Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Sat Dec 02, 2017 12:06 pm Post subject: Need 181 Thing engine cage design ideas... |
Looking for off road 181 engine cage designs. Im going to stay vw engine and im trying to deside on an engine cage design. I kinda like the cage on this white car... Looks to give good rear impact protection as well as rock clearence while not looking big and bulky. Ideas? Do's or Don'ts?
_________________ Change is Opportunity!
Instagram=metaltwister |
cbeck Samba Member
Posted: Sat Dec 02, 2017 2:58 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
After this, I went for a surplus as opposed to a surminus.Cage was 120 dom vs 095? frame. I think the frame took it worse than the cage. Also bent the solid motor mount, crushed header into pulley, which took out longblock.
Surminus
Surplus
Posted: Sat Dec 02, 2017 3:01 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
Ouch! Were you rear ended on the street? _________________ Change is Opportunity!
cbeck Samba Member
Posted: Sat Dec 02, 2017 5:36 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
Drunk in a 4x4 ram on a sunday afternoon. |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Sun Dec 03, 2017 1:53 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
Your gonna need more motor to push all that steel! _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Sun Dec 03, 2017 2:57 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
As for the cage on that white car, it looks to me if you were rear ended on the street the cage will fold into the exhaust pushing the exhaust into the engine. or maybe go under lifting you off the ground. |
cbeck Samba Member
Posted: Sun Dec 03, 2017 4:19 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
Check. 125? Hp Plus some re-gearing. Smokes my kids 17 fiesta w/5 speed. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Sun Dec 03, 2017 4:53 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
weasel_ugs wrote: |
It has a type 4 engine and it and sticks out the back quite a bit more than mine will _________________ Change is Opportunity!
Last edited by Metal Twister on Sun Dec 03, 2017 7:36 pm; edited 1 time in total |
cbeck Samba Member
Posted: Sun Dec 03, 2017 7:29 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
I must be a f#@ktard magnet. Typical flaps bumper. Took out the pushrods/tubes on the right side along with right side header and a couple exhaust studs. Sorry about the 1985 pics.
Posted: Sun Dec 03, 2017 7:39 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
cbeck wrote: |
I must be a f#@ktard magnet. Typical flaps bumper. Took out the pushrods/tubes on the right side along with right side header and a couple exhaust studs. Sorry about the 1985 pics. |
So your suggesting not to run an engine cage at all what would you have distroyed if the cage wasnt there? _________________ Change is Opportunity!
cbeck Samba Member
Posted: Mon Dec 04, 2017 4:20 am Post subject: Re: Need 181 Thing engine cage design ideas... |
Make it stout. Little bit of tubing is cheap compared to engine work. Don't bolt the top tubes to just the firewall, it will punch thru the sheet metal. The baja had the style of top mount that bolted on with the upper shock bolts. Leave some room in back so if it does deform, it doesn't take out something else out. The baja took a lite hit from the drivers door of a car that spun out trying to stop at a red lite in the snow with a little old lady behind the wheel. The rail made it about a mile chasing the hit and run driver before it lost oil pressure. DON'T use the type of skid plate that bolts to the engine case. Got the baja bugs and buggies book? It's a little dated, but still has lots of good info. _________________ My cut in half and rebuild thread
dustymojave Samba Member
Posted: Mon Dec 04, 2017 9:09 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
Be sure the bumper is no stronger than the cockpit part of the car. You would be better off if the engine takes one for the team than the team taking one for the engine. I've seen both situations. _________________ Richard
SoCalBajas Member
Posted: Mon Dec 04, 2017 10:03 pm Post subject: Re: Need 181 Thing engine cage design ideas... |
dustymojave wrote: |
Be sure the bumper is no stronger than the cockpit part of the car. You would be better off if the engine takes one for the team than the team taking one for the engine. I've seen both situations. |
Very good point... I will make sure to keep that in mind. _________________ Change is Opportunity!
