Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed May 28, 2008 8:03 pm Post subject: |
The correct distrbutor is a 131 905 205 with no letter suffix. |
OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Wed May 28, 2008 8:44 pm Post subject: |
malachai wrote: |
[ if you want to make life even easier that would be a good time to fit a cut off tap so that next time you need to change your filter you don't get so much petrol in your eyes/mouth/nose/belly button. |
nice tip _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Wed May 28, 2008 9:48 pm Post subject: |
So my engine has no number, but a vw symbol with a recycle symbol around it and an H next to it. After a search, I found out it's a factory rebuilt 1500 H engine. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Sun May 29, 2011 5:10 pm Post subject: |
Reviving an old thread here. I have a few updates and more questions.
Here is all of my tin off of the engine.
I am obviously missing a few pieces. I now have the 67 only front and rear tin with matching heat exchanger. (thanks Camerod!).
I have no flaps in the fan shroud, the cylinder tins are still on the engine, and the generator piece is a chinese chrome pos so thats getting replaced along with the generator nut and pulley and the chrome oil filler.
Clara said i need to replace the tin piece behind the crank pulley. Im not sure what piece i would need to look for though.
What is the correct carb for a late 67 bus?
What else is missing? _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon May 30, 2011 7:40 am Post subject: |
OG Velvet wrote: |
What else is missing? |
See that little piece at the bottom of the photo? It shouldn't have a hole in it (if it does) and you need the right side one with no hole or cutout. Your heat riser-to-fan shroud pair are missing as well as the top pulley cover. Does the air cleaner have the heat riser flap?
OG Velvet wrote: |
What is the correct carb for a late 67 bus? |
30 PICT-1
211 129 027K or 211 129 027K with VW 78-1 modification
OG Velvet wrote: |
Although not tin, if you want the carb elbow to line up with the aircleaner elbow you'll want the 211 129 701G intake manifold and the 28 DR-1.5 governor (or the replacement spacer). |
Posted: Mon May 30, 2011 8:25 pm Post subject: |
In the middle of your rear tin there is a weld nut/hole. There is a piece of tin that screws into that hole and covers the space between the reat tin and the crankshaft pulley. I've seen quite a few in the classifieds. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
galexander Samba Member
Joined: April 17, 2003 Posts: 524 Location: Round Rock, TX
Posted: Tue May 31, 2011 7:58 pm Post subject: |
great stuff on making something correct, I love this.
OK, couple of things:
fresh air hose rubber gasket goes between tin and 'h' pipe.
Not sure if a Bus generator had the plastic cover on it where the brushes are, I thought it was for Beetles only, possibly to keep moisture from gen brushes maybe? _________________ enjoy the journey,
Gary
Check out our YouTube Channel, VW Life |
Old Paint Samba Member
Joined: May 29, 2010 Posts: 436 Location: Battle Ground, Washington
Posted: Wed Jun 01, 2011 9:00 pm Post subject: |
You going to the show this weekend in Woodburn???? You should be able to get all those missing pieces at the swap meet, $1-$10. I have a H engine also and went with the 30 pict-1 and k vacuum advance distributor. RUNS AMAZINGLY!! PM me for sources.
Just swapped my plastic fuel filter, less than a year old, not many miles, damn thing fell apart. I went from "yeah yeah whatever" to a believer. _________________ Greg
1961 Ragtop
1961 Single Cab (Old Paint) |
Posted: Sun Nov 26, 2017 6:06 pm Post subject: Re: Can someone ID my engine and what it's missing? |
Ok. It's been a minute. Bus is restored and painted. I'm slowly putting it all back together (build thread to come)...
I have been collecting engine pieces based off of the info in this thread (thank you). Here is an updated pic of my tin. I have replaced almost everything. The fan shroud is still the same from the 68 beetle, but I have found flaps and linkage. The top of cylinder tin is also the same. Everything else is new. Can anyone confirm that I do or do not have all of the correct tin?
I also have a 30 pict 1 that I am rebuilding right now. I still need the correct distributor. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Sun Nov 26, 2017 6:33 pm Post subject: Re: Can someone ID my engine and what it's missing? |
One example of the correct distributor.
https://www.thesamba.com/vw/classifieds/detail.php?id=1138141 _________________ Roads Scholar &
Posted: Sun Nov 26, 2017 9:54 pm Post subject: Re: Can someone ID my engine and what it's missing? |
Mocked some things up. Getting somewhere!
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Sun Dec 10, 2017 10:25 pm Post subject: Re: Can someone ID my engine and what it's missing? |
I've had this for a few years now, just waiting for when I put this motor back together correctly. I thought this was the 67 only heat exchanger... Just realized it's for the wrong side... Also the hole is plugged. Kinda sucks because I want to have the correct pre heat going for my bus. The search continues... _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Dec 11, 2017 10:07 am Post subject: Re: Can someone ID my engine and what it's missing? |
OG Velvet wrote: |
I've had this for a few years now, just waiting for when I put this motor back together correctly. I thought this was the 67 only heat exchanger... Just realized it's for the wrong side... Also the hole is plugged. Kinda sucks because I want to have the correct pre heat going for my bus. The search continues... |
For now you can pull the plug and route the hose to it. Most of the older heavy replacement HE's had those provisions on them and the mounting kits had the plugs. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Dec 11, 2017 12:26 pm Post subject: Re: Can someone ID my engine and what it's missing? |
Leave the left side hole plugged. A 67 needs that snout on the right side only.
They are not that hard to find. Do a search in general parts for heat exchangers and I bet you find a seller with what you are looking for. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Dec 11, 2017 3:58 pm Post subject: Re: Can someone ID my engine and what it's missing? |
Be a very good time to upgrade to dog house shroud and oil cooling system. Old non-DH shroud preheats the cooling air to #3&4 cylinders, which leads to failure of #3 cylinder all too often. You will need matching DH cooling fan and crankshaft pulley to pump more air thru the fan shroud to get enough cooling.
Might as well add a CB Maxi 2 or VW of Mexico stock oil filter/pump to keep metal shavings in the oil from chewing up the bearings. Need to match oil pump to the camshaft you are using, and do a little research on having the filter clear the muffler heat riser tube. _________________ In Stereo, Where Available! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Mon Dec 11, 2017 8:56 pm Post subject: Re: Can someone ID my engine and what it's missing? |
Super funny. I was just researching the doghouse setup last night because I just happen to have all the pieces for a DH setup except the Hoover bit and the cooler itself. I’ll just drill the front tin for the correct 67 pre heat. I still want to have a correct “appearing” engine. Sounds like DH is the way to go. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Mon Dec 11, 2017 9:17 pm Post subject: Re: Can someone ID my engine and what it's missing? |
I need the hoover bit, thermostat and the DH pulley. Anything else? What’s the nipple on top of the DH shroud for?
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Mon Dec 11, 2017 9:28 pm Post subject: Re: Can someone ID my engine and what it's missing? |
What width of cooling fan do you have? Inside measurement at the outer diameter. _________________ In Stereo, Where Available! |
Posted: Mon Dec 11, 2017 9:42 pm Post subject: Re: Can someone ID my engine and what it's missing? |
I don’t have the exact measurement, but it came off of the same car with the DH stuff and it’s wider than my other one. What size crank pulley should I be looking for? _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
