Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5305 Location: Central Florida
Posted: Fri Dec 15, 2017 8:13 am Post subject: Re: Rewiring my buggy |
Not a bad idea about the brown wire. I may look into that if I completely rewire. I do remember seeing brown wire I think at O’Reilly. We have a place here called Skycraft that is like a Radio shack on steroids that deals in surplus parts. They have shelves full of wire of any and all colors. If I decide to completely rewire I’ll be going there and getting my wire.
As an example I found open barrel connectors for $.05 yesterday!! I’m going back this weekend to scoop up the rest of what they had. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Dec 15, 2017 8:15 am Post subject: Re: Rewiring my buggy |
MrGoodtunes wrote: |
Dale M. wrote: |
.... The tab at bottom of three light cluster goes to 12 volts with key on....
It powers the ALT, OIL and high beam (idiot) lamps... |
Don't you mean ALT, OIL and turn signal indicator ? |
Yeah... Its hell getting old and not having a VW speedo around for reference (all VDO gauges here)....
Posted: Fri Dec 15, 2017 8:27 am Post subject: Re: Rewiring my buggy |
Q-Dog wrote: |
Here is a tip to make things easier ... pick a different color of wire for grounds and only use it for grounds. Brown is probably the best choice because lots of vehicles use that.
It seems none of my FLAPS carry brown wire, but I picked up a roll of brown the last time I ordered terminals from Delcity and I am using that exclusively for grounds on all my wiring projects. The advantage is that lots of vehicles use brown for ground so that makes it easy to remember.
Recently installed a new factory style harness in a 1957 Chevy pickup, and when I ran a couple of new circuits I used the brown for grounds. Looks like factory work under the dash. |
YES its very European on vehicles that use DIN codes to have brown as ground... And newer "computer" cars...
Personally I went a slight different way.... All UNFUSED 12volts are RED and ALL grounds are black.... Blue for high beams (sky) green for low beams (grass).... And other silly stuff
Also number tags ... If you tag something #12 on one end, the other termination is also #12, you can sort of go by the numbers and forget colors....Put number in middle of wire run on diagram....
Best of all is wiring kits with function printed directly on wire...
