look at videos of removing the airbag from the steering wheel I'm not seeing such contacts. Should there be a ring there, or some other contact that isn't showing in videos?
I haven't checked a fuse yet. Will tomorrow. Not hearing a relay click but I can listen for that tomorrow, too. Any help appreciated. [/u] |
Abscate Samba Member
Posted: Sun Nov 19, 2017 4:50 am Post subject: Re: Horn Question |
I've got pictures I buried somewhere in an ignition switch thread , my recollection is its two knife edge contacts bearing no resemblance to earlier T123 horn switches.
I'll try dig them up later this evening _________________ .ssS! |
Scottn59c Samba Member
Joined: December 22, 2016 Posts: 308 Location: Northern CA
Posted: Sun Nov 19, 2017 8:24 am Post subject: Re: Horn Question |
Check the fuse. Should be #13. _________________ Farfignewton! |
Posted: Sun Nov 19, 2017 8:44 am Post subject: Re: Horn Question |
Thanks Abscate and Scottn59c. Will check fuse and also search threads for an ignition switch post. |
Posted: Sun Nov 19, 2017 11:21 am Post subject: Re: Horn Question |
The fuse was bad! That was my next step. I'm assuming the fuse went bad b/c the connections were all so bad. I'll see if this fuse goes, then will have to locate a different short for the fuse problem. |
Posted: Fri Nov 24, 2017 8:29 pm Post subject: Re: Horn Question |
OK. Fuse has blown again. Any suggestions on where to start looking to track down a short are appreciated. |
