Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Sat Aug 08, 2015 2:21 pm Post subject: New to Me 73 Project... On/Off Road Dual Sport Thingamajig |
I made arangements to go get the thing today and for the first time I got a really good look at it. This is a project that kinda of stalled with the PO. I took it in on trade for labor on another vehicle he was wanting to get finished up and driving soon.
After seeing all the after market parts that he purchased for it and the quality of the workmanship to this point Im getting really excited to play with it. It needs a little light body work and a fresh coat of yellow paint. at that time Im going to just drive it and tinker on it as time permits. Its not your stock model but I think it will serve my needs perfectly.
_________________ Change is Opportunity!
Instagram=metaltwister
Last edited by Metal Twister on Fri Dec 01, 2017 10:45 pm; edited 3 times in total |
liken127 Samba Member
Joined: June 27, 2013 Posts: 102 Location: Upland Ca.
Posted: Sat Aug 08, 2015 6:47 pm Post subject: |
Looks great! lots of fun ahead!! Maybe we will cross paths some day.
hopping to be on the road by end of October with ours. |
Posted: Sun Aug 09, 2015 9:45 am Post subject: |
I plan on using it a lot and I should be on the road about the same time as you. I will wave if I see ya! _________________ Change is Opportunity!
Instagram=metaltwister |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Sun Aug 09, 2015 12:31 pm Post subject: |
Looks like a great platform to finish personalization.
Looks solid ride and will be great when done.
congrats |
Posted: Sun Aug 09, 2015 1:11 pm Post subject: |
I have been sorting things out today on it. There are new repop floor pans in place to be installed so I will most likley start there and work my way up. Other than the floors there is no rust in the vehice at all which is a big plus. As mentined the PO has done a bunch of work to this car and what he did do was great quality so Im not that far off from actually getting it going.
Guess if ya seen one youve seen them all! _________________ Change is Opportunity!
Last edited by Metal Twister on Sun Aug 09, 2015 10:26 pm; edited 1 time in total |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
imtb Samba Member
Posted: Mon Aug 10, 2015 5:47 am Post subject: |
Looks like a great start. |
Posted: Mon Aug 10, 2015 8:45 am Post subject: |
Un like most of my projects that get dragged out of the field after 70 years this thing is almost ready to go! Im getting excited now. Now I need another 3 or 4 weeks to get mr customers truck finished up and gone so I can focus on the thing... Just having it here is a great motivator to get his work done. _________________ Change is Opportunity!
Last edited by Metal Twister on Mon Aug 10, 2015 10:12 am; edited 1 time in total |
lowsquare Samba Member
Joined: May 29, 2004 Posts: 287 Location: Queen Creek, AZ
Posted: Mon Aug 10, 2015 9:49 am Post subject: |
Good looking...keep the pics coming. How big is the body lift? _________________ PRAISE THE LOWERED.
1973 THING |
Posted: Mon Aug 10, 2015 10:08 am Post subject: |
lowsquare wrote: |
Good looking...keep the pics coming. How big is the body lift? |
It looks to be 2.5" wide. Are there different widths? Thanks guys for the encouragement. _________________ Change is Opportunity!
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Mon Aug 10, 2015 2:18 pm Post subject: |
Looks like you will have a lot of fun with it. Looking great. I would like to find one that I could turn into a Dirt Buggy but the ones I have I just can't tear them up.
GB |
ThingOw181 Samba Member
Posted: Tue Aug 11, 2015 4:16 pm Post subject: |
Looks like a great start!
Body lifts are typically 3".
You do need to modify your steering. I can't see inside, but it appears to be the stock column. Not sure how it is mounted or routed through the firewall.
The issue is that 1" square tube spacer on the steering box. That is going to put a ton of leverage on the rag joint. Lengthening the shaft would be a far smarter choice.
Good news is it still has a stock Thing beam with adjusters welded in- it kept the outboard gussets in place. Lots of strength there.
