Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Dec 14, 2017 11:53 pm Post subject: Cam Lobe Clearance |
I have .040 clearance or more on every point the crank or rods come near the cam except this spot on the #1 #3 crank cheek, its only .028 here. This is probably the stiffest part of the crank, am I good to go or do I hit it with the disc and rebalance the assembly?
_________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Fri Dec 15, 2017 2:09 am Post subject: Re: Cam Lobe Clearance |
Can you maybee degree the cam, and maybee you're lucky
and needs to retard or advance 3 degrees?
just an idea _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
jason Samba Member
Posted: Fri Dec 15, 2017 10:39 am Post subject: Re: Cam Lobe Clearance |
One of the reasons to balance after mock up, just saying. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Fri Dec 15, 2017 12:36 pm Post subject: Re: Cam Lobe Clearance |
This a 2332? My Buick journal 84 had plenty of room _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
maui Samba Member
Posted: Fri Dec 15, 2017 2:28 pm Post subject: Re: Cam Lobe Clearance |
I had a similar problem wen I had 5.7 rods and 90 stroke so I had my rods contoured smallkine to get my 50 clearance. It costed $40.00 contour and rebalanced. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Fri Dec 15, 2017 2:30 pm Post subject: Re: Cam Lobe Clearance |
Is the crank in its proper orientation, as it would be with final end play set? The gap might increase if you slide the crank to its final position and the tapered cam lobe moves away a bit. This still may not give you 0.040”. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Teeroy Samba Member
Posted: Fri Dec 15, 2017 4:56 pm Post subject: Re: Cam Lobe Clearance |
Jason, normally that would be proceedure for me, but this one was balanced already from its first incarnation as a 2007.
This was a NOS made in USA Bugpack 78mm crank.
Maui its the crank web to cam nose not the rod on this one.
Neil yes to dots, no to end play, pushing crank against thrust surface helped some.
I took a finishing file and lightly went over the tight spot (it was coursely clearanced here from the original builder) taking the sharp corner off and have enough room now. didnt hardly remove any material, and being so close to the main journal I doubt the balance changed enough to notice _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
jason Samba Member
Posted: Fri Dec 15, 2017 6:31 pm Post subject: Re: Cam Lobe Clearance |
What cam is that? I have an 86C with an 86 crank and have a ton of room. |
Teeroy Samba Member
Posted: Fri Dec 15, 2017 6:37 pm Post subject: Re: Cam Lobe Clearance |
WEB 86B, VW journal 78mm crank. Crank webs are beefy on this _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Fri Dec 15, 2017 6:54 pm Post subject: Re: Cam Lobe Clearance |
Looks like they ground the cam with big base circles. What kind of crank is that? Old bugpack? |
Teeroy Samba Member
Posted: Fri Dec 15, 2017 7:51 pm Post subject: Re: Cam Lobe Clearance |
Yep USA made Bugpack _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Fri Dec 15, 2017 7:58 pm Post subject: Re: Cam Lobe Clearance |
Teeroy wrote: |
Yep USA made Bugpack |
Yep thought so, better than the current China stuff. Dan |
nsracing Samba Member
Posted: Fri Dec 15, 2017 9:32 pm Post subject: Re: Cam Lobe Clearance |
you need to bevel just a little to gain clearance. don't go crazy though just a little.
Do all the fitting and mock assembly before getting all the parts balanced. |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Sun Feb 25, 2018 11:29 am Post subject: Re: Cam Lobe Clearance |
same issue here . what is minimum acceptable clearance? _________________ "Albatross"! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Feb 25, 2018 12:55 pm Post subject: Re: Cam Lobe Clearance |
calvinater wrote: |
same issue here . what is minimum acceptable clearance? |
0.040" of about the thickness of a "zip" tie according to modok.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Feb 25, 2018 1:31 pm Post subject: Re: Cam Lobe Clearance |
thanks 67Rusty,, lost count of mock ups so far, more clearancing ,more cleaning
hows your stroker build going? _________________ "Albatross"! |
Posted: Sun Feb 25, 2018 2:24 pm Post subject: Re: Cam Lobe Clearance |
calvinater wrote: |
hows your stroker build going? |
Slowwww! But picking up speed.
I feel ya on the numerous mock ups. I think I have done mine at least ten times now.
Buy Once, Cry Once!
Teeroy Samba Member
Danwvw Samba Member
