Tie rod assembly passenger side listed as 181 part why?
74 Thing
74 Thing is online now
PostPosted: Sun Dec 10, 2017 10:43 pm    Post subject: Tie rod assembly passenger side listed as 181 part why? Reply with quote
I see that the complete tie rod assembly on the passenger side is listed as a 181 part. The tie rod ends are type 1 parts. Is there anything special between the Thing tie rod and a Type 1 tie rod tube on the passenger side?
Thanks
Al Capulco
Al Capulco is offline
PostPosted: Mon Dec 11, 2017 12:25 am    Post subject: Re: Tie rod assembly passenger side listed as 181 part why? Reply with quote
I think it may be longer.
YDBD
YDBD is offline
PostPosted: Mon Dec 11, 2017 4:19 am    Post subject: Re: Tie rod assembly passenger side listed as 181 part why? Reply with quote
Thicker wall tubing? Many things were similar to Type I, but beefier to handle off road driving or extra weight of the Thing.
Or just more money...
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
el_safari
el_safari is offline
PostPosted: Mon Dec 11, 2017 4:20 am    Post subject: Re: Tie rod assembly passenger side listed as 181 part why? Reply with quote
Hello
the 181 tie rod is thicker than the bug tie rod Cool
La terre n'est qu'un seul pays
sam_w
sam_w is offline
PostPosted: Mon Dec 11, 2017 9:36 am    Post subject: Re: Tie rod assembly passenger side listed as 181 part why? Reply with quote
I bent my tie rod off-roading, and yes the typ 181 tie rod is stronger. I put a sleeve around my bug tie rod, The long one will buckle if you hit a rock with the wheels turned.
63 singlecab
73 thingster
74 Thing
Wildthings
Wildthings is offline
PostPosted: Mon Dec 11, 2017 12:13 pm    Post subject: Re: Tie rod assembly passenger side listed as 181 part why? Reply with quote
You can slide a piece of pipe over the 181 tie rod to strengthen it. Sorry not sure the size I used, maybe 1" Sch 40, NPT???
sam_w
sam_w is offline
PostPosted: Fri Dec 15, 2017 4:06 pm    Post subject: Re: Tie rod assembly passenger side listed as 181 part why? Reply with quote
This is what happens to a non 181 tie rod!
63 singlecab
73 thingster
74 Thing