Keep posting pics! |
Posted: Tue Aug 11, 2015 4:17 pm Post subject: |
Oh and don't read too much into my body lift comment on my other post. A lot of that was execution on my part! |
Posted: Tue Aug 11, 2015 7:37 pm Post subject: |
The bug in my avatar was one I lifted way back in the day. It had over sized tires on it as well and I had troubles with the crumple zone on the steering column. The expanded metal would stress crack right where it attached to the steering shaft below it. So I most likely will find a piece of tubing 1" longer than the crumple zone and weld that in. There is nothing more strange feeling than driving down the hwy and not have any steering. Might be something to inspect from time to time specially if you venture off road very often. _________________ Change is Opportunity!
Posted: Fri Dec 01, 2017 9:40 pm Post subject: Re: New to Me 73 Project... On/Off Road Dual Sport Thingamajig |
Well im back, I think? I had some life changing setbacks these past few years that were totally unexpected as well as very time and energy demanding. But I think im just about ready to focus in on the Thing once again and see if I can make it happen this go around.
Sometimes when you step back from something for awhile and come back to it it takes on a different twist. Its like you see it through different eyes. Last weekend i spent some time in the desert with a good friend who has a old school tube frame buggy with the typical 1776cc engine. It was so much fun playing in the mud hills and sand i decided i had better get busy once again on the Thing. In looking it over after some time in storage I realized there are some things that i need to address right off the top. First is the exhaust... Man that thing hangs down low and its not condusive to the places Im desiring to go. If i dont change it out im going to be leaving it on a good sized rock somewhere. Its a very nice like new aluminized exhaust, but just the wrong style for my liking. So with the body lift installed it gives me a lot of vertical room to move an exhaust.
Im thinking a competition buggy style exhaust might be in order but wondering just how much body will need to be removed to accomplish it? Any ideas for maximum clearance? I know this white car is a type 4 engine and he had to really open the back up to make it work... Which if that is the only option i have no problem going in that direction. Now the blue car cant run a deck lid but looks like he kept the hacking to a minimum.
Im liking the blue cars approach and thinking i could build a cage much like the white car while making the deck lid slide down behind the exhaust on to a couple guide pins. By doing so i could retain a some what original look. Thoughts?
It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Dayton, Nevada
Posted: Sat Dec 02, 2017 8:37 am Post subject: Re: New to Me 73 Project... On/Off Road Dual Sport Thingamajig |
Looks like both cars have the engine set back to help the CV's with the long rear arms. Are you planning to keep the engine under the deck lid ? there are better cage designs than thoses. _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
Posted: Sat Dec 02, 2017 9:00 am Post subject: Re: New to Me 73 Project... On/Off Road Dual Sport Thingamajig |
It's a play thing wrote: |
Looks like both cars have the engine set back to help the CV's with the long rear arms. Are you planning to keep the engine under the deck lid ? there are better cage designs than thoses. |
Short term im not going to change things up too much as id really like to get a feel for what the car is capable of in its present configuration. To be honest a type 4 might be in the far off future but not planning anything in that direction at the moment. I would like more ideas on engine cage designs if you have any pics? A full roll cage is in order and id like to tie everything together, or at least eventually tie everything together. lol These two are pretty much the standaed engine cage designs. Think the white car is more of a Off Road Race design and the blue a Sand car /Baja Bug look. Then there the nerf / bumper styles which seem to be derived from a cross from cars and different dirt track cars... Im anxious to see the better designs you know of. _________________ Change is Opportunity!
Posted: Sat Dec 02, 2017 7:59 pm Post subject: Re: New to Me 73 Project... On/Off Road Dual Sport Thingamajig |
just search google Off road Things and you will see a bunch of designs. _________________ It's not the size of your shop, it's what comes out of it that counts.
Posted: Sat Dec 02, 2017 8:41 pm Post subject: Re: New to Me 73 Project... On/Off Road Dual Sport Thingamajig |
just search google Off road Things and you will see a bunch of designs. |
Oh believe me ive been looking. I was just curious to see what the "better" design that you speak of looks like? Just hoping for another option. Thanks _________________ Change is Opportunity!
Posted: Sun Dec 03, 2017 8:10 am Post subject: Re: New to Me 73 Project... On/Off Road Dual Sport Thingamajig |
better might have been a poor choice of words on my part. On my off road Thing it was important to keep the rear deck lid and keep the tires under the fenders, sorry for the confusion. while still being off road worthy. _________________ It's not the size of your shop, it's what comes out of it that counts.
