Pcella Samba Member
Joined: December 09, 2017 Posts: 8 Location: Shreveport
Posted: Sat Dec 09, 2017 7:52 pm Post subject: Turbo Engine Locked Up. |
I just purchased a very nice 73 sedan with a 2276 turbo.
The motor was built by a reputable air cooled turbo builder.
It had already been broken in and I was told had about 1500 miles on it.
I put probably 2 miles on it after purchasing and made one short, maybe 1/8 mile pull and the motor locked up.
I have absolutely no air-cooled experience, but a good amount of performance experience, mainly with small block chevy and LS motors.
I have pulled the motor out and removed the heads and cylinders and all seems well with them and the pistons, but the motor is still locked up.
I am guessing that I have lost a main bearing but not sure.
Any suggestions or ideas what else it could be?
I'm really don't want to take this thing down any further myself since I have no idea what I am doing.
Also anyone know of a good performance shop close to Shreveport (North) Louisiana?
Thanks for the help,
Pat |
Brian Anthony Samba Member
Joined: October 02, 2006 Posts: 215 Location: Longview TX
Posted: Sat Dec 09, 2017 7:57 pm Post subject: Re: Turbo Engine Locked Up. |
Take it to Oak Hill Automotive in Longview TX. A second generation classic VW garage. _________________ 1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans. |
modok Samba Member
Posted: Sat Dec 09, 2017 8:12 pm Post subject: Re: Turbo Engine Locked Up. |
Seized #1 main bearing is a common problem.
Any given set of bearings in any given engine case, these days, good chance it will be too tight or too loose, they can't seem to get it right every time like the Germans.
Chevy small blocks have had the exact same problem. Some specs say #5 main is smaller than the rest and others don't. Are you familiar with that? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Dec 09, 2017 10:17 pm Post subject: Re: Turbo Engine Locked Up. |
Pcella wrote: |
Pat |
Man that's bad luck! Definitely sound like you spun a bearing. Since it's such a new engine, everything should be in good shape. Find out why it spun a a bearing, and get it put back together. Usually it's parts that didn't fit together, or oil starvation. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Dec 10, 2017 4:58 am Post subject: Re: Turbo Engine Locked Up. |
Deep sump? got a pic of the Motor? That will help us, But I'm guessing a spun rod bearing too _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Pcella Samba Member
Posted: Sun Dec 10, 2017 2:09 pm Post subject: Re: Turbo Engine Locked Up. |
Guys,
Thanks for all of the quick responses.
Brian, I will get with Oak Hill and see what they have to say. Any idea if they have any experience with turbo engines?
Modoc, Yes I familiar with the confusion on the #5 main on smc engines. I'm afraid that we may be showing our age here. lol
Madmike, I'll try to get a picture of the engine posted tonight.
Thanks for all of the help! |
Posted: Sun Dec 10, 2017 2:15 pm Post subject: Re: Turbo Engine Locked Up. |
Yes, Oak Hill has plenty of experience with turbo engines. Ask for Daniel Watts. 903-297-3496 _________________ 1965 Double Cab
1967 Bug, Sedan
modok Samba Member
Posted: Sun Dec 10, 2017 3:25 pm Post subject: Re: Turbo Engine Locked Up. |
Pcella wrote: |
Great. Basically #5 was most likely to seize if it was too tight or saw a little oil starvation, so you want a little more clearance on #5 than the other bearings in the end, but they did that a few different ways depending on if they ground the crank smaller OR made the bearing thinner.
Same here. Mahle brand generally they make the #1 bearing for a bit more clearance but the other brands don't.
Silverline has the BEST main bearings these days but if you end up with #1 being tighter than it should be you gotta do something about it, maybe polish the crank smaller or get a set of mahle bearings and just use the #1 out of it perhaps.
So, might be anything but it probably is the SAME OLD problem.
Can't use plastigague tho, the bearing is a full circle. |
Pcella Samba Member
Posted: Sun Dec 10, 2017 7:13 pm Post subject: Re: Turbo Engine Locked Up. |
Here is a picture of the engine.
[/img] |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Mon Dec 11, 2017 3:09 am Post subject: Re: Turbo Engine Locked Up. |
What's the I.D. of that 90° bend you're using on the oil full-flow inlet to the case? that looks like it could be restrictive. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Mon Dec 11, 2017 6:26 am Post subject: Re: Turbo Engine Locked Up. |
X2
Looks like a reducer and then a ninety. Also looks like the SAE style hardware instead of AN style. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Mon Dec 11, 2017 9:50 am Post subject: Re: Turbo Engine Locked Up. |
clonebug wrote: |
X2
Looks like a reducer and then a ninety. Also looks like the SAE style hardware instead of AN style. |
Yup. Seems like a bit too much brass. Small at that. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Mon Dec 11, 2017 10:52 am Post subject: Re: Turbo Engine Locked Up. |
I had one lock up under an hour old, no 2 rod had stuck on crank due to lack of oil, due to dirt and debris blocking oilways, due to a complete numpty being left in charge of it. |
Pcella Samba Member
Posted: Mon Dec 11, 2017 11:41 am Post subject: Re: Turbo Engine Locked Up. |
FreeBug wrote: |
I'm not at home where I can look at it, but are you talking about the brass fitting?
I don't know what's up with that. For the most part the thing seems pretty quality and there was a lot of money spent on quality parts where he could have skimped, but didn't. I did notice that and wondered why he went with that verses an an fitting. |
jason Samba Member
Posted: Mon Dec 11, 2017 4:01 pm Post subject: Re: Turbo Engine Locked Up. |
If the rods are still free, not there. You’re almost there. |
Pcella Samba Member
Posted: Mon Dec 11, 2017 5:55 pm Post subject: Re: Turbo Engine Locked Up. |
I looked at that fitting closer and if I was a betting man I would say that's probably what caused my problem.
I didn't measure it, but I'm almost sure that it an AN4 (1/4") reduced from about an AN8 (1/2").
I wonder why anyone would buy forged pistons and rods, port and polish the heads, go with a high dollar turbo and cheap out on the hose and fittings. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Mon Dec 11, 2017 6:05 pm Post subject: Re: Turbo Engine Locked Up. |
Do you know that the engine had real miles on it before you bought it? _________________ modok wrote:
Dale M. Samba Member
Posted: Mon Dec 11, 2017 6:06 pm Post subject: Re: Turbo Engine Locked Up. |
Because builder was probably not person who "assembled" the parts to put it in car....
Posted: Mon Dec 11, 2017 6:12 pm Post subject: Re: Turbo Engine Locked Up. |
Dale M. wrote: |
Dale |
This.
The engine was sold as a long block I bet. Whoever put the ancillaries on it probably just used what they had, or didn't know better. You can get away with that (maybe) on a low rev stocker, but not a high revver turbo. You need oil! |
Pcella Samba Member
Posted: Tue Dec 12, 2017 5:22 am Post subject: Re: Turbo Engine Locked Up. |
esde wrote: |
Do you know that the engine had real miles on it before you bought it? |
I was told that it had 1500 on it. |
