Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Wed Dec 13, 2017 4:25 am Post subject: New engine build by ladies |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5305 Location: Central Florida
Posted: Wed Dec 13, 2017 4:43 am Post subject: Re: New engine build by ladies |
If I’m not mistaken your #4 rod is upside down. Hopefully this was corrected before assembly. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Wed Dec 13, 2017 5:04 am Post subject: Re: New engine build by ladies |
Yes..fixed b4 case closed..thank u.. |
Posted: Wed Dec 13, 2017 5:13 am Post subject: Re: New engine build by ladies |
Out of curiosity, what all did you do? What size was it originally? Did you rebuild it to factory or increase displacement? Did you rebuild the heads or just clean them up and put them back on? In the circled area it appears you are missing the plate that belongs there. Helps cool the heads. I also don't believe you're supposed to use sealant between the jugs and the case. What condition was the case? Were the align bore or thrust out of spec?
Also, looks like the crankshaft pulley may be smaller and result in the fan turning slower and increase temperatures. Did you rebuild any of the components or just buy new? Looks like you put an aftermarker SVDA on, what are your plans for carburation? Some of the OG carbs don't play well with the SVDA as the vac signal is incorrect. You may be better off cleaning up the OG distributor and carb and using those. Check the fuel pressure on that fuel pump. A lot of the aftermarket ones put out too much pressure. Again, you may have been better off cleaning up and using the old one instead of spending money on new. More information on what all you did would be great if you're looking for input. If you're not we can all bugger off. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Zundfolge1432 Samba Member
Posted: Wed Dec 13, 2017 5:23 am Post subject: Re: New engine build by ladies |
Most of the women mechanics I’ve worked with over the years have done better than the men. They take time double check and are detail oriented, especially in metal working or that which requires a good eye. |
Posted: Wed Dec 13, 2017 5:30 am Post subject: Re: New engine build by ladies |
Zundfolge1432 wrote: |
I don't doubt it at all. I'm impressed that they tackled this as I'm still looking at my stack of parts trying to get the courage to jump in. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Dec 13, 2017 5:31 am Post subject: Re: New engine build by ladies |
Thanks guys 4 comments.
We bought all new parts.same size case.1600 standard..happy 4 comments. |
Posted: Wed Dec 13, 2017 5:34 am Post subject: Re: New engine build by ladies |
The extra fin on heads was in the way of thermostat rod..we filled it for 5 hours careful not to bend rod..heads new ..bad aftermarket.. |
Posted: Wed Dec 13, 2017 5:39 am Post subject: Re: New engine build by ladies |
Joannekay wrote: |
Seriously, you may have been better off rebuilding components and saving the cash. May be worth your time to muddle through the rest of my comments and check some things.
Here's a good article and diagram of all the tin that you should have:
http://www.vw-resource.com/engine_tin.html _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Dec 13, 2017 5:50 am Post subject: Re: New engine build by ladies |
Posted: Wed Dec 13, 2017 5:54 am Post subject: Re: New engine build by ladies |
Sharp I’m not sure what u are saying..we decided 2 purchase all new & build..hard 2 check if crankshaft is balanced..case had small cracks..heads had done there time..thank u 4 comments but I don’t find them helpful . |
Posted: Wed Dec 13, 2017 6:02 am Post subject: Re: New engine build by ladies |
bugger off it is then. Good luck. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Wed Dec 13, 2017 6:40 am Post subject: Re: New engine build by ladies |
Nice work going on in your shop. Please keep an eye on that new style thermostat, I've heard and read they can be sketchy at best. Keep the pic's coming _________________ 1960 Convertible |
bluebus86 Banned
Posted: Wed Dec 13, 2017 7:00 am Post subject: Re: New engine build by ladies |
lovethatconvertible wrote: |
Nice work going on in your shop. Please keep an eye on that new style thermostat, I've heard and read they can be sketchy at best. Keep the pic's coming |
new style wax thermostats are known to fail with flaps closed. original types fail with flapsnopen. which do you want??? the new types only have to fail once to ruin the motor. source a good used orignal type.
see link below on safety wires and engine fires.
good luck, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Wed Dec 13, 2017 7:03 am Post subject: Re: New engine build by ladies |
As mentioned Looks nice and clean assembly...Do source out a stock thermostat. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Wed Dec 13, 2017 7:10 am Post subject: Re: New engine build by ladies |
Joannekay wrote: |
I think he was trying to say it’s standard operating procedure to measure the parts for tolerance and wear, that and a little non destructive testing will tell you if parts are serviceable.
This may be hard to do if you don’t have the measuring equipment and experience and know what to look for. This is where a machine shop comes in.
The crank may have just needed polishing and they don’t go out of balance with use. They are either balanced or within spec from the seller, or maybe not it’s up to you to check. In fact it only gets slight mention but it’s a great idea to take all the rotating parts in for balance prior to assembly, you can exceed factory specs for a really smooth long lasting engine with a little effort here.
Looking at your pic make real sure that tarboard is secure, it would be a real shame to suck that into the fan and cook a new engine. Have fun and congrats on tackling that project. Few here know the feeling of DIY. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31266 Location: Hot Arizona
Posted: Wed Dec 13, 2017 7:29 am Post subject: Re: New engine build by ladies |
I'm pretty impressed.
Looks like you stayed with non-doghouse, and used the Brosol Solex 30/31 PICT carb. I use that carb on my 1600cc engine, and have been OK with it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Dec 13, 2017 8:24 am Post subject: Re: New engine build by ladies |
Cusser wrote: |
Looks like you stayed with non-doghouse, and used the Brosol Solex 30/31 PICT carb. I use that carb on my 1600cc engine, and have been OK with it. |
But what distributor are you running it with? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6554 Location: Houston, Texas
Posted: Wed Dec 13, 2017 11:38 am Post subject: Re: New engine build by ladies |
Good stuff. I'm always trying to get my wife involved. _________________ www.vwnos.com [email protected]
