WestfaliaMike Samba Member
Posted: Fri Nov 24, 2017 10:13 am Post subject: Air cooled Heat question |
Been slowly putting back togreather my vanagon that the PO disassembled.
One of the last problems i have is the lack of heat. I have searched the forum, and didn't fine much. Anyone have a link that could help me troubleshoot?
I have a smaill amout of floor and center dash heat. Nothing but cold air from the defrosters and dash vents.
Thanks! _________________ 1981 Vanagon Westfalia
1983 Vanagon Passanger (Parts Vehicle)
2016 Passat TSI |
Posted: Fri Nov 24, 2017 11:49 am Post subject: Re: Air cooled Heat question |
*There is always the possibility that there is a mouse nest blocking the ducting.
*Any piece missing from the system can compromise the entire working of the heating system.
*Are your flapper valves opening fully?
*Have you taken them off and actually looked inside to see that the flaps are operating and haven't fallen apart?
*Make sure that the levers on the heater box up front under the middle of the dash actually move when you move the levers on the dash itself. The cables will get kinked and as a result when you move the levers on the dash nothing actually happens in the heater box.
*Read your owners manual so you know what position the levers need to be in to get good heat, their operation is not intuitively obvious. |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Fri Nov 24, 2017 8:37 pm Post subject: Re: Air cooled Heat question |
That's a weak heater at best. Now that your rig is 35 years old or more. The heat is in need or a lot of attn. New duct w sealers and clamps and prob just a straight up overhaul.
At least you haven't removed the motor and installed something not remotely associated w the engineering your van was born w. Like one guy I know. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Fri Nov 24, 2017 9:05 pm Post subject: Re: Air cooled Heat question |
thank you _________________ 1981 Vanagon Westfalia
2016 Passat TSI
Last edited by WestfaliaMike on Sat Nov 25, 2017 1:24 pm; edited 1 time in total |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Nov 24, 2017 9:30 pm Post subject: Re: Air cooled Heat question |
deleted |
