John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
tobiasax Samba Member
Posted: Tue May 21, 2013 10:26 am Post subject: Re: 1958 Model Year |
John Moxon wrote: |
Large 30 cm Ghia Decklid Script - 1955-1962
Hood Badge - Sept 1957-1962
Bat-ear Karmann Badge - 1955-1959 - Passenger side only.
Are you sure about the bat-ear badge? I spotted an (what I believe) un-touched March 1960 Ghia with the older style badge. |
Posted: Tue May 28, 2013 10:45 am Post subject: Re: 1958 Model Year |
John Moxon wrote: |
I think you could be right Tobias. The HoG catalog states 1956-1960 for the "Bat-ear" badge and 1961-1974 for the flat top badge. I have to say the issue isn't helped by the KGPR website stating 1956-1959 for the "Bat-ear" badge.
I think we need input from the gurus. |
According to Neuffers catalouge the old style emblem was until july 1960 (the same goes for "Ghia-only"-speedo, symmetrical-euro headlights and white front turn signals for non-Italian European markets.
I trust Neuffer over KGPR
See my blog for pics of the "untouched" March 1960 Ghia: http://lowlightkaizen.blogspot.se/ (in Swedish) |
aerosilver Samba Member
Posted: Tue May 28, 2013 11:51 am Post subject: Re: 1958 Model Year |
Nice '60 Will you post up some more pictures on your blog? |
JD1 Samba Member
Joined: February 27, 2004 Posts: 49 Location: Citizen of the world 😂 SLC UT
Posted: Wed Jul 24, 2013 2:44 pm Post subject: Bat Ear side badge different but |
But what about the sheet metal behind the early bat ear badge. Still the same basic outline indentation?
Or did it contour to the badge more earlier?
Just wondering. |
De_Lars Samba Member
Joined: January 20, 2013 Posts: 4 Location: Zandvliet
Posted: Tue Oct 01, 2013 11:56 am Post subject: |
I read somewhere that the sidetrim on a 61 is unique. Any confirmation or pictures on that?
Is it correct that the rear decklid of a 61 has the cooler dent only and no airfilter dent?
And while restoring mine i saw that the lowlight floor pan is used till 61. Dont know if it was used on later models to. |
c21darrel Samba Member
Posted: Tue Oct 01, 2013 2:00 pm Post subject: |
I dont think its side trim that is different, it is the door window chrome trim that is different. |
crede999 Samba Member
Posted: Mon Sep 01, 2014 10:30 am Post subject: Re: 1958 Model Year |
John Moxon wrote: |
tobiasax wrote: |
John Moxon wrote: |
hi john
i did alot of research on the badge and the batear badge is correct for early 1960 ghias basically the ones with the lowlite fuel tanks, dash etc in ...............
my wifes ghia is a feb 1960 new body outside all lowlite inside and under the front hood, it was a right headache sorting the right bits for it but luckerly it was mostly complete
regards
chris |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Wed Nov 08, 2017 8:49 pm Post subject: Re: Karmann Ghia Progressive changes 1955–1974 |
I'm looking for details on the interior of a 65. For instance, was the ignition key in the same position as on the 66 (to the right side of driver in LHD car) or was it on the left?
Thanks!
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
alansvwTwinCab Samba Member
Joined: December 28, 2005 Posts: 164 Location: Sydney, Australia
Posted: Fri Dec 08, 2017 9:24 pm Post subject: Re: Karmann Ghia Progressive changes 1955–1974 |
Can someone tell me if the seats from a 1961 ghia coupe are the same as those in a beetle? |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3915 Location: In Molinya Orbit
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Sat Dec 09, 2017 10:30 am Post subject: Re: Karmann Ghia Progressive changes 1955–1974 |
Late January 1957
Rotary klob (driver + passenger side) changed to "slide control" (driver side) |
Posted: Sat Dec 09, 2017 10:36 am Post subject: Re: Karmann Ghia Progressive changes 1955–1974 |
December 1958
Dashboard changed as preparation for the form fitting dashboard cover (>>1959) |
Sterck Samba Member
Posted: Thu Feb 01, 2018 7:55 am Post subject: Re: Karmann Ghia Progressive changes 1955–1974 |
Hello
Is it possible to have a picture of a 71 door scraper.
I can't find it for my french one (i'm french )
Thanks !! |
Scott@KGPR Samba Member
Joined: August 12, 2005 Posts: 92 Location: VENTURA, CA
Posted: Mon Oct 08, 2018 8:54 am Post subject: Re: Karmann Ghia Progressive changes 1955–1974 |
This is a 72 door. I can see by the steering wheel you have a 71 or earlier ghia.
Also, your door seal's round ball at the top back side of the door (as in your photo) should be pushed into the hole underneath the ball (not glued on top). _________________ Scott Dempster
www.karmannghia.com
(AKA, "The Ghia Guy") |
bnam Samba Member
Posted: Mon Oct 08, 2018 6:10 pm Post subject: |
sputnick60 wrote: |
pbaptist wrote: |
Here some more education (for the people who likes it)
First and second series of decklids had holes for the festoon bulbs. Like Dave (retrowagen) mentioned, the real early ones didn't have the Karmann ghia script. If you look carefully there is a dent for the airfilter and pressings in the upper part of the decklid
third style was still with the dent for the airfilter and with the pression.
Later there was a hole added in the lower left side of the decklid and two small drain holes at the left and right side on the botton
Next style had a larger holes and the pressings in the top partion disapperead
And after that the plastic rear tray appaired
Maybe I have missed a style, but this gives a nice overview.
regards
Patrick |
The number of clips for securing the harness to the license plate light also seems to have changed. Wit the later ones only seeming to have one clip. Would the harness not hang low over the engine/gen belt in that case?
Which of these decklids would correspond to the 65model? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Tue Oct 09, 2018 6:07 pm Post subject: Re: Karmann Ghia Progressive changes 1955–1974 |
I’d like to add that 71 had a one year only turn signal switch.
Not certain of all the technical differences but I do know that the horn ring contacts are different.
