Lost a wheel today. related to powder coat?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
pb_foots
pb_foots is offline
PostPosted: Sun Oct 08, 2017 10:26 pm    Post subject: Lost a wheel today. related to powder coat? Reply with quote
This afternoon, my wife lost a rim on highway 17 with my son in the back seat. She got it over to the side, but it was squirrely and both of them were pretty shook up. The lug bolts backed out. When I got there, I checked the other 3 and the two fronts were tight, but the other back was also loose.
Right before I drove the car up from So Cal to Nor Cal, I had the rims stripped and powder coated. New tires, then installed them myself and torqued them to 80 ft lbs. Not sure what the spec is but that should have been tight, since I've been doing it for decades.
I am not sure if the powder is a factor? Also, the fronts are disk, back are drum. Brakes were not dragging, and the car had no other issues. I mounted the spare and drove it home.
Any thoughts? I thought I remember a debate here about reaming the powder away from the bolt seats?
sjbartnik wrote:
Engines get hot. They have fire inside.
Tobias Bylund
Tobias Bylund is offline
PostPosted: Mon Oct 09, 2017 12:39 am    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
That was what i was about to suggest, i would for sure remove any powdercoating on the ball seat for the lugs/nuts on the rims, if that stuff breaks loose from the metal on the rim, you would have a loose nut
andk5591 Premium Member
andk5591 is offline
PostPosted: Mon Oct 09, 2017 3:45 am    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
Did a quick search on the net and this topic comes up quite a bit, so I am guessing there is some concern.
D-Dubya Manx clone - 63 Short pan,1914.
Max - 73 standard Beetle hearse project
There's more, but not keeping them...
H2OSB
H2OSB is offline
PostPosted: Mon Oct 09, 2017 5:46 am    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
Oooo Shocked , highway 17. I'd be shook up too!
I've been thinking about having my wheels powder coated. Maybe I'll insist they don't paint the lug holes.
H2OSB
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Oct 09, 2017 5:51 am    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
Very common for this to happen if you don't remove the powder coat from where the lugs sit on the rims. I had some lugs loosen on freshly painted rims as well. When I checked the lug torque, they had loosened. I unscrewed one of the looser lugs and found a thick layer of paint on the lug face.
I removed all 4 rims and removed the paint from the seat on the rims where the lugs tighten up. They never loosened again.
Bill
My 1970 bus refresh thread- http://www.thesamba.com/vw/forum/viewtopic.php?t=598191
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
pb_foots
pb_foots is offline
PostPosted: Mon Oct 09, 2017 6:19 am    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
OK, thanks guys. Guess I know what I'm doing this weekend!
This didn't happen for the first 50 years of the car's life, then within a thousand miles of powder coating. That's definitive enough for me I think.
campingbox Premium Member
campingbox is offline
PostPosted: Wed Nov 22, 2017 6:14 pm    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
Yes. For sure caused by the powdercoat. Sounds like you guys got lucky. Powdercoating is very thick and chips away easily with torque applied, leaving a gap. I nearly lost a wheel on my '57 after 200 miles of desert driving with powdercoated wheels. I got lucky. My buddy rolled his 23 window after a few thousand miles as well. Not so lucky. I'm sure a google search would yield all kinds of horror stories.
Cdennisg shared this genius idea
modified lug bolt for paint/powder coat removal
I used a cold chisel to plow a few grooves in a lug bolt. a quick spin with a drill and socket and the freshly coated lug bolt holes are shiny and free of paint, awaiting fresh contact with a lug bolt seating surface.
easy e Premium Member
easy e is offline
PostPosted: Thu Nov 30, 2017 12:54 pm    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
Lug bolt ^^ is a genius reactive method.
A good proactive method is to have the powdercoater wipe the lug holes prior to baking.
The powder wipes off like dust on a waxed coffee table.
It's how they do powdered Harley cylinders (with exposed fin edges).
Polish... powder... wipe... bake...
"They are about as worthless as the tits on the boars that live in the woods behind their junk yard." -Weatherly
Busstom
Busstom is offline
PostPosted: Wed Dec 06, 2017 1:00 pm    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
I'd never had a problem with powder coated wheels before, so I was a bit skeptical in the past.
Then more recently, when I had my Bay wheels powdered in a 2-part coat (clear coat over chrome silver), I torqued them on, but didn't drive. Then I broke torque and removed the rims to do some other stuff...low-and-behold, the powder coating on the lug seats was falling off in little ring-shaped layers, having yielded and delaminated under the pressure of the lugs being torqued on it.
Now I'm convinced that it ALL needs to come off the seats (or never be applied like the pre-wiping suggestion above).
W1K1
W1K1 is offline
PostPosted: Fri Dec 08, 2017 1:26 pm    Post subject: Re: Lost a wheel today. related to powder coat? Reply with quote
I do all my own powder coating and I've never had anything come loose after years of driving
Most of mine are mutiple coats.
the white wheel is, white base, clear with ice pearl, and then clear on top
the phone dials are almost chrome with a clear topcoat
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
