Sourcing 914 Transmission
Mikedrevguy
Mikedrevguy is offline
PostPosted: Mon Jul 24, 2017 7:41 am    Post subject: Sourcing 914 Transmission Reply with quote
Looking to replace transmission -76 914 2.0 (though a 2.2 is going in)
Where to begin finding a solid replacement?
Rev.
74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
nogoodwithusernames
nogoodwithusernames is offline
PostPosted: Tue Jul 25, 2017 2:45 pm    Post subject: Re: Sourcing 914 Transmission Reply with quote
Try a WTB over on 914world.com?
71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
(Conversion thread https://www.thesamba.com/vw/forum/viewtopic.php?t=732508&highlight= or https://shoptalkforums.com/viewtopic.php?f=1&t=151375&sid=f0542d44a322d290c29d6609fac7f215 )
74 914, 2.0L w/ D-Jet
-Derek
Mikedrevguy
PostPosted: Sun Jul 30, 2017 7:03 am    Post subject: Re: Sourcing 914 Transmission Reply with quote
Found Gene in Utah with rebuilt. Has others available as well, if anyone is in need of such a transmission,
https://www.thesamba.com/vw/classifieds/detail.php?id=2054638
Also had set of new 3bolt heads.
76 914 with 2260
79 VW Iltis
69 Bwajaja
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Wed Oct 25, 2017 7:51 am    Post subject: Re: Sourcing 914 Transmission Reply with quote
914 transmissions are a dime a dozen, but most by now suffer at least first gear problems if not second as well. We have seen few ring gear and pinion problems. The problem is that the parts are expensive, not so much the rebuild labor as long as one has the proper factory tools to reset things like ring gear and pinion depth and to press off the dog teeth. SO one winds up spending 2000 on a rebuild, when one can purchase a used questionable transmission for 250. Just does not make much sense "huh"
Mikedrevguy
PostPosted: Sat Nov 25, 2017 9:30 am    Post subject: Re: Sourcing 914 Transmission Reply with quote
Found one from Genno in Utah for reasonable, plus a couple of 2.0 heads.
He even dropped them off in his way through to Portland.
After the car is put back together, I’ll train my sights in that direction.
76 914 with 2260
79 VW Iltis
69 Bwajaja
