projectclark Samba Member
Posted: Sun Dec 10, 2017 5:32 pm Post subject: Bolts won't come out! |
Restoring my '69 bug, took the transmission out and was attempting to remove the bolts that hold the arm to the tortion plate, however the head of the bolt contacts the trailing arm before it can come all the way out.
Do I need to remove the tortion plates and trailing arms as an assembly?
If so... why have bolts to connect them? Alignment purposes, since the holes are slotted?
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Sun Dec 10, 2017 5:40 pm Post subject: Re: BOLTS WONT COME OUT! |
The holes in the trailing arms are slotted, think if you get the diagonal trailing arm "more forward" in the slots, that you can wiggle the bolts out. I've removed trailing arms, but many decades ago.
I can't remember if the big allen-head bolt (17mm allen) needs to come out first to allow more movement.
Yes, the holes are slotted to allow rear toe adjustment. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Cusser Samba Member
Posted: Mon Dec 11, 2017 8:26 am Post subject: Re: BOLTS WONT COME OUT! |
joey1320 wrote: |
Once you remove them, remember to install them with the nut on the inside and the bolt coming through from the outside in. |
Yes, that would help. Just remember that someone got those bolts in there ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4407 Location: Stuck in Ohio
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Mon Dec 11, 2017 6:46 pm Post subject: Re: Bolts won't come out! |
If you run out of options just hack off the bolt and get new bolts, but as mentioned, it got in there somehow. They didn't build the car around that bolt. |
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Tue Dec 12, 2017 4:24 pm Post subject: Re: Bolts won't come out! |
Buggeee wrote: |
I freaked when I encountered this. Even started to work on those huge things that hold the trailing arms to the frame. Then I took a Phillips screwdriver and knocked that bolt right out. It popped right out no problem at all. It went right back in too, the same way it came out. Can't figure it out. Looked impossible to me. Its an illusion. It pops right out. Go get 'em. |
My guess is that with the hole being slotted, it allows the bolt to pass through at an angle. _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Posted: Tue Dec 12, 2017 5:11 pm Post subject: Re: Bolts won't come out! |
shakers73 wrote: |
Buggeee wrote: |
My guess is that with the hole being slotted, it allows the bolt to pass through at an angle. |
It's magic. Gives me chills just thinking about it. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
