begood56vw Samba Member
Posted: Thu Dec 14, 2017 10:58 pm Post subject: 1966 fastback brake problem. |
Hello fellers, I'm stumped with my brakes on my 1966 fastback and I hope someone can help out.
First, I've checked most of the links in the samba, and of course, I can't find anything that might help me.
To start, I have 914 rims on my fastback. I started hearing some chirping sounds coming from the rear so I decided to remove the rear drums and check the brakes. I didn't find anything wrong but when I was putting back the rims, I stripped the treads of the hub.
I bought new rear hubs from a respectable vendor and after a week of driving it, I began getting a pulse (kinda like the front rotors being warped) at the brake pedal.
I bought new rotors, brake pads and wheel bearings and installed them. Well the problem is still there. I drove my fastback on the freeway and when I stepped on the brake it felt like I have ABS brakes.
Any help would be appreciated. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Fri Dec 15, 2017 12:18 pm Post subject: Re: 1966 fastback brake problem. |
Thanks for the reply W1K1. I just took the drums off and checked the shafts. They looked okay. Only issue I noticed was the rear brakes needed adjustment. I’ll drive it to work today and I hope that fixed the problem. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Fri Dec 15, 2017 12:26 pm Post subject: Re: 1966 fastback brake problem. |
look at the front, make sure the calipers were ground down and not hitting the wheels. I know you said rear, but check. When you run aftermarket wheels on a disc type 3, you usually need to grind them down _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri Dec 15, 2017 12:58 pm Post subject: Re: 1966 fastback brake problem. |
Erik G wrote: |
look at the front, make sure the calipers were ground down and not hitting the wheels. I know you said rear, but check. When you run aftermarket wheels on a disc type 3, you usually need to grind them down |
Thank you Erik for the suggestion. Weird is that my fastback has been my daily driver for several years, with the 914’s on it and Im not hearing any noise like if it’s rubbing up front.
Yesterday coming home from work, I pulled the ebrake, holding the button down of course, and i felt the shaking coming from the rear. That was without pressing the brake pedal. So I leaning towards the NEW rear hub being the problem. |
Erik G Samba Member
Posted: Fri Dec 15, 2017 1:33 pm Post subject: Re: 1966 fastback brake problem. |
begood56vw wrote: |
Erik G wrote: |
ok, yep. with that added info, I agree _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri Dec 15, 2017 3:00 pm Post subject: Re: 1966 fastback brake problem. |
Update; I adjusted the rear brakes and got on the freeway. Oh my, just driving 65 mph, the fastback was shaking like crazy. Then after a short time, it would feel ok. After about 5miles, I decided to take the Vdub back home. To scary to drive it. I’m still kinda stumped. Any help would be great. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Fri Dec 15, 2017 3:57 pm Post subject: Re: 1966 fastback brake problem. |
Make absolutely sure the hubs are torqued to the proper value. If you are satisfied that they are, pull them and look them over. Do you still have the old ones to compare? There have been some reports of new hubs being not so great, but I haven't had any personal experience with them. _________________ 71 Elm Green FI A/T Squareback |
Posted: Fri Dec 15, 2017 4:29 pm Post subject: Re: 1966 fastback brake problem. |
I used the torque tool which makes it easier to remove and torque the axle but so I believe it’s properly torqued. I don’t have the original hub anymore( in the garage it went). .
I will take it off and check it. I did buy two new hubs and still have another new one that I will install. I hope that’ll fix it. Fingers crossed. |
Posted: Wed Dec 20, 2017 10:18 pm Post subject: Re: 1966 fastback brake problem. |
Another Update;
I changed the hub for another new rear hub, torqued it to the proper numbers and drove it on the freeway.
When I press on the brakes, it shakes like no tomorrow. I'm now thinking it might be the rear drums that are bad. Sucks.
Any suggestions would be appreciated. Thank you in advance. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Dec 21, 2017 10:54 am Post subject: Re: 1966 fastback brake problem. |
Did you leave off the OG allen head bolts that hold the rear drums on? They will interfere with most aftermarket wheels. I have to run 1/4" spacers on the rear to get the dust covers to fit on my OG Fuchs 914 wheels. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Dec 21, 2017 6:26 pm Post subject: Re: 1966 fastback brake problem. |
Thank you Mr. Fisher. I will remove the allen head bolts from the drum and see if that'll help out. When you say "1/4 in spacers", are you referring to placing washers between the drum and rim?
Thank you. |
Posted: Fri Dec 22, 2017 11:39 am Post subject: Re: 1966 fastback brake problem. |
The EMPI #16-9926 aluminum wheel spacers I use are actually 3/8" thick I see. I ordered longer lug bolts from http://www.ezaccessory.com/Lug_Wheel_Bolts_s/20.htm _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Dec 25, 2017 1:27 pm Post subject: Re: 1966 fastback brake problem. |
Mike Fisher wrote: |
Did you leave off the OG allen head bolts that hold the rear drums on? They will interfere with most aftermarket wheels. I have to run 1/4" spacers on the rear to get the dust covers to fit on my OG Fuchs 914 wheels. |
I removed the OG Allen bolts and drove the fastback. I still have the pulsating brake pedal feeling. ☹️ |
Bobnotch Samba Member
Posted: Tue Dec 26, 2017 2:25 pm Post subject: Re: 1966 fastback brake problem. |
begood56vw wrote: |
Sounds like a drum out of round. Might try taking it to a good auto parts place and have them do a slight cut on them to true them up. Explain to the guy there what's going on, and see if he can help you. If that doesn't fix it, then I'd look at replacing the stub axle as it might be bent. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Dec 26, 2017 2:37 pm Post subject: Re: 1966 fastback brake problem. |
Thanks Bobnotch for the suggestion. I will remove the rear drums and have them turned. I’m leaning towards bad drums. Fingers crossed. |
Posted: Tue Dec 26, 2017 3:57 pm Post subject: Re: 1966 fastback brake problem. |
begood56vw wrote: |
Keep in mind that good used Original German type 3 drums are better than the new repop drums. This is mainly because the repop drums are cast as 1 piece, and are machined off center. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Dec 27, 2017 8:25 pm Post subject: Re: 1966 fastback brake problem. |
Dang.... I didn't read the message soon enough. I just ordered two new drums. We'll see if that fixes the problem. Thank you. |
stonecoldcars Samba Member
Joined: February 21, 2013 Posts: 265 Location: Oregon
Posted: Thu Dec 28, 2017 1:27 pm Post subject: Re: 1966 fastback brake problem. |
I would agree with warped drums(out-of-round). I've had the same issue on a beetle I use to have. and fixed it with the drums turned at a machine shop. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Thu Dec 28, 2017 7:08 pm Post subject: Re: 1966 fastback brake problem. |
If you can get it down to Santa Cruz I can check it out for you.
A 2nd set of eyes can be invaluable sometimes...
My first thing to do would be to put an indicator on the rotors and drums and see if anything is running out. _________________ Bus Motor Build
What’s That Noise?!? |
