veedubfreak59 Samba Member
Joined: February 22, 2010 Posts: 228 Location: Denver, CO
Posted: Sat Dec 02, 2017 7:45 am Post subject: 58 antenna question |
Whats going on here? Which holes do i need to weld up. Why are there 3 holes here. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sat Dec 02, 2017 8:21 am Post subject: Re: 58 antenna question |
Grab your attenae, figure out which holes work and weld up what’s not needed. Antennas were dealer options so there isn’t truly a rule as to what or even where they are. A PO probably slapped on whatever they found at their FLAPS back in the day and rather than trying to use the old holes drilled new ones. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sat Dec 02, 2017 10:16 am Post subject: Re: 58 antenna question |
Looks to me like the car had a two post antenna installed, once in the vertical position and once at an angle following the A pillar rake. _________________ 1960 Ragtop w/Semaphores "Inga" |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sat Dec 02, 2017 1:13 pm Post subject: Re: 58 antenna question |
As mukluk states- someone had a 2-post antenna as pictured. If you are sticking with an antenna, then choose if you want vertical or raked to align with the A pillar. Or weld them all if you want to use a radio delete. Here is a vertical mounted antenna:
_________________ Plate of shrimp |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Sat Dec 02, 2017 2:39 pm Post subject: Re: 58 antenna question |
In Feb 59 the dealer put a two post vertical on mine, with a Motorola am radio. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
